View Full Version : F55/F56 :: Hatch Talk (2014+)
- F55/F56 Is It Usually This Noisy?
- F55/F56 ECS High Performance Air filter
- F55/F56 engine Air Filter .. prefilter yay or nay
- F55/F56 Black flag USA shift boot delete
- F55/F56 So how much do I add???
- R56 Backup Camera Trouble
- F55/F56 AC Compressor Replacement
- F55/F56 Front lower control arms repalcement
- F55/F56 Looking For Front Bumper COVER see pic
- F55/F56 Bonnet Stripe Removal Quick Question
- F55/F56 can 2108 OEM Union Jack tail lights be used in a stock 2015 F55?
- F55/F56 0w-30 availability ?
- F55/F56 2016 F56 Aisin Transmission Fluid?
- F55/F56 Long cranking
- F55/F56 Oil check
- F55/F56 Transmission Fluid Over Filled? Overflow question.
- F55/F56 Insane rev hang. Fixes?
- F55/F56 Is it possible to swap B48TU into a non TU car?
- F55/F56 Fuel filler door cover
- F55/F56 2017 Mini Cooper Hardtop S Tire Recommendation Please.
- F55/F56 JCW Tuning kit question
- F55/F56 2018 Cooper S alternator belt sheared off and water pump blown
- F55/F56 Bimmercode Coding
- F55/F56 Film on Door Windows
- F55/F56 Hood finishing
- F55/F56 Rear Hatch Spoiler
- F55/F56 luggage sill
- F55/F56 Where to stow tow hook?
- F55/F56 F56 Euro Taillight Replacement
- F55/F56 new guy, new car - sunroof and phone mount q's
- F55/F56 tow hook storage
- F55/F56 2018 Cooper S P13C9, P054B and P0015 Codes
- F55/F56 Is my clock spring getting angry?
- F55/F56 Question about installing JCW pro splitters
- F55/F56 Alternator won't come off
- F55/F56 E-SYS Read SVT issue
- F55/F56 How to get MINI USA to help with repair costs
- 2021 F60 Transmission performance problems
- F55/F56 CTS Turbo Downpipe? Thoughts?
- F55/F56 Rev9 Intercooler On Sale
- F55/F56 Rally Lamps for LCI2 (2022-2024)?
- F55/F56 Rear Splash Guards for F55 4-Door (hatchback)?
- F55/F56 Adjusting door fitment
- F55/F56 REMUS Cat-back Exhaust
- F55/F56 Can't fix EVAP problems in 2017 mini
- F54 LCI Headlight Retrofit on Pre-LCI LEDs
- F55/F56 Serpentine Belt Issues
- R56 Service transmission oil required
- F55/F56 center ring multcolor question
- F55/F56 F55 B38 JCW: Build Thread
- R55 N18 Turbo Valve cover replacement / Fuel Line
- F55/F56 Caliper Replacement Question
- F55/F56 Couple of headlight questions if you guys have any ad vice!
- F55/F56 Weekend at track ruined by a coolant hose
- F55/F56 Replace water pump 2014 Cooper S w/ 2L turbo
- GP3 JCW Pro Exhaust for GP3
- F55/F56 F67 Style Taillights Now Available
- F55/F56 This is one MINI quirk that I could live without
- F55/F56 Headlight Level Control - Looking for Info
- F55/F56 Ideal Suspension for F56 non-s / b38
- F55/F56 Right Rear Turn Signal stays on with key off
- F55/F56 Replacement for W8W boot light
- F55/F56 New F56 in the House!
- F55/F56 JCW transmission cooler on a Cooper S
- F55/F56 Loose hose in engine bay
- F55/F56 F56 AUC Sensor Location
- F55/F56 6 speed auto to 8 speed swap????
- F55/F56 Back to the MINI world... Any tips?
- F55/F56 F56 CV Joint Boot DIY Help
- F55/F56 Valve Body Removal Procedure
- F55/F56 Roof Rack Question
- F55/F56 Need link for wheel hub
- F55/F56 Looking for part number of the foam/sponge top cover for battery.
- F55/F56 Steering Wheel Rattle
- F55/F56 Drive train Check Soon
- F55/F56 Meth Injection
- F55/F56 Clutch replacement
- F55/F56 Does the rear spoiler disassemble?
- F55/F56 Can I add a backup camera to my F55? I have entrynav 2 head unit I beleive
- R56 Motor Mount Defect Not Covered
- F55/F56 VO Coding - How to remove 2VB ?
