Wheight of Web Spokes? ANYONE KNOW?
Old Apr 21, 2005 | 01:18 PM
gavin7777's Avatar
gavin7777
How much do the factory 17" Web spokes wheigh? I've seen all of the other wheights posted but those. They are a beautiful wheel by the way, I saw some at the dealer the other day on a black and white S! SWEET!!
Old Apr 21, 2005 | 02:23 PM
morknmini's Avatar
morknmini
"17" factory web spoke" is probably the optional 2 piece 7x17 R-90 wheel. That weighs 10.95 Kg.
Old Apr 21, 2005 | 04:04 PM
XAlfa's Avatar
XAlfa
MotoringFile reports 22.3 pounds. Portly little mothers.
Old Apr 22, 2005 | 07:05 AM
holdenontoit's Avatar
holdenontoit
Style R81 (7-hole) 5.5Jx15 - 1512458 & 1512459 = 5.45Kg Offset = 45mm
(Cooper w/ all season tires) [weight is 14.601794lb]
Style R82 (8-spoke) 5.5Jx15 - 1512347 & 6756674 = 6.9Kg Offset = 45mm
(Cooper w/ all season tires) [weight is 18.4866793lb]
Style R83 (5-star) 6.5Jx16 - 1512348 & 1512349 = 9.1Kg Offset = 50mm
(Cooper w/ performance runflat tires ) [weight is 24.309828]
Style R84 (V-spoke) 6.5Jx16 - 1512350 & 1512351 = 8.0Kg Offset = 50mm
(Cooper S w/ all season runflat tires) [weight is 21.4338310lb]
Style R85 (S-lite) 7x17J - 1512352 & 6757859 = 11.4Kg Offset = 50mm
(Cooper S w/ performance runflat tires or all season runflat tires )
[weight is 30.5432092lb]
Style R86 5.5Jx15 - 6755809 = 6.8Kg Offset = 45mm
(Accessory wheel) [weight is 18.2187564lb]
Style R87 5.5Jx16 - 6755814 = 7.5Kg Offset = 45mm
(Accessory wheel) [weight is 20.0942166lb]
Style R88 6.5Jx16 - 6755811 = 8.9Kg Offset = 48mm
(Accessory wheel) [weight is 23.8451370lb]
Style R90 7Jx17 Two-Piece - 6755813 = 10.95Kg Offset = 48mm
(Accessory wheel) [weight is 29.3375562lb]
Old Apr 22, 2005 | 07:22 AM
Ryephile's Avatar
Ryephile
The Web-spoke is NOT the R90, it is R98, quoted on MINI2 as 22.3 lbs.
Yes a little chunky on the weight, but it's on-par with the rest of MINI's OEM 17's.
Old Apr 22, 2005 | 08:45 AM
eVal's Avatar
eVal
Yeah, 22 lbs is not light, but I've been looking into aftermarket wheels for awhile now and find that many, esp mulitpiece like the webspokes, are in the same range. Even some (not all before people start quoting the light ones) expensive 17" wheels, Volks, etc, are not as light as you'd think for the $$ - around 18/19 lbs per wheel, and it can be heavier on the less expensive/not as well made cast wheels. So far I'm not in love with the open designs of the super light/stronger wheels and alternately don't want to pay a huge sum for the forged ones I like :P
Something else I've found is that wheel sites are not neccessarily accurate with the weights they quote. I've seen a weight listed on a wheel site then find the manufacturer has it as something else
Old Apr 22, 2005 | 08:13 PM
morknmini's Avatar
morknmini
That's right about wheel sites misquoting weights. If I ran a big wheel shop I would have someone weigh the wheels and note them in the web site.
I had a hard time ascertaining the weight of the 7x16 Panasport. I finally found a site that quoted just over 22 pounds. So I nixed that brand. But recently I found a site that claims the 7x16 Panasport weighs 16.9 pounds.
But I have also seen variations in the length of the MINI. Is it 139.5" long or is it 143.5" long? Do bumper or spoiler variants make that much of a difference? Inquiring minds remain unelucidated.
Old Apr 23, 2005 | 09:58 AM
Alex@tirerack's Avatar
Alex@tirerack
Precisley why we weigh each application.
Alex
freeman727
Mar 31, 2016 03:00 PM
vulkandino
Oct 31, 2015 08:29 PM
GVFlyer
R61 :: Paceman Talk
Oct 21, 2015 06:48 AM
chowpott
Oct 19, 2015 08:37 AM
dutchhome
Sep 30, 2015 07:17 AM
