PDA
View Full Version : F55/F56 :: Hatch Talk (2014+)
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21
  1. F55/F56 R53 guy with questions about Gen 3
  2. F55/F56 iJDM LED Sidemarkers
  3. F55/F56 Mini died
  4. F55/F56 Mini died
  5. F55/F56 Headlights w/DRL and High Beams
  6. F55/F56 Upgrade F56 S with JCW donor?
  7. R56 Rear Trunk Covering
  8. F55/F56 What is involved in calibrating a new windshield
  9. F55/F56 2021 F56 MCS fitting sport sway bar. Need bushings?
  10. F55/F56 Wireless charger from SCP Automotive, UK
  11. F55/F56 F-56 Batt. type
  12. F55/F56 Something I never knew!!
  13. F55/F56 OEM Jack question
  14. F55/F56 Fire extinguisher mount
  15. F55/F56 Battery Type
  16. F55/F56 My wife saved us 350 Dollars!
  17. F55/F56 Climate Control Knob problem
  18. F55/F56 Learning to brake with left foot
  19. F55/F56 Going to order a new MCS
  20. F55/F56 Leak Question
  21. JCW Clutch action question, new owner
  22. F55/F56 Has your iDrive ever spontaneously rebooted?
  23. F55/F56 Forsvara Engineering Jack Stand adapters - anyone tried these (or alternatives)?
  24. F55/F56 control front and rear fogs with only 1 switch
  25. F55/F56 New navigation data available message
  26. F55/F56 Tracker? Strange Object in Engine Bay
  27. F55/F56 F56 Digital Speedo Retrofit Esys 3.27.1 possible ?
  28. F55/F56 Issue with shifting to reverse
  29. F55/F56 Start/Stop Switch
  30. F55/F56 cold air intake?
  31. F55/F56 Lights on Center Display Questions
  32. F55/F56 Hood Scoops
  33. F55/F56 How to Code Sweep in Union Jack tail lights
  34. F55/F56 Rear hatch pops open when I open the driver side door or unlock with fob
  35. F55/F56 Thump after switching off ignition
  36. F55/F56 Corrupt USB Port
  37. F55/F56 Blackout trim
  38. F55/F56 How to reattach emblem on hood
  39. F55/F56 dyno'd
  40. F55/F56 2016 Convertible Rear Defroster Wiring Help
  41. F55/F56 Roof rack for 2015 2 door S?
  42. F55/F56 Serpentine Belt Replacement
  43. F55/F56 ID4 to ID5/ID6 FW Upgrade
  44. F55/F56 Muffler Delete with single Cat and resonator
  45. F55/F56 Looking for JCW Style Front of Rear Bumpers
  46. F55/F56 F56S LED Fog lamp vertical alignment - how to?
  47. F55/F56 F56 engine mounts
  48. R57 what would you do?
  49. F55/F56 2015 Mini Cooper S F56 rear window defrosting not working
  50. F55/F56 Car pops during coldstart, riding is jerky at lower speeds
  51. F55/F56 Top brake bulb (filament) in left/right tail lamp assemblies - what turns it on?
  52. F55/F56 Program F56 Rear Fog Lamps as **DRLs**?
  53. R56 Can anyone help
  54. F55/F56 Adjusting NM Engineering Rear Sway Bar links
  55. F55/F56 2022 Mini F55 Dynamic Damper Control
  56. F55/F56 Battery not charged notification on a 6 y.o Cooper SD F56 with new battery
  57. F55/F56 software update for misfires/running rough/high idle?
  58. F55/F56 Parts to upgrade/refresh when installing coilovers?
  59. JCW JCW order
  60. F55/F56 Engine Air Filters
  61. R56 Interior Seat/Cargo Covers to protect from Dog Claws
  62. F55/F56 Newbie from Southern CA
  63. F55/F56 Replacing Cooper fuel door with S chrome door
  64. F55/F56 Intro post
  65. F55/F56 Two kayaks on the factory roof rack system?
  66. F55/F56 threw my first code ?
  67. R56 Repair Manual?
  68. F55/F56 2022 LCI Interior Dash Trim
  69. F55/F56 Tail Light question - LED related
  70. R56 2014 S 3-Door F56 B48 HPFS High Pressure Fuel Pump Noisy but NOT Noisy.
  71. F55/F56 Part recognition and replacement advice
  72. R55 Heddon Street - part number
  73. F55/F56 CEL P12A5, Burger Stage 1 BETA (the original)
  74. F55/F56 Alt. output in amperage
  75. F55/F56 Engine mounts replacing and Front lower control arm bushings.
  76. F55/F56 Tire Temperature Question
  77. F55/F56 Wheel spacers needed for coilovers
  78. F55/F56 2019 JCW Tuning kit vs. 2020
  79. F55/F56 Trs
  80. F55/F56 The MINI bike rack
  81. F55/F56 100 miles on my 2022 Oxford edition - what I think so far
  82. F55/F56 Cooper S vs Non-S - More than engine?
  83. F55/F56 Recode rain sensing wipers to intermittent?
  84. F55/F56 Can't pump gas - Fuel pump shutting off
