F55/F56 Truck stuck shut/locked
Old Jun 5, 2023 | 07:40 AM
honderpilot's Avatar
honderpilot
I closed my trunk rather hard as it had been full and now I'm not able to open it with neither the trunk handle, the drivers side button nor the key fob. When I do any of the three, I hear a a soft "click" as I can hear the actuator trying to release the trunk unsuccessfully. Nothing is jammed in the lock and i've tried pushing and pulling every which way while holding down the button. I am aware the F56 does not have a manual trunk release that is accessible without removing the back paneling which cannot be removed with the boot shut. I'm open to any suggestions before taking her to a mechanic.
Old Jun 5, 2023 | 10:36 AM
lonewolf170's Avatar
lonewolf170
Can you push closed while clicking the button to unlock? Or pulling slightly when unlock?
Are your panel gaps consistent?
Old Jun 5, 2023 | 10:59 AM
honderpilot
Yes, I tried pushing from the inside while friends pulled from the outside. I also pushing in down near the lock all while unlocking to no avail. Funny you mentioned, I did check the gaps this morning incase it was off to one-side but it looks clean and locked evenly unfortunately.
Old Jun 5, 2023 | 11:10 AM
Yes sounds like its stuck, that cable is under there, last resort you break the trim to get it. . https://www.realoem.com/bmw/enUS/sho...diagId=41_2290
https://www.ecstuning.com/b-genuine-...k/51247337576/
All i can think is applying some pressure and and outward on the trunk door while hit the unlock. I think either it got jammed from dirt or fabric/something in the trunk that was carried got stuck?
Old Jun 5, 2023 | 12:58 PM
honderpilot
I wish there was a way to get at it the pull release (51249878934) with a screwdriver or something from the inside without having to punch a hole in the trim.
StingrayRandy
Jan 25, 2021 11:40 PM
gzaos
Electrical
Dec 8, 2013 03:17 PM
iceman72
Jun 15, 2009 06:12 AM
kimmc
May 25, 2007 06:30 PM
MIN 18
May 23, 2007 01:09 PM
