F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Passenger Side Front Rattle
Old Oct 5, 2025 | 09:53 AM
pocketmaster's Avatar
pocketmaster
If i pull the base of the CV Axle (the part closest the transmission) towards the wheel and push toards the transmission it rattles and moves roughly a 32/100 of that. Up and down and side to side very minimal. Is this normal?
Old Oct 7, 2025 | 12:51 PM
WhatV8's Avatar
WhatV8
Yes, CV joints do have some axial play to them (i.e.- in/out), but it should be limited. The CV shaft is fixed on the hub/wheel end and 'floats' in the transmission. If your number of 32/100 (0.320") is correct, you may have a worn/damaged CV, but I don't know what our CV specs actually are so you may need to do some more research. Your rattle is likely something else in the front suspension, check your ball joint and sway bar link, as I feel they are the most likely culprits. It could be your lower a-arm bushings or possibly your hub bearing. Good luck and let us know what you find.
Zagnutbar
Jan 1, 2022 08:16 PM
wojtek@pagacz.ca
Aug 27, 2018 12:16 PM
TheZlog
R59 :: Roadster Talk (2012+)
Mar 6, 2013 02:04 PM
jmdor
R60/R61 Stock Problems/Issues
Jul 28, 2011 05:30 AM
pepperwhitemcs
Oct 15, 2008 06:25 PM
