F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Knocking wheel steering low speed
Old Apr 2, 2025 | 06:38 PM
Ian156's Avatar
Ian156
Hello All,
2022 F54 JCW 54,000 km. No mods.
Been looking all for discussions of knocking/ clunking wheel steering at low speeds and can’t seem to find anything. Can anyone point me in the right direction?
Last couple of weeks, manoeuvring at low speeds whilst parking, I’ve noticed a knocking feeling both left and right. What would feel similar to maybe a lack of fluid in a hydraulic steering system.
Any clues?
Old Apr 3, 2025 | 02:19 AM
THE ITCH's Avatar
THE ITCH
Check the torque on your wheel lug nuts.
Old Apr 5, 2025 | 05:08 PM
SubKompactKing's Avatar
SubKompactKing
I might be having the same issue on my 2018 S. (41,000 miles) Only at very low speeds like parking or making a right or left hand turn at an intersection does it "knock" Other than that it acts and feels fine. I've been thinking it's the tie rod ends. I haven't had time to jack the car up and test that but it seems to make sense.
Old Apr 9, 2025 | 08:57 AM
Maybe a motor mount, these mounts are known to go bad and make sounds? Maybe the fwd to reverse is making the mount move a bit to hit?
https://www.northamericanmotoring.co...ion-mount.html
https://www.northamericanmotoring.co...placement.html
Old Apr 10, 2025 | 03:33 PM
Ian156's Avatar
Ian156
**Update***
I torqued all the nuts to 140Nm and still feel a light clunking at parking speeds on a flat surface when moving left and right. Feel light knocking through the steering wheel and it may be worse when reaching the limit of turning the wheel either way.
I had visually inspected the upper engine mount and don’t see any significant wear. The knocking is even more obvious when stationary. No knocking is apparent at speed when the steering wheel isn’t being moved to its maximum turns.
It’s 2022 JCW with 19inch wheels and only 33k miles /54k km.
Anyone with any other ideas? Would be greatly appreciated.
Old Apr 23, 2025 | 06:31 PM
Ian156's Avatar
Ian156
Update 2
Found a probable cause.
We have a short dusty road to reach the house. As the snow and ice melted, the dust turned to a wet paste. That paste appears to have caked itself in the bearing at the upper strut mount area.
Went to have my summer tyres mounted today and when they lifted the car, the powder dropped from the top of the suspension.
No more knocking feeling. This also explains the timing and the fact that it was intermittent.
Old Apr 24, 2025 | 10:49 AM
Thanks for the update.
Regis7136
Feb 10, 2021 11:19 AM
TG.
May 23, 2020 02:33 PM
joshp912
Nov 8, 2012 12:01 PM
bsures
May 29, 2012 03:34 PM
inioway
Mar 6, 2004 04:25 PM
