View Full Version : F55/F56 :: Hatch Talk (2014+)
- F55/F56 Will Creator c310+ clear Airbag Light?
- F55/F56 F56 Lowering Springs
- F55/F56 Driver door handle comfort access button no longer works.
- F55/F56 Wheel lug renewal / when do *you* renew/replace?
- F57 Is this space between the fender and the wheel normal?
- F55/F56 Seat damaged by sun. Help.
- F54 ESys Programming Verification/Help With Steps
- F55/F56 Installing Powerflex Upper Engine Mount Inserts in F56S without removing headlight
- F55/F56 Loud flapping noise from engine room at hwy speed
- F55/F56 tuning options for 2024 MCS
- F55/F56 Tire Question
- F55/F56 Will a Clubman grille fit an F56?
- F55/F56 Any BMW/Mini Techs here? I Smell Transmission Fluid from AC after Flush
- F60 Bimmercode Help
- F55/F56 F56 Possible Heating Issues
- F55/F56 Brake Upgrade
- F55/F56 security system
- F55/F56 Heads up: Priming the engine with oil in certain repair scenarios
- F55/F56 adding JCW tune with JB4?
- F55/F56 How tight for hood latches?? redid hood lock system
- F55/F56 Headlight delta adjustment retrofit?
- F55/F56 Gas Tank PID Level
- F55/F56 hood latch - hinge grease
- F55/F56 Race seats
- F55/F56 Liqui Moly + Schwaben:
- F55/F56 DIY: upper, lower motor & transmission mount
- F55/F56 Stuck Trans Fill Plug!! Suggestions?
- F55/F56 2015 F55, 3/2015 build, can't put gas in tank!
- F55/F56 Auto Climate Control: Possile to adjust temp on both sides with driver's dial?
- F55/F56 Amyone Disconnect Built-In Cell Internet?
- JCW External dialogue
- F55/F56 Need Scan Tool Recommendation for 2019 Cooper S
- F55/F56 automatic brake system: drive moderately
- R56 automatic brake system: drive moderately
- F55/F56 2025 MINI doing away with stick shift!
- F55/F56 Small coolant loss then stop cause for concern?
- F55/F56 Possible Fuel Tank Vent Valve Issue?
- F55/F56 Turbo/exhaust duct rubber boot replacement - what kind of rubber is it?
- F55/F56 How To Lock The Hatch On My F56? Just Walk Away!
- F55/F56 B38 Engine Teardown
- F55/F56 Grease your hood locks!!!
- F55/F56 F56 MCS, 100k maintenance: Questions, Questions...
- F55/F56 Techs: Man Trans Fluid @100k (dealer & Indy BOTH say DONT change??)
- F55/F56 Aux Water Pump Bleed Procedure Not Working
- F55/F56 Shifter Help
- F55/F56 Worth upgrading 15 to 23 24?
- F55/F56 Is Sun Damage A Concern With A Closed Sunroof?
- F55/F56 Airbag connector under seat.
- F55/F56 lugbolt spacers
- F55/F56 So that you know
- F55/F56 MMR vs. Wagner Intercooler
- F55/F56 Door opening and closing issues in cold weather
- R56 help....2015 mini cooper s...no right side running tail lights
- F55/F56 Title: Mini Cooper Suspension Upgrade: Installing Horizontal Shocks. Horizontal Shock
- F55/F56 Auto transmission - shifting from Drive to Reverse without button?
- F55/F56 Summer Tires
- JCW Carbon Fiber Hood for a 2019 Mini JCW...A REAL ONE
- F55/F56 Upgrading halogen headlights to pre-lci?
- F55/F56 Where to install catch can
- F55/F56 Transmission Mount Hassle.
- F55/F56 How do I know I my DME must be bench unlocked to tune?
- F55/F56 How are you working on your car without a service manual
- F55/F56 Union Jack tail lights for my 2015 F56 MCS. Please help me choos the correct lights.
- F55/F56 Is it possible to have a tuned map applied only to Sport Mode?
- F55/F56 Romondes chg.
- F55/F56 Our Roadtrip Machine
- F55/F56 F55 Front Base Seat Replacement.
- F55/F56 2023 F56 rear wiper blade replacement?
- F55/F56 oil ch. flap
- F55/F56 Can't play audio over bluetooth anymore
- R55 Pano sunroof acting up
- F55/F56 Rally Lights: Help with aim and pattern
- F55/F56 How to purchase F56 MINI Challenge parts?
- F55/F56 Accelerator pedal connector clips
- F55/F56 Have you replaced your water pump, thermostat housing, or alternator bracket? Got Qs.
- F55/F56 spare kit
- F55/F56 Possible to retrofit the LCI auto shifter to the pre-LCI?
