F55/F56 NM GT sway bar 25mm
I wonder if the 25mm over the 22mm will make any performance difference?
Also wondering how important it is to buy the NM sway bar link kit?
With the GT bar and link kit I'm looking at $520. Will it really make a dramatic improvement in handling/under steer?
From NM,
" As you can see from one of factory parts, MINI cuts cost by equipping the new F55/56 with links made from plastic. As it may be sufficient for factory 17-18mm hollow bar it will not perform optimally when paired with our larger 22mm Solid Anti Sway Bar or 25mm bar. NM ALL METAL Sway Bar Links are far more superior by providing these following benefits:
-Replacement of factory weak plastic links
-Provide direct sway bar feedback
-Adjustable to 15mm shorter than factory length to accommodate extreme suspension drop
-Can compensate sway bar pre-load from poorly manufactured sway bars (uneven arms)
Yea, look at the difference.
Looking good! 👍
Looks good. Good double check with the marker for completed job.
Good practice.
I have a mild squeak from mine sometimes in the rain. I'm assuming I didn't grease it well enough. Is any old synthetic NLGI #2 grease (Red Line, Valvoline, RP, etc.) appropriate, or should something specific (Energy, Prothane, etc.) be used?
Well, seems like any old NGLI #2 is not OK for poly bushings and lithium based lubes samage them. Silicone/Teflon lubes seem to be most widely recommended, and the Prothane, Hotchkis, and Super Lube varieties all seem to be well liked.
Ordered some of this stuff:
https://www.amazon.com/gp/aw/d/B0042FG74W
--Matt
--Matt
You guys may also want to consider getting some rod end dust boots to help seal out dust/dirt/debris/water. When rod ends are exposed on a daily driver that sees a fair amount of wet weather, they can wear out more quickly than expected. Here are links to a couple options:
http://www.midwestcontrol.com/series.php?id=190
https://www.summitracing.com/search/...end-dust-boots
I actually asked Jerry @ NM about this and he indicated that they're not needed. I live in a place that gets snow, has salt, etc. so it was the first queation I had on them. They're apparently important on their control arms though.
--Matt
--Matt
NM rear Sway bar on my 2016 JCW. Clearly no a good paint job. Yes I drive on salted roads but this is the only part under the car that looks like this. I must admit I am disappointed in the quality.
