F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Brake pad service notification
Old Sep 25, 2023 | 10:04 AM
Seems's Avatar
Seems
I received my brake pad service notification and had them replaced outside the dealership. How do I reset the service notification on the console? The threads I've seen all seem to pertain to the warning on the odometer, but I'm referring to the message, not the service light.
Thanks!
Old Sep 28, 2023 | 08:59 AM
gearhead60's Avatar
gearhead60
From: Manassas, VA where the Civil War resides.....
Assuming the sensor was replaced with the brake pads, by going through the reset with the odometer successfully, it should clear any other warnings.
Old Oct 1, 2023 | 06:07 PM
MotoringMiniac's Avatar
MotoringMiniac
I got this somewhere on a forum, had it in my notes. Figured I would share it here as well.
How to reset service checks, brake pads, etc.:
Make sure the parking brake is off
Press start button to first stage of ignition (do not start engine)
Wait for red brake sensor warning to disappear
Press odometer and hold (about 15 - 20 seconds)
Should see the reset menu
Now just press and hold
Then press and hold again to reset.
If it doesn't work then reset the odometer to zero and try again.
Old Oct 8, 2023 | 10:00 AM
Seems's Avatar
Seems
Thank you both - this worked after a couple of attempts. Initially I was getting some sort of test menu that I did not want to mess with, but once I was able to start the first stage of ignition with the "brake" warning in the odometer I was able to access the reset option.
Lifecycles
Oct 25, 2013 07:40 AM
Garconis
Jul 21, 2012 09:53 PM
miniclubman
R55 :: Clubman Talk (2008+)
Mar 28, 2008 10:58 PM
corrupt52
DC Metro MINIs (Archive)
11
Sep 5, 2007 06:00 AM