- F55/F56 Traction control off
- F55/F56 F55 Stutter on start-up
- F55/F56 Need Part number for a F56 Auto Trans Shift Linkage connector
- F55/F56 Air intake difference between 2014 and 2015
- F55/F56 Auto lock feature
- F55/F56 Third Brake Light Pulser Question
- F55/F56 Instrument Cluster Programming
- F55/F56 F55 1.5L P13C9 and P054B code
- F55/F56 Upper engine mount
- F55/F56 2015 Mini cooper Fuel Monitor for Smog
- JCW Lightweight seat with heat?
- F55/F56 Axle back muffler install
- F55/F56 Ram air snorkle ?
- F55/F56 Squealing metal ringing sound that goes away when depressing the clutch?
- F55/F56 Help with Rumble
- F55/F56 Lamp customization / coding - 8041C3 lamp mapping failed - fixed (finally)
- JCW 2023jcw pro exhaust wiring help
- F55/F56 Obd performance chips ?
- F55/F56 Front Windshield Sunshade Recommendation
- F55/F56 Rear seat delete ?
- F55/F56 B48 and b46 cross compatibility
- F55/F56 Windshield Wiper cowling ?
- R56 Help Verifying Factory Options & Build Sheet – 2009 Mini Cooper S (Manual, PepperWhit
- F55/F56 2015 F55 maintenance/reliability
- F55/F56 Please help me to upgrade my nav/infotainment screen
- F55/F56 Need UPD09041.bin
- F55/F56 Replacing oxygen sensor, need torque spec
- F55/F56 New owner: Oil filter housing, fuel tank vent valve, engine mounts, & auto trans
- F55/F56 100k Miles Preventative Maintenance Service
- F55/F56 Help Programming Digital Cluster
- F55/F56 Screen Upgrade for 2017 Mini Cooper F55. Im a bit confused, help a noob pls?
- F55/F56 Missing rubber cap in trunk. What's the name?
- F55/F56 Installed Powerflex Bushings for F56 JCW Upper, Lower Engine Mount & Trans Mount
- F55/F56 Cannot Install Passenger Side Axle - Auto F56 JCW
- F55/F56 Vanity Light Vent Question
- F55/F56 Brake air duct cover removal ?
- F55/F56 window noise
- F55/F56 F56 Front Control Arm DIY
- F55/F56 Ebay Grill
- F55/F56 Trying to find a local tuner (Jax FL)
- F55/F56 Cabin air filter, I think I messed up
- R56 2019 JCW Instrument Cluster
- F57 Enthusiast seeking floaters?
- F55/F56 Full screen CarPlay in LCI1 car with the big display
- F55/F56 Spotty AC Performance Question
- F55/F56 coding AUX and Android Auto retrofit question
- R58 F56 steering wheel nut and column torque
- F55/F56 Center armrest removal - Is there a cover?
- F55/F56 First Oil change
- F55/F56 What is this clamp? Help!
- F55/F56 Amount of oil after oil/filter change. 2.0l S
- F55/F56 2016 MINI Cooper S F56 – Low Beams Stay On w/ Ignition Off, High Beams Non-Functional
- F55/F56 Bimmer Utility
- F55/F56 Cargo cover rattling
- F55/F56 Front Creaking Over Bump
- F55/F56 Long dead, brought back. Lots of issues. Need guidance
- F55/F56 Full Size Spare In F56
- F55/F56 Anyone know if rear pro splitters fit MCS?
- R55 Misfire... At a loss
- R61 F66 Center Console Storage
- F55/F56 Replace rear sway bar bushings?
- F55/F56 Champion (frenh #s?) Sp. plugs
- F55/F56 What to maintain/change to keep forever?- 2016
- F55/F56 NGK spark plugs
- F55/F56 Bimmerlink or BimmerUtility to "Reset transmission oil wear values" for DCT MCS?
- F55/F56 Looking for help
- F55/F56 Secret compartment on LCI 2
- F55/F56 Drivetrain Error F55 2016 S
- F55/F56 Underbody Braces
- F55/F56 Spark Plugs
- F55/F56 2015 F56 S - 100K Service Suggestions
- F55/F56 Wiring Identification Help
- F55/F56 Anybody fix a broken connector before??
- F55/F56 BimmerUtility - how to register new battery with BU?
- F55/F56 F-series have a Diagnostic Mode?
- F55/F56 Upstream O2 sensor videos?
- F55/F56 Trouble removing oil filter housing
- F55/F56 High Flow Downpipe
- F55/F56 Racing Dynamics and Emnotek.com Buyer beware!
- F55/F56 Growling sound coming from right side
- F55/F56 Install 2025 side mirrors on a Gen 3 Mini?
- F55/F56 rear fender wheel arch light
- F55/F56 Racing Dynamics downpipe doesn't fit
- F55/F56 Fuse box 103 & 104 location
- F55/F56 who to choose for ECU remap?
- F55/F56 Top up oil?
