F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 front sway bar comparison
Old Apr 5, 2022 | 01:25 PM
EmedpaDHSc's Avatar
EmedpaDHSc
Rear sway bar comparison
https://whitelineperformance.com/col...ar-vehicle-kit
vs:
https://new.minimania.com/part/G3NMS...m-Gen3-F56-F55
24 mm vs 25 mm. twice the cost for the NM. Thoughts?
Old Apr 6, 2022 | 03:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
In my opinion, NM stuff is overpriced. Also, a 22mm solid bar should be roughly the same stiffness as a hollow 25mm bar. Not sure what NM is smoking saying the 25mm hollow bar is twice as stiff…
I would have no issue running the Whiteline REAR bar you have linked. Looks like you’re still on stock suspension, too. The rear bar will be a nice addition.
Old Apr 6, 2022 | 08:20 AM
TVPostSound's Avatar
TVPostSound
You mean REAR??
I would go for the VIP 23mm solid bar, that was my gateway drug!!
http://www.vipcustomparts.com/F54%20parts%20page.html
Old Apr 6, 2022 | 08:49 PM
EmedpaDHSc's Avatar
EmedpaDHSc
Originally Posted by TVPostSound
You mean REAR??
Yes, rear (I fixed it). Thanks!
Old Sep 8, 2023 | 09:59 AM
EmedpaDHSc's Avatar
EmedpaDHSc
A few years later, I think I am ready to take the plunge on a rear sway bar. Looking at the VIP https://www.vipcustomparts.com/F54%20parts%20page.html with the NM end links.
That combo is $400, then $350 or so for install.
Old Nov 15, 2023 | 03:33 PM
paulsminis's Avatar
paulsminis
Plan to install a rear bar on my 2020 F54 JCW All-4. I have installed the NM rear bar on a couple of previously own F54S models all front wheel drive versions. I would imagine installation could be a bit more complex in an All4 Car. Any inputs from others? Thanks
Old Dec 1, 2023 | 11:54 AM
gearhead60's Avatar
gearhead60
From: Manassas, VA where the Civil War resides.....
It's not a difficult job, but time consuming. You do have to drop the rear subframe to get enough room. See my install here.
Old Dec 1, 2023 | 12:53 PM
paulsminis's Avatar
paulsminis
Thank you very much, Gearhead60! From your excellent install post it doesn’t appear any more difficult than any I have done on several previous installs on front wheel drive Clubmen.
Thanks for the help, I’m not a young one any more!
Old Dec 2, 2024 | 07:52 AM
johnnys2quick's Avatar
johnnys2quick
As I remember you should remove the rear cross brace that runs across the exhaust pipe tunnel. This will allow additional clearance as you lower the rear sub frame. It is easy to remove just four small fasteners.
jetmechinnc
Jul 29, 2024 08:53 AM
DAVIDLEERAD
Nov 30, 2017 09:34 PM
ZeroGravity
Nov 13, 2015 05:08 AM
Twin2turbo
26
Jun 5, 2015 09:03 PM
JimR56JCW
Suspension
30
Aug 6, 2012 04:46 AM
