F55/F56 Trs
Old Oct 30, 2021 | 03:54 PM
Brohan's Avatar
Brohan
Trs
Hey yall. I'm newer to the mini community and learning as I go. I have a 2015 mini cooper base model and I'm having issues with shifting. I replaced the gear selector a while back but still having problems. I was thinking it was my trs but I can't seem to find it. I've looked all over the internet and watched several you tube videos but I found nothing for my car specifically, just that it was supposed to be on the transmission. I've read on other forums that it was on the shifter but those were for older models. My next guess is it's under the tcm (which is on the transmission). I did order the trs but I don't have it yet which is why I didn't actually take the tcm off to see. I was running out of daylight. Can anyone help me out? Also here's a picture of my tcm.
Old Oct 31, 2021 | 10:24 AM
TVPostSound's Avatar
TVPostSound
Whats a TRS?
What exactly are your shifting problems?
Old Oct 31, 2021 | 10:51 AM
Brohan's Avatar
Brohan
Originally Posted by TVPostSound
Whats a TRS?
Transmission range sensor. There's a hard vibration and when it shifts it's like it shifts into a higher gear than it should be in. It's almost like it starts in second and shifts up from there.
Old Oct 31, 2021 | 11:18 AM
TVPostSound
Oh!!
AKA Neutral safety switch.
That doesnt determine when to shift, it only tells the transmission what gear you are in, Like reverse, neutral, park.
It would be either at the shifter or the end of the shift cable.
Old Oct 31, 2021 | 11:27 AM
TVPostSound
I would suspect a torque converter issue.
Old Oct 31, 2021 | 12:35 PM
Brohan's Avatar
Brohan
Alright. How can I figure out what the issue is if the scan tool isn't reading any codes? Do I just need to say screw it and take it somewhere?
tHeFastEsTtUrTlE
Jan 30, 2021 06:58 AM
Eylül Toğay Kir
May 4, 2017 09:24 PM
KWPhelps
Mar 4, 2015 10:17 AM
6cyclones6
Jan 27, 2015 02:18 AM
DeLorean
Oct 28, 2013 07:07 PM
