View Full Version : F54 :: Clubman Talk (2015+)
- F54 Exhaust Question
- F54 Clubman S All4 6MT Fluids
- F54 Retrofit TJA to F54 Clubman
- F54 Upper Motor Mount - Failed 14k Miles and 2 years later
- F54 Thule Bare Roof Rack
- F54 Front Turn Signal
- F54 Bimmerlink to disable fake engine noise
- F54 6th gear stopped working
- F54 Driving with a Broken Upper Engine Mount?
- F54 F54 Clubman Suspension Upgrade Questions
- F54 FailedUpper/Lower Engine mounts after 16k miles
- F54 Rear Sway Bars: WMW vs NM
- F54 Codes after downpipe install
- F54 Power steering feel adjustment?
- F54 Rare 6MT 2022 Clubman S
- F54 Front grille Trim
- F54 Esys coding
- F54 F54 all4 sports cat
- F54 F54 Front Springs/Struts
- F54 Clubman Questions!
- F54 Water under the rear seat and footwell
- F54 Factory repair manual / BMW TIS
- F54 F54 cargo length
- F54 2020 F54 JCW Clubman Suspension
- F54 Cool rubber ducks wearing hats
- JCW F56 JCW AWD Clutch Dump
- F54 F54 2020 Clubman S - Manually Close Sunroof
- F54 F54 Clubman S- Transmission Fluid Type
- F54 2020 F54 All4 high pitch whistle noise??
- F54 Passenger Side Front Rattle
- F54 Keyfob and cargo doors
- F54 19 inch wheels
- F54 Electrical project - stop light relocated
- F54 First mod install not going well...
- F54 F54 JCW Tyre Pressure Placard
- F54 Sport Mode effects explained by ChatGPT
- F54 F54 LCI Front Brake Pad Question
- F54 Jacking F54 JCW for stands
- F54 Batch of bad tire valves from the dealer ??
- F54 Clubman S with JCW tune kit compatibility with Dinan
- F54 2018 Clubman S loud AC blower motor
- F54 Seat lowering options?
- F54 2018 Clubman blower fan random speed
- F54 New to me 2019 Clubman S All4 Manual 6
- F54 2020 Clubman Blower motor
- F54 Front Wheel Arch Headlight Access Cover
- F54 All4 Emblem placement
- F54 Coolant Leak
- F54 Clubby Mods
- F54 Digital dash retrofit RPM gauge not working
- F54 Fuel Injector Replacement
- F54 Powerflex Upper Engine Mount
- F54 Hitch options.
- F54 Ur Mileage on stock brakes?
- F54 Need Help, Coilovers and DDC. What are my options?
- F54 Reverse Camera Issue
- F54 Knocking wheel steering low speed
- F54 oil change - without filter change
- F54 16" wheels on an f54 Clubman?
- F54 Whining noise during acceleration
- F54 WTB: JCW Circuit Spoke 592
- F54 R55 vs F54 Clubman ownership
- F54 Anyone buy from "new generations cooper" online?
- F54 2023 intercooler install
- F54 No Heat and Possible Coolant Leak
- F54 Can't reset, and can't measure oil level (2017 Clubman JCW)
- F54 Clubman Center Console Disassembly
- F54 New to me BRG F54 S 4All
- F54 Digital cluster upgrade
- F54 clutch noise
- F54 JCW clone cup spoke wheels on a JCW - spacers needed
- F54 It showed up - my '17 JCW Clubman
- F54 245/40R18 tires on JCW 8"x18 wheels
- F54 With huge anxiety, I introduce myself to the F54 part of NAM!
- F54 Pre-LCI tail lights - swapping the brake and turn signal positions
- F54 retrofit LCI front fog lights
- F54 F54 Battery replacement
- F54 Barn doors will not open
- F54 F54 2020 MINI Clubman JCW All4 Right Engine Mount Replacement
- F54 First Post - Anyone know about those bumper covers?
- F54 HUD Not Working/Stuck
- F54 stuck right barn door -- F54 2016 Clubman S
- F54 New Clubman Owner
- F54 Manual transmission mount bolt torque
- F54 LCI UJ tail light retrofit help!