- F55/F56 Timing Chain on a 2015 F56S
- F55/F56 Leaking counterbalance shaft cover seals/gaskets - anyone run into this?
- F55/F56 F56 Auto vs Manual Trans Mount, any difference??
- F55/F56 Red, extended paddle shifters - Yea or nay?
- F55/F56 Dervtech Tuning / Florida / Jan 2024
- R55 Mini F55/F56 - Is it possible to code with ESys to enable telephone function & BT
- F55/F56 Intermittent "clunk" when releasing brake pedal
- F55/F56 OK to use slightly longer bolts with spacers?
- F55/F56 Batt. Draw
- F55/F56 Batt.raw
- F55/F56 Aftermarket needs to innovate
- F55/F56 Help with Steering rack replacement for 2015 F56
- F55/F56 Thinking of Painting Roof
- F55/F56 difference between GS6-59BG and GS6-59SG trans
- R56 2023 Cooper S problems
- F55/F56 JCW corner splitters on a Cooper S?
- F55/F56 Help with engine part
- F55/F56 Headlight moisture?
- F55/F56 Power tolerance between Auto/DCT
- F55/F56 Any vendors know about NEW JCW badges?
- F55/F56 JCW steering wheel paddles removed
- F55/F56 2020 - 2024 w digital cluster - Anyone use an F1 style wheel?
- F55/F56 Beltline - Should I black it out?
- JCW Steering - Can it be made tighter?
- F55/F56 Seatbelt/B Pillar rattle?
- F55/F56 Drivetrain Malfunction - Misfire
- F55/F56 F56 (B46/B48) Performance Camshafts/Big Valves
- F55/F56 Selling Mini soon
- F55/F56 Stock vs GP3 vs Powerflex Gearbox Mount Differences
- F55/F56 Need help upgrading base audio system
- F55/F56 Scooper
- F55/F56 GIOMIC previews brand new Aero kit
- F55/F56 2023 Cooper S quirks vs. old 2017
- F55/F56 Outdoor Car Cover?
- F55/F56 Crankshaft pulley replacement / locking the flywheel
- F55/F56 Removing passenger side LED headlight for upper engine mount bushings install
- F55/F56 Leak at junction of starter and engine block - what is it & how big a deal?
- F55/F56 Gas Cap Trim removal
- R56 2023 F56 shift knob
- F55/F56 How to remove headlight lens?
- F55/F56 Powerflex lower engine support bushing questions about potential problems…
- F55/F56 2017 F56 mini Give back thread!
- R56 Head rebuild leaves extra bolts?
- F55/F56 week break
- F55/F56 What this thar thing on mah radiator be huh hm?
- F55/F56 Air Moto
- R56 300 HP Recipe
- F55/F56 JCW Pro Exhaust Questions
- F55/F56 Jb4 + afe intake
- F55/F56 proper city mpg
- F55/F56 sp. plugs
- F55/F56 Is there anyway to monitor injectors?
- F55/F56 Black Out but only light bezels? Lame?
- F55/F56 18 F56-S roadside parking light coding
- F55/F56 Valvetronic code 133f03
- F55/F56 LCI2 Mini Cooper Base Rear Bumper
- R56 Seat materials? PVC? 100% leather?
- F55/F56 Shift Logic failing intermittenly on piggyback tune
- F55/F56 once/month batt. charge
- F55/F56 Cooper S - ignition coil lifespan?
- F55/F56 JCW tuning kit vs. 2019 build date
- F55/F56 Anyone have access to or have an old F56 S/JCW radiator?
- F55/F56 Belt line bodywork clips broken - can they be replaced?
- F55/F56 Spring bushing part #?
- F55/F56 Very confused about DME unlock
- R56 In abundance
- F55/F56 Out Looking
- F55/F56 F56 2016 Gen3 Hatchback, 2doors, hardtop, 1.5 LTR engine
- F55/F56 "Info" level codes in BimmerLink -- not visible in a Foxwell?
- F55/F56 Metal shavings on magnetic plug @ oil change. What to freak out about first?
- F55/F56 changing rotation direction of tires
- F55/F56 Side sun visor clip part #s?
- F55/F56 Car magically surpassed Vmax
- F55/F56 2016 F55. Id4 to id6
- F55/F56 F56 "MINI Vehicle Check" - comprehensive list of what's in it?
- F55/F56 B48 - 500 hp?!
- F55/F56 BERU plugs
- R56 Engine Roughness — Shop Can’t Find Issue
- F55/F56 F56 (B48) High Mileage Lessons and Experiences
- F55/F56 2024 NON S in 6 speed.
