Such things as Runflat rims?
Old Jun 3, 2005 | 03:44 PM
boognish's Avatar
boognish
I own a 2003 MINI Cooper with 16" OEM rims and the Dunlop runflats. My question is: Can I take off the 16" runflat tires, and fit standard (non-runflat) 16" tires on the rims? I'm asking because I don't know if runflat rims are different than standard rims and if they only "work" with runflat tires.
Thanks,
-Boognish
Old Jun 3, 2005 | 03:48 PM
minimort's Avatar
minimort
You're good with other rims, it's just the tires that are runflats
Old Jun 3, 2005 | 03:50 PM
dominicminicoopers's Avatar
dominicminicoopers
Thanks,
-Boognish
There are some run-flat tire "systems" that require a special wheel. The MINI does not use one of these systems. You'll be OK with installing new skins onto the stock rims.
Old Jun 5, 2005 | 04:19 PM
JCW Driver's Avatar
JCW Driver
There's always Michelin's "tweel". redefining runflats...
Old Jun 10, 2005 | 10:07 AM
mrdirosa's Avatar
mrdirosa
Yup - just did this with my 16's...the runflats were horrible, replaced with 205/50/16 Pirelli All seasons and the ride is much smoother and more comfortable than the harsh runflats. The handling is still though
Old Jun 10, 2005 | 10:40 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Considerably more comfortable than conventional runflats and no air needed.
http://www.michelinman.com/differenc...01102005a.html
(Like mini independent suspension built into each tire).
For racing that means you cannot adjust tire pressures to alter handling!
Awh, that's no fun.
tacticalbacon02
NEO Miniacs (Mini NEO)
Oct 4, 2019 07:18 PM
schwac2
Jun 14, 2016 04:06 PM
Sep 4, 2015 03:56 PM
Ladybug-S
Sep 1, 2015 07:07 PM