- F54 JCW Pro exhaust rattles with valves closed
- F54 Rear view camera failure
- F54 Flat towing behind a motor home
- F54 JCW Steering Wheel
- F54 Another JCW Brake Swap Question
- F54 Electronic handbrake not disengaging and auto gearbox issue
- F54 Uppler Engine Mount Repair and Upgrade
- F54 Battery Warnings?
- F54 Halogen to LED conversion
- F54 2017 S ALL4 engine pulse
- F54 Help removing 2020 b48 ecu?
- F54 Passenger Side Rear CV Axle Replacement
- F54 Clubman transmission question
- F54 What are these cut outs?
- F54 hole in oil pan, where to go from here?
- F54 spendy suspension upgrades got me down...
- F54 😖 clutch release bearing.makomg noise.
- F54 Rear Split Door Handle Replacement?
- F54 2024 JCW suspension issue - low wife approval
- F54 Wet footwell continues after clearing sunroof drains
- F54 New 2014 JCW Untold Edition
- F54 Aftermarket option for VDC?
- F54 Electronics help (wipers and heated seats)
- F54 Scrolling presets with steering wheel controls?
- F54 Strut Bar/Brace Fitment
- F54 retrofitting 40/20/40 seats
- F54 All4 oil pan removal difficulty?
- F54 Clubman Final Edition, finally here
- F54 FMIC for 2023 S All4
- F54 Transmission Mount Bolt Torque Specs
- F54 android audio for 2017 clubman
- F54 Importing a US-spec F54 Cooper into the EU
- F54 "Breeders" Cameo
- F54 Cylinder Head Temperature Sensor Replacement
- F54 Brake pad service notification
- F54 Just got my 10th Mini since 02. This time a 22 Clubman
- F54 Panoramic Sunroof Water Leak
- F54 '17 S All4 Nicknamed VeeVee
- F54 2019 Clubman panaromic sunroof won't close
- F54 What is the widest tires I can fit on 2020 Clubman S All4?
- F54 basic throttle response controller
- F54 Mini Clubman F54 Trunk Speaker Posibilities
- F54 Oil pressure & temp f54
- F54 New 2017 F54 owner
- F54 Need help with filling coolant, how to initiate bleeding procedure?
- F54 (F54 Facelift) Speedo error
- F54 ALL4 vs FWD
- F54 Looking at 2020 JCW, CarPlay upgrade?
- F54 LCI Clubman JCW Winter Wheels - pics
- F54 2016 MINI Clubman Mod question
- F54 Clubman sport suspension
- F54 Fuel filter location and part?
- F54 Comfort access kick open feature not working
- F54 Warranty Question
- F54 Windshield Washer Odyssey
- F54 Clubman Tires
- F54 2019 Clubman Cooper S no ASD
- F54 Clubman Final Addition
- F54 Rear suspension bolts
- F54 Anyone have 2024 Product Guide Build Sheet?
- F54 PSA: Check for mice!
- F54 All4, Transfer case, Hang on Clutch and Rear Differential Fluid Replacement.
- F54 Code values for ASD on 2020 JCW
- F54 2019 Clubman All4 rear bumper brake light
- F54 Pre-LCI Tuning kit lost its pops and bangs
- F54 Official: End of the Clubman
- F54 BMW Mini F54 TJA (Traffic Jam assistant) 5AR
- F54 P11C4 Unknown Code (also P0171, P0440, P0446)
- F54 Cargo space trim remaoval
- F54 RoadTop Carplay install
- F54 Retrofit Mini Clubman F54 LCI 2020 electric folding wing mirrors
- F54 What's making the fuse burn out?