- F55/F56 Help fitting non-OEM reversing camera
- F55/F56 New Union Jack taillights installed
- R56 Walnut blast adapter, pay shipping.
- R56 Will a shift knob made for an F56 fit an R56?
- F55/F56 Using 12V cigarette outlet causing Passenger SRS warning
- F55/F56 Quote for replacing struts and front LCAs
- F55/F56 Need help with coding side lights/parking lights please
- F55/F56 Front crankshaft seal replacement
- F55/F56 Need help with reprogramming/replacing modules in 2016 JCW.
- F55/F56 Code Headlight Switch 9301808 for US Spec F56
- F55/F56 New VLAND (ZIZA) LED Headlight Retrofit for F55/56
- F55/F56 First post & question about suspension
- F55/F56 Where do you keep your glasses?
- F55/F56 Coolant Confusion Misinformation?
- F55/F56 Any Techs on here - Replaced OFH, now getting 9 codes!!
- F55/F56 "pretty" cover
- F55/F56 Coolant Flush Question: 2014 MCS B46 have 2-circuit cooling system?
- F55/F56 Bolt Torque specs for B46 intake manifold??
- R56 Looking for a shift knob like the r53 JCW
- F55/F56 F56 MCS B46 Coolant Change - how the heck do you drain???
- F55/F56 Who uses car covers ?
- F55/F56 B46 b46c difference
- F56 door lock switch
- F55/F56 Roof railing retrofit?
- F55/F56 F56 Solo Camper Conversion (2 weeks / 5500 miles) [Photo Heavy]
- F55/F56 Intercooler
- F55/F56 Powerflex motor mount insert failure
- F55/F56 2014 F56 Cooper S Hardtop DME update
- F55/F56 Switched hot in the mirror housing?
- F55/F56 Why does my Mini engine smell like a bakery suddenly?
- R56 Rally F-56?
- F55/F56 Warranty Extension (MINI USA): Evaporative Emission Control (EVAP) Purge Valve
- F55/F56 constant hissing noise from AC
- F55/F56 Looks like we are getting NEW OEM Taillight design!
- F55/F56 Floating Center Caps - any good?
- F55/F56 JCW Pro Exhaust issue - help
- F55/F56 Aftermarket wheel fit — will this require modification or additions to work?
- F55/F56 Is the 3rd Gen Mini's just cold blooded.
- F55/F56 Retrofitting ID6 into a F56 - question on parts
- F55/F56 Should the Oil Filter Housing on the F56 be Replaced Preventatively?
- F55/F56 What is the best piggy back?
- F55/F56 RealOEM for latest models
- F55/F56 DME unlocking for 2020+
- F55/F56 Mini #4 (green this time)
- JCW Has ANYONE actually WORKED OF THEIR 2 LITER MOTOR 2 INCEWASE POWER???
- F55/F56 Steering Wheel - Union Jack Lower Trim
- F55/F56 DRL stopped working in one headlight
- F55/F56 Dyin' Batt.
- F55/F56 Brake Pads
- F55/F56 Recommended Oil for High Temp Climate? - South Texas
- R56 Speaking coming from front suspension F56 JCW
- F55/F56 Failing battery cause head unit issues?
- F55/F56 Remus Exhaust Questions
- F55/F56 Emissions warning light
- F55/F56 Extended warrranty for common "Secure Vehicle Against Rolling" letter from MINI USA
- F55/F56 Who wants a Paddy Hopkirk
- F55/F56 Is stu-mon invisible ?
- F55/F56 Romondes chg.
- F55/F56 Oil Chaneg Specs
- JCW Is Rebel green on a F56JCW metallic?
- F55/F56 Where is this leaking from?
- F55/F56 Changing upper motor mount, change transmission mount too?
- F55/F56 Increasing Adaptive Cruise Control Resume Timeout
- F55/F56 thievin' Mini store
- F55/F56 AC Compressor change Procedure
- F55/F56 weird'n out
- F55/F56 Tire Rubbing Solution
- F55/F56 BimmerCode/ESys and the Condition Based Service (CBS) System
- F55/F56 Rear Trailing Arm Removal 2016 S Hardtop
- F55/F56 New (to me) 2021 Paddy Hopkirk Cooper S
- F55/F56 yellow tire icon/yellow sar icon
- F55/F56 DSP Amplifier recommendations?
- F55/F56 F56 no turn signal sounds
- F55/F56 Auto cross this Sunday!
- F55/F56 added up cost of aftermarket parts
- F55/F56 Upgrade front sway bar?
- F55/F56 Low speed downshift clunk
- F55/F56 Caliper piston rebuild help
- F55/F56 batt. quandary
- F55/F56 What specs should I look for in a USB thumb drive for my 2022
- F55/F56 ECS tow hook shoulder bolt size?