  85. F55/F56 Halogen tail lights to LED (not union jack)
  86. R55 Oxford delivery…..today
  87. F55/F56 Base two-door to GT rear interior conversion
  88. F55/F56 JCW Brake piston size
  89. F55/F56 Location for JCW Pro badge
  90. JCW Tunning
  91. F55/F56 Throttle is somehow making car pull left and right
  92. F55/F56 Disappointed in the HK sound system
  93. F55/F56 Flat roof roof rack
  94. F55/F56 Remote start
  95. JCW Catalytic Converter Issue
  96. F55/F56 Rough idling cold start with engaged gear
  97. F55/F56 Annoying delay to turn off car
  98. F55/F56 Just got my Dinan Sport - review
  99. F55/F56 Difference Between Sport Driving Modes
  100. F55/F56 Acoustical lock/unlock confirmation
  101. F55/F56 Disable Pops, keep burbles - possible?
  102. F55/F56 Where to get OEM stripes
  103. F55/F56 Retrofit LCI2 blind ring cover on pre-LCI models
  104. F55/F56 Coverking indoor car covers
  105. F55/F56 Wireless Charger
  106. R56 issue with Dinan Website
  107. F55/F56 Wanted to buy, Cooper S in Mid-Altantic area
  108. F55/F56 Engine mount problems on 2019 Mini 4 door
  109. F55/F56 Flow Through Ventilation?
  110. F55/F56 Will 225/45 tires fit?
  111. F55/F56 Auto transmission fluid change
  112. F55/F56 MINI Black Chrome Exhaust Tips
  113. F55/F56 2022 Cooper S Rear Fog Lights
  114. F60 CPO Guidance
  115. F55/F56 Sound horn when locking/unlocking possible?
  116. F55/F56 Designed a way to mount front license plate without drilling holes in your F56
  117. F55/F56 Headlights
  118. F55/F56 Exhaust downpipe differences
  119. F55/F56 Weight savings with moonroof/etc delete
  120. JCW F56 - Fake sound? eh?
  121. F55/F56 Tuning automatic gearbox getrag 7 speed
  122. F55/F56 F56 Cooper No Low Beams?????
  123. F55/F56 2022 Side Scuttle Indicator Light Upgrade….
  124. F55/F56 Adding Carplay to a 2022 Oxford Edition F55
  125. F55/F56 Disassemble iDrive controller for cleaning?
  126. F55/F56 LCI Headlight Retrofit Help
  127. F55/F56 Removing Sunroof Shade
  128. F55/F56 Sorry! I need help!
  129. F55/F56 Battery recoding on the cheap?
  130. F55/F56 Ambient Air temperature sensor
  131. F55/F56 2017 F56 MCS Glovebox light no worky (no it's not the bulb)
  132. F55/F56 Mini LED Rally Lights wiring
  133. F55/F56 New JCW, funky sound when slowing down
  134. F55/F56 Are there any fender flares available for an F55?
  135. F55/F56 Best sway bar?
  136. JCW Interior Trim question
  137. F55/F56 Terrible fuel economy with hills + city + stop signs
  138. F55/F56 You're welcome Mini Financial Services
  139. F55/F56 Just changed my spark plugs. How bad are these?
  140. R56 A/C intermittently blows room temperature
  141. F55/F56 Interior dimensions of the Mini Roof box 82732223388
  142. F55/F56 Lost “Configure Sport” menu.
  143. R55 2015 R55 AC recirculate
  144. F55/F56 2022 Anniversary Edition
  145. F55/F56 F-56 alt. output in amp.s
  146. F55/F56 Cup Holder phone mounts?
  147. F55/F56 ID4 to ID5 upgrade complete!
  148. F55/F56 2015 f-56 2.0 l
  149. F55/F56 Need advice: Is catless too loud?
  150. F55/F56 Has anybody seen this radio control knob before?
  151. F55/F56 Mirror caps
  152. F55/F56 F55/56 Fuel Line Size
  153. JCW Mini JCW finally in a class it should be...(TIRE)SMF
  154. F55/F56 JCW exhaust control valve no power?
  155. F55/F56 Has anyone got used to the 2022 F55/56 Look?
  156. F55/F56 Main Harness Wiring Schematic/Pin Out
  157. F55/F56 Won't restart after auto stop, requires ignition switch start.
  158. F55/F56 Bluetooth Streaming on pre LCI F56?
  159. F55/F56 Reasonable price for this fully loaded 2015 F56?
  160. F55/F56 New intake
  161. F55/F56 Does anyone know what this color is?
  162. F55/F56 Best bang for the buck: Koni Active+ 17" non-run-flats or 16" non-run-flats + wheels?
  163. F55/F56 Help with OEM Camera and Aftermarket Android Head Unit
  164. F55/F56 Mini F55 Bootmod3 Review
  165. F55/F56 Automatic Tailgate / Power boot Retrofit Kit for F56 / F55 / F60
  166. F55/F56 Remanufactured alternator ok for Mini, or no??
  167. F55/F56 Paddle Shifter Upgrade
