F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 F54 all4 sports cat
Old Dec 23, 2025 | 06:53 PM
Parqee's Avatar
Parqee
F54 all4 sports cat
Hey all, I’ve been upgrading my 2017 clubman s all4 and I’m ready to pull the trigger on a sports cat. For reference, the only other performance upgrade I’ve done is a Remus cat back exhaust.
Has anyone done this upgrade? Which one would you all recommend? I am looking for deeper sound along with added hp.
Also, is it true I will have to disconnect the front drivetrain to replace the cat? According to this product, it is recommended https://www.urotuning.com/products/evolution-racewerks-200-cel-catted-downpipe-bmw-mini-b46-x1-x2-mi-exh001tbcat#collapse-tab4
Old Dec 24, 2025 | 04:56 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Yes, with the All4 system and transfer case in the way, there is no easy way to get the down pipe out and in.
Check out this discussion:
https://www.northamericanmotoring.co...-all4-jcw.html
Old Dec 24, 2025 | 06:25 AM
Yep, they come with a welded one piece for most aftermarket. ER comes in catted and they have a clamp. ER Catlless (which we dont sell) comes welded from them.
https://www.ecstuning.com/b-evolutio...=1&facet_nav=1
Old Dec 24, 2025 | 11:15 AM
Parqee's Avatar
Parqee
so I will be able to install without lowering the subframe or disconnecting the drivetrain?
Old Dec 24, 2025 | 12:51 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
While the two piece down pipe will be easier to get into the car, you still have to deal with getting the OEM out of the car. With the All4 system in the way, I’ve not seen how to do the removal without removing something big or cutting the OEM pipe out. Either way, it’s not going to be a simple job.
Old Dec 24, 2025 | 01:37 PM
Parqee's Avatar
Parqee
I was planning to cut out the OEM pipe. So in this case, how hard is it to cut out?
Old Dec 25, 2025 | 05:59 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Not sure, but it is pretty tight down there….
I feel like if you’re going to do it, you’re going to have to be fully committed to the task. No turning back after you start cutting stuff.
coopdog7401
Apr 12, 2025 11:31 PM
Sugeray
Oct 17, 2016 08:25 PM
Csbdr
Jun 30, 2015 02:30 PM
mikey1991
Mar 4, 2012 11:45 PM
stinkytofu
Dec 21, 2009 09:18 AM
