F55/F56 F56 Cooper No Low Beams?????
Old Aug 20, 2021 | 03:49 PM
OscarBRG's Avatar
OscarBRG
Wife's 2016 Base cooper with halogen headlights. Today no low beams? High beams work if turned on or if using flash to pass,,,,but no low beams,
Swapped out headlight switch with neighbor same model but same results. Checked fuse's with multimeter but they all checked out okay.
Schematic is not real helpful, is there a relay for high/low beams? Only fuses are behind glove box correct?
Any help appreciated....dealer is 1.5 hour drive.
-Thanks
Old Aug 20, 2021 | 04:11 PM
OscarBRG's Avatar
OscarBRG
So Warning screen messages are : Right low beam malfunction, Left low beam malfunction, Parking light Malfunction?
Anyone ever had this?
Just tried an old bulb I had left from when I replaced these a year ago and same result (high beam work, but no low beam)????
Old Aug 20, 2021 | 10:39 PM
michaelo's Avatar
michaelo
Maybe the entire headlight is no good. If possible, swap out the entire headlight with your neighbors.
Old Aug 21, 2021 | 04:06 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Have you done any bulb coding on your car? I recently had nothing my brakes lights stop working, and it was related to some coding glitch. I’m still not sure how it happened or when, but the only fix was to revert my coding.
Old Aug 21, 2021 | 04:00 PM
OscarBRG's Avatar
OscarBRG
Sorry I'm not even familiar with what you mean? This is with a laptop?
Old Aug 21, 2021 | 04:01 PM
OscarBRG's Avatar
OscarBRG
I appreciate you reply, but it is both front lights. I just don't think it's in the lights themselves.
GoCartDad
Nov 9, 2020 01:45 PM
Turnbud
Jun 13, 2019 07:53 PM
skyhawk940
Mar 20, 2011 02:40 PM
115hp
Oct 24, 2004 07:38 PM
Servoman
Sep 17, 2002 02:32 PM
