F55/F56 Difference Between Sport Driving Modes
Old Sep 20, 2021 | 06:21 AM
rphox2003's Avatar
rphox2003
I have a 2017 automatic Justa and am trying to figure out the difference between the Sport mode (using the ring at the base of the shifter) and the Sport mode (moving the shifter to the left).
I know the ring Sport mode bumps up the rpms and stiffens the steering but as I don't have an S, it doesn't adjust the suspension.
I think the shifter Sport mode just holds gears a little longer before shifting.
Is that correct?
Also, is anything gained by using both together?
TIA
Old Sep 20, 2021 | 07:52 AM
ASKtheteach's Avatar
ASKtheteach
Moving the shifter to the left changes only the shift points to make it shift more aggressively. Putting the car in sport mode also tightens the steering and makes the suspension stiffer (if you have dynamic damper control).
hp79
Nov 29, 2018 05:27 AM
rphox2003
Apr 25, 2018 08:36 PM
Kristopher Sullivan
Aug 23, 2016 08:08 AM
Minime1963
R55 :: Clubman Talk (2008+)
May 4, 2015 01:19 AM
russmini
Jan 29, 2015 01:50 PM
