F55/F56 Squealing metal ringing sound that goes away when depressing the clutch?
Old Aug 12, 2025 | 08:15 AM
therealijw's Avatar
therealijw
2017 S Hatch - 6spd
Squealing metal ringing sound that goes away when depressing the clutch.
Car drives great and shifts with no issue. It currently has about 46k on the clock and I bought it when it had 38k. I've lived with the noise but I figure I should probably stop ignoring it and get to fixing it.
Has anyone else had a similar sound or issue?
I'm very mechanically inclined so I may try and replace the clutch and throw-out bearing to see if it helps. I would be sad if that did not fix the noise as it would mean something more serious is going on.. hopefully not.
I'd love anyone's advice on the matter.
Old Aug 12, 2025 | 10:20 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Typically, a squealing bearing noise that goes away when you press the clutch pedal would tell me the throw out bearing. Does it make the noise while idling in neutral? Maybe a mechanics stethoscope could help you find the source before pulling the gearbox.
Clubman Kirill
Apr 23, 2025 02:59 PM
gbrides
Dec 17, 2021 05:55 AM
Louis Demers
May 3, 2019 11:02 AM
Hochspannung
Jul 25, 2013 11:59 AM
MarioKart
May 6, 2007 12:39 AM