  168. JCW Mini JCW First AutoX with New Flairs and Wheels/Tires
  169. F55/F56 Dealer wants my car!!!
  170. F55/F56 Add USB port connected to head unit USB2 - what cable?
  171. F55/F56 Clunking noise from front end
  172. F55/F56 ‘22 Cooper S about to enter production!
  173. JCW FAT MINI ... Fenders/Wheels/Tires
  174. F55/F56 2015 S - hard start after refueling
  175. F55/F56 Only one headlight turning on when unlocking the car
  176. F55/F56 BM3 Tune B46/B48 Mini F54 F55 F56 F57 F60 Cooper S JCW
  177. F55/F56 Aftermarket intake sound?
  178. F55/F56 Is this high for stock boost?
  179. F55/F56 Passenger restraint system error
  180. JCW Nearing the Finish Installing Aesthetic Fender Flairs
  181. F55/F56 B48 Engine Rebuild
  182. F55/F56 Smoked Side Marker Lights?
  183. F55/F56 Water and Meth
  184. JCW Mini Driving Experience Classes in Thermal, CA ?
  185. F55/F56 F56 2014 Mini Cooper S Driver Seatback Has Play & Doesnt Lock at Times
  186. F55/F56 XXR 527 et42 18" - New Shoes are on!!!
  187. JCW My tires FINALLY arrived 32 days after ordering
  188. F55/F56 B48 Blown Motor Tracker - Max Potential
  189. R56 Lci headlights on pre lci f56
  190. F55/F56 Retrofit JCW Steering Wheel with Paddle Shift on Cooper 1.5 LCI
  191. F55/F56 New battery.. no infotainment/other issues
  192. JCW Now have The TWO CARS I always wanted for personal reason...
  193. F55/F56 *Need Help* Coding for door handles LEDs
  194. F55/F56 AC working only when moving
  195. F55/F56 B48 f56 Engine Load
  196. F55/F56 225/40/18 vs 215/40/18 on 8" wide rims
  197. F55/F56 Forge Intake Pipe with Eventuri Intake
  198. F55/F56 F56 Oxford Ordering?
  199. F55/F56 MINI USA Site, 2022 models
  200. F55/F56 Anyone mind getting a quick measurement?
  201. F55/F56 Updated Nav/CarPlay by Dragos, Super Happy!!
  202. R52 Starter relay
  203. R55 F55 vs F56
  204. F55/F56 Mini Connected - WiFi hotspot?
  205. F55/F56 AFE Catted Downpipe?
  206. F55/F56 Driver’s Side Window Height When Retracted
  207. R50/R53 CTEK Charge-O-Mat hook up question
  208. F55/F56 Mario still in business?
  209. F55/F56 Best carnauba wax
  210. F55/F56 Tuning 2016 Cooper S
  211. F55/F56 2022 Configurator
  212. F55/F56 TPMS Sensor Part number for 202X cars?
  213. F55/F56 Missing POP Burble in 2021 F56 S 6MT
  214. F55/F56 Easy power mods for the Cooper F56 1.5t?
  215. F55/F56 Comfort Access Quit/Died
  216. F55/F56 Mini Clubman part fell out from under the engine bay
  217. JCW F56 Looking for some 18x8.5 et32 (6.01BS) 5x112 Race Wheels
  218. F55/F56 Remap Cooper SE regen braking options to steering wheel buttons
  219. F55/F56 Front fog lights as DRLs
  220. F55/F56 Haynes Repair manual
  221. F55/F56 Muffler delete on base f56 cooper 1.5t
  222. F55/F56 Enabling rear fog lights: VO change
  223. F55/F56 Raindow effect when viewing HUD with polorized lenses - Is this normal?
  224. F55/F56 Change speed readout on digital display to traditional needle/number when using HUD?
  225. F55/F56 Error codes after removing ecu
  226. F55/F56 Gas Flap Stuck
  227. F55/F56 Outmotoring coupon?
  228. F55/F56 Dash Panel Removal, Fog Lamps Install
  229. F55/F56 Yellow check engine light
  230. F55/F56 Match VIN to Part Number
  231. F55/F56 Just Retrofitted Factory Bike Rack Bumper Bar
  232. F55/F56 Dinan Elite
  233. F55/F56 New Tires
  234. F55/F56 2017 Countryman, hard to swap to B48 from 3series?
  235. F55/F56 F56 parts for sale
  236. F55/F56 Gauges/centre-screen dimming randomly
  237. F55/F56 Help - center screen removal
  238. F55/F56 Constant Power Fuse
  239. F55/F56 Paddy Hopkirk Edition
  240. F55/F56 Halogen reflectors to LED projectors?
  241. F55/F56 Anyone knows who this 16 jcw belonged to? bay area cali
  242. F55/F56 TPMS not re-setting problem
  243. R55 2021 or wait for a 2022
  244. F55/F56 trubo Boost gague install
  245. F55/F56 Headliner/roofliner center control module question
  246. F55/F56 My New ‘21 F56 JCW
  247. F55/F56 Door handle key cover
  248. F55/F56 Ice Blue Edition
  249. F55/F56 Aftermarket or OEM Battery?
  250. F55/F56 500 Abarth Owner looking to get into a JCW F56
