F55/F56 2021 F56 MCS fitting sport sway bar. Need bushings?
Old Feb 1, 2022 | 02:09 PM
cargusjoh's Avatar
cargusjoh
Hi,
Fitting sport suspension sway bar to MCS part number 33506853919. 21mm hollow 39% more rigid than standard S. Can I use existing bushings, or do I need different ones. Thanks!
Old Feb 7, 2022 | 09:51 PM
J_L's Avatar
J_L
It will arrive with the bushings glued on. But if you're going through all the effort, I'd put on something bigger, at least the NM 22mm.
Old Feb 8, 2022 | 08:52 AM
TVPostSound's Avatar
TVPostSound
I second J_L
I would use the 23 mm from them, that was my gateway sway bar!!
https://www.vipcustomparts.com/F56%20parts%20page.htm
Old Feb 10, 2022 | 01:52 PM
cargusjoh's Avatar
cargusjoh
Thanks for the responses. J__L yup it has the bushing thanks! I want to skip aftermarket parts so going with the JCW bar, 21mm hollow, instead of NM 22mm solid Per minimania JCW is 39% stiffer compared to NM 63%. Just installed and can tell the difference. Still have Winter tires so will know more with stickier Pilot Sport AS late Spring. Install was pricy, at $800 book from dealer. They did for $600, bar for $222. On R series it is much cheaper. I want the MINI install and parts paper, as well as 2 year warranty. Thanks all again!
Old Feb 10, 2022 | 04:57 PM
TVPostSound
Book labor from MINI includes 4 wheel alignment.
cooper48
Jul 19, 2021 01:02 PM
CSP
Suspension
Jan 30, 2021 08:49 AM
jeangtd
Jun 16, 2020 03:39 PM
Jason C
Suspension
Dec 12, 2007 10:42 PM
Iautox
Suspension
Oct 1, 2007 11:29 PM
