F55/F56 Ambient Air temperature sensor
Old Aug 2, 2021 | 05:01 PM
Mr Meowgi's Avatar
Mr Meowgi
Ok so I installed a new larger intercooler this weekend into my 2015 Mcs f55 2.0l. And it threw the code for the AAT circuit low input.
Everything I can find online states that it's mounted to the front bumper. Well the location for mine is in the air duct that travels to the brake system. Which I can't find any other mention or pi s of a sensor in that location.
So that's a little closer to the motor than you'd think it would be.
When hooking everything back up last night I accidentally plugged one of my fog light plugs into it and got the AAT and side marker warning lights. Amazing that they have the same plug.
After switching the plugs out the lights are fine now but still throwing the AAT code. And temp on my spedo say 122f. I've cleaned it with electrical contact cleaner both plug and sensor. Not sure what else to do besides replace.
Do you think plugging the light bulb plug would have shorted the sensor completely? Is there a way to reset the sensor. Read pushing ac and circulation button at the same time would reset but doesn't work.. Also the auto air barely works but max ac button does t work at all anymore. Below are photos of the sensor location.
Any help is definitely appreciated.
Old Dec 6, 2021 | 05:10 AM
Santier's Avatar
Santier
Solution?
Did you ever find a solution to this?I’ve got a similar issue.
Old Dec 6, 2021 | 08:45 AM
Santier's Avatar
Santier
Thank you so much. My temperature showed +122 and I immediately went down the rabbit hole of troubleshooting “short to ground” my scanner showed. Never thought to check the plugs. I also had parking light errors but I thought they were due to the LEDs I had installed and not yet coding. Didn’t think the two errors were related.
Old Dec 6, 2021 | 09:44 AM
Mr Meowgi's Avatar
Mr Meowgi
I ended up getting a new sensor and installing. Amazon has them cheap
tjkru
May 28, 2021 09:00 AM
alexs3d2
Sep 6, 2014 09:59 AM
GoinCrzyWanaCom
Apr 29, 2013 03:21 PM
harrisoncope
Dec 19, 2010 07:41 PM
Wake|MCS
Mar 18, 2008 07:32 PM