- F54 heated seats too hot
- F54 F54 Upper Engine Mount busing replacement
- F54 Pinout for BDC module
- F54 MINI is retiring the Clubman
- F54 Selling my Clubman
- F54 After market LED headlight assemblies
- F54 Rear Fog coding issue / UJ turning on/off instead
- F54 Retrofit Roof Rails on F54 Clubman
- F54 All4 transfer case leak
- F54 Maps Navigation Update
- F54 SiriusXM
- F54 Shopping for new wheels
- F54 mud/rally flaps
- F54 Service schedule
- F54 JCW Rear Brake Piston Compression
- F54 Silver Roof on the configurator
- F54 What in God's name is this sound?
- F54 Help with Codes from BlueDriver OBD Scan
- F54 Removing rear roof spoiler
- F54 BM3 vs Evolve vs RPM tune for F54 JCW pre LCI
- F54 2020 MINI John Cooper Works Clubman ALL4 - I cannot find the part number for the rear
- F54 2019 JCW aftermarket tune options and expected increases in HP
- F54 Intercooler pros/cons
- F54 Good F54 Service/Scan Tool?
- F54 Rear Wiper Washer Failure
- F54 Normal Coolant Temperature
- F54 How much Mileage is to much when purchasing used?
- F54 Need help and advice, coolant system
- JCW F54 JCW All4 - Looking for more WHP
- F54 HELP!!! Blower Motor DIED!
- F54 Non Runflat Tire Pressure?
- F54 Windshield Top Gasket
- F54 2022 Clubman 1” Spaccer Lift
- F54 Left brake lamp malfunction
- F54 Front tower bar/strut bar for F54?
- F54 Help please , DRL/TFL bimmercode
- F54 ignition up grades for my f54
- F54 Recommendation for windshield replacement in MA
- F54 8-Speed Automatic Gearbox Problem
- F54 '17 Clubman S All 4 headlight/drl/foglight upgrade
- F54 DIY Brake pad replacement, service reset question
- JCW F54 JCW Clubman suspension options in 2022
- F54 Boost testing
- F54 front sway bar comparison
- F54 Replacing gas springs barn doors
- F54 Automatic transmission fluid replacement
- F54 Is there a way to desactivate the all4 system
- F54 2023 Clubman configurator
- F54 F54S brake pads?
- F54 Exhaust pops less on 2022 vs 2018? Why?
- F54 Has anyone fit 19” wheels with dynamic dampers?
- F54 Can I use 245/45R18 OEM tires/wheels on '17 Clubman S that has currently has 245/45R1
- F54 F54 JCW Wheel Query
- F54 MY22 Software / Infotainment Update
- F54 Add Additional Key
- F54 chip shortage means missing options?
- F54 Can I use OEM '18 Countryman S 19" wheels on '17 Clubman S that has currently has 17"
- F54 Newb intro
- F54 Service manual and poor dealer service
- F54 Can i See photos Mini F54 with 19 inch wheels.
- F54 JCW Clubman lowering springs
- F54 Brake lights
- F54 Coolant leak
- F54 NM power module vs JB+
- F54 Ordering a JCW Clubman
- F54 Dynamic turn signals (union jack)
- F54 Manual gearbox oil leak.
- F54 New to me 2017 Camera Add/Nav
- F54 Engine mount bushing inserts
- F54 Manual trans pops out of 2nd gear
- F54 Harman/Kardon Availability
- F54 2022 Clubman JCW Dynamic Damper Control vs JCW
- F54 2022 Clubman JCW on the way - What mods?!
- F54 Air Vent remove
- F54 Red car warning light in lower digital display instrument panel
- F54 F54 8 Speed Automatic (S FWD)
- F54 Headlight spiderweb cracks
- F54 Dead Battery - 2017 F54
- F54 Lower brake lights - LED alternative?
- F54 Throttle is somehow making car pull left and right
- F54 Track mods F54 S
- F54 Enthusiast Built MINI Clubman - ECS Tuning
- F54 F54 OEM Roof rack placement
- F54 Mini Clubman Barn Doors Stuck closed
- F54 mini clubman build 10-2017
- F54 LCI Grill on Pre-LCI ONE / Cooper
- F54 Would this steering wheel fit?
- F54 ALL4 Differential Bushing Upgrade
- F54 Spare parts
- F54 Seat Removal
