F55/F56 Dash Panel Removal, Fog Lamps Install
Old Mar 23, 2021 | 06:14 AM
Leis's Avatar
Leis
Does anyone have any experience / tips for the removal of interior dash panels. I'm installing some PIAA fog lamps and I at least need to remove the underside of the drivers side panel to do some wiring from what I can tell. I may also need to remove some panels to get access to the fuses behind the glove box if I want to have them switched with the ignition.
The experience of others would be greatly appreciated - so I don't bust something!
Old Mar 23, 2021 | 10:48 AM
thunderball kaboom's Avatar
thunderball kaboom
For the driver's side, it appears to just pull out with some force - see this thread with some pics: https://www.northamericanmotoring.co...-swap-out.html
For the fuse box, it appears to drop down from once a tab is released - see this thread: https://www.northamericanmotoring.co...-fuse-box.html
Please share some pics and thoughts once you've installed the lights! This is my next mod, and I'll be using the PIAA lighting kit as well. I saw that the CravenSpeed instructions show the on/off switch mounted upside down on the lower bolster. I was thinking of mounting it to the side of the dash in the wider space between the door and the dash just to the left of the light switch (PIAA switch would face toward the door).
Old Mar 23, 2021 | 02:26 PM
jpsjr1970's Avatar
jpsjr1970
I had my PIAA’s installed by Chris from AutoWerks in Middletown, NJ and he used my OEM Foglight Switch to turn on/off the lights. He clearly did an amazing job! Also, HIGHLY RECOMMEND CravenSpeed setup! The 5” LED lights with the mounts are a breeze to deal with. Enjoy, Jose
Old Mar 23, 2021 | 02:54 PM
Leis's Avatar
Leis
So they wired the front fog lamps into the same switch as the reat fog lamp?
Old Mar 23, 2021 | 02:59 PM
jpsjr1970's Avatar
jpsjr1970
That is correct my friend. The PIAA switch is crappy looking, Chris suggested that he could do it and make it work and bingo it was done! My ‘15 F56 JCW had the same setup and I couldn’t be happier! Hopefully the new owner of the ‘15 knows how to use it. Enjoy, Jose
Old Mar 24, 2021 | 12:58 AM
jpsjr1970's Avatar
jpsjr1970
Here’s a picture of my PIAA 5” LED Lights...
Old Mar 29, 2021 | 09:53 AM
Leis's Avatar
Leis
Done. Hella 500 Fog Lamps installed.
iSUPR3ME
Dec 5, 2012 09:24 AM
classpro
Detailing 101
Jun 12, 2012 08:26 AM
jujucooper
Feb 13, 2012 06:23 PM
amarzano
Jul 23, 2006 08:40 PM
Iggy-MCS
Jan 11, 2006 11:18 AM
