F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
JCW F54 JCW Clubman suspension options in 2022
Old Apr 12, 2022 | 09:34 PM
fjork_duf's Avatar
fjork_duf
Hey people. I have a 2020 JCW Clubman. It has the fixed JCW suspension. I love the power of this car and most things but the handling hasn’t really met my expectations.
For context I had a 2007 Cooper S I loved. The car handled well. Turned in with immediacy and was just fun to chuck around. I understand the Clubman has a lot more mass to deal with so that’s a challenge.
Im wondering what suspension packages are out there. I am searching for that mythical goldilocks suspension. For those of you have driven modern porsches GT4 etc - Im thinking that kind of suspension. Compliant but still sporty.
Id like something daily-able but gets rid of that body roll / harshness you of the stock set up.
Maybe that doesn’t exist? Who knows. But I thought I would try.
Old Apr 13, 2022 | 04:00 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If Bilstein had an option, I’d go with that, but it doesn’t appear to exist yet. So, alternately I’d be tempted to go the KW route:
https://www.ecstuning.com/Mini-2020-...ion/Coilovers/
Old Apr 16, 2022 | 08:17 AM
BendersMINI's Avatar
BendersMINI
You have probably already thought of and considered these suggestions, but I'd start with the following before looking for the goldilocks shocks/springs or coilovers:
Originally Posted by fjork_duf
...but gets rid of that body roll
==> rear (anti)-sway bar. NM, VIP, etc
but gets rid of that ... harshness
==> what tires are you using? If you are still on run-flats and would consider non-run-flats, then I suggest starting there. Latest gen run-flats are WAY better than they used to be, IMHO, but still aren't as comfy as the non-RF.
Old Apr 17, 2022 | 02:05 PM
TVPostSound's Avatar
TVPostSound
Start with a set of Michelin Pilot Sport 4S and a rear sway bar.
VIP makes a 23mm rear sway. Compared to NMs 22 and 25mm. Its a good middle ground.
22 you might want more, 25 might be too aggressive unless you match it with a 27mm front bar.
But a Clubman is a little heavier the NM engineering 25mm might be right.
http://www.vipcustomparts.com/F54%20parts%20page.html
Old Apr 17, 2022 | 02:33 PM
AutoCoarsen's Avatar
AutoCoarsen
I’d start with the NM Engineering 25mm rear sway bar, Powerflex front control arm bushings and non-RFT tires. I have those plus AST springs and Bilstein B8s.
If I had to do it again I’d have skipped the springs and Bilsteins. The other 3 mods actually made the biggest positive difference for me.
Old Apr 20, 2022 | 11:14 AM
gearhead60's Avatar
gearhead60
From: Manassas, VA where the Civil War resides.....
I did the NM Eng. 25mm GT rear SB & End Links, Chassis Bones Braces, and run the Michelins 4S. Car handles great. Not a track car, but can corner very well. Don't have the power of the JCW (yet), but will soon.
Old Apr 24, 2022 | 10:12 AM
CPWillys's Avatar
CPWillys
I had Lowering Springs on my 2020 JCW with a Whiteline Front Sway Bar and an NM Rear Sway Bar. The Harshness wasn't changed from stock but the body roll was greatly reduced and the turn in felt perfect. I would recommend Sway bars and finding a set of comfort struts or coil overs to improve the harshness of bumps and road joints.
Old Apr 24, 2022 | 12:09 PM
EmedpaDHSc's Avatar
EmedpaDHSc
I really liked the change from the chassis bones over the stock brace as well. Still don't have a rear sway bar because I haven't been able to find an affordable (installed) option for less than $800 or so.
Old Apr 24, 2022 | 03:08 PM
TVPostSound
Worst case scenario, labor is 2 hours, <$400. bar is $250 for a VIP
Are they gouging up there?
Old Apr 24, 2022 | 04:28 PM
EmedpaDHSc's Avatar
EmedpaDHSc
I was looking at the NM bar + end links + labor around $800 at an independent mini shop, more at the mini dealer. Will look at the VIP bar.
Diablo243
Apr 9, 2017 08:54 AM
CharlesB.
Mar 16, 2017 04:00 PM
MiniMaestro
R55 :: Clubman Talk (2008+)
Jun 11, 2014 02:55 PM
kingbc
Factory JCW Talk (2009+)
Sep 6, 2008 10:57 AM
ahendy
Aug 25, 2008 03:03 PM