- F55/F56 HVAC controls/OBD port no power/inop
- F55/F56 F56 Exhaust - going from performance back to OEM
- F55/F56 2014 mini cooper hardtop
- F55/F56 No heat
- F55/F56 AC condensation drain draining in wrong place, funky smell
- F55/F56 BMW R5 NGK F56 S Spark Plug Problems
- F55/F56 I'm back from the dead with another one
- F55/F56 Anyone replaced a transmission?
- F55/F56 cat.less DP
- F55/F56 Anyone done rear PDC retrofit on F56?
- F55/F56 B48 vs B46 Differences - JCW exhaust/tuning kit
- F55/F56 JCW Pro Exhaust and disconnecting battery....will it cause issues?
- F55/F56 Here we gooooooooooooooooooo!!!!!!!!
- F55/F56 2015 Cooper, help diagnose transmission disengagement issue
- F55/F56 F56 JCW Pro Tuning kit exhaust tip help
- F55/F56 Part ID for the condensation drain under the car?
- F55/F56 Truck stuck shut/locked
- F55/F56 Dinan springs
- R56 02 Sensors and Registered Battery
- F55/F56 F56 Front Sunblind Install help in Southern California
- F55/F56 Stage 2
- F55/F56 F56 Charging voltage
- F55/F56 Intake Valve Walnut Blasting
- F55/F56 Batt. Man
- F55/F56 Are midpipes bad for untuned B48?
- F55/F56 Engine stuttering at 40mph after coding 2TB by Codemybimmer
- F55/F56 Strange "Drivetrain Malfunction Warning" Situation
- F55/F56 Can you flash the ECU yourself?
- F55/F56 Headlight stopped working
- F55/F56 Ramps
- F55/F56 Anyone running Royal Purple oil? 🟣
- R56 exhaust vibration?
- F55/F56 Hood scoop
- F55/F56 Is stock intake duct a restriction?
- F55/F56 ready to desulfate !
- F55/F56 Normal Engine Noise?
- F55/F56 Looking for the underhood fuse box
- F55/F56 Auto trans issue
- F55/F56 Considering a newer Mini, curious on some options
- F55/F56 Speaker upgrade - any recommendations?
- R55 my car for sale at dealer
- F55/F56 triangle-exclamation pont
- F55/F56 Parking/side lights not working…
- F55/F56 Cooper S stock exhaust question
- F55/F56 How do you keep the radio playing with the engine running
- F55/F56 2016 S Auto - No paddles?
- F55/F56 Brakes not properly serviced?
- F55/F56 LEAP Works Intake Scoop??
- F55/F56 Hood Up ?
- F55/F56 Battery charge
- F55/F56 Tire Size for 18x8.5s
- F55/F56 Tire Pressure
- F55/F56 Play in harmonic balancer -- how much is normal?
- F55/F56 Bushings: Front Control Arm & Sway bar, DIY friendly??
- F55/F56 DIY for Transmission Mount??
- F55/F56 Missing fuses from fuse box
- F55/F56 JB+ N18 on a 2019 F56 S?
- F55/F56 Fuel Tank Filling Problem
- F55/F56 Brake/clutch fluid flush
- F55/F56 Would you proactively change your serpentine belt tensioner?
- F55/F56 stiffening up chassis for sunroof creaking
- F55/F56 Loud engine noise - video
- F55/F56 source for torque values F56
- F55/F56 F55 Infotainment fuse
- F55/F56 HELP! Car inop after motor mounts installs
- F55/F56 Fuel Tank Issue
- F55/F56 Are Adjustable Rear Control Arms Needed?
- F55/F56 Security System lock?
- F55/F56 speed
- F55/F56 Loggin' in
- F55/F56 F56 digital speed
- F55/F56 Chili Red wash and wax products?
- JCW 2019 Mini JCW Last AutoX in February!!!
- F55/F56 About to pull the trigger - 2017 to new 2023
- F55/F56 Front Brake Pad Warning
- F55/F56 Bov
- F55/F56 MSC F56 windshield snow cover?
- F55/F56 Tire fitment
- R56 Buyer’s remorse
- F55/F56 rally lt.s
- F55/F56 F55 S front/rear fog lights. Do I just need switch to be able to use these?
- F60 Headlight swap
- F55/F56 Power Steering went out after click n drive wired
- F55/F56 beltline and strut bar wrapping
- F55/F56 How to debug a parasitic draw?
- F55/F56 2017 Cooper S coolant leak diag help?
- F55/F56 Rally Lt. Covers
- F55/F56 O.P. Sender
- F55/F56 Digital gauge cluster not fitting
- F55/F56 Stock Information Display Head Unit
- F55/F56 Disabling the Outside Air Temp Alert?
- F55/F56 Replacement driver door visor
- F55/F56 Coding/feature/etc acronyms
