F55/F56 Failing battery cause head unit issues?
Old Jul 16, 2024 | 08:57 AM
VOmini's Avatar
VOmini
Can a failing battery cause the head unit to be stuck in a boot loop, even if the car runs fine otherwise? Or is the head unit pooched? This happened coincidentally with a carplay module install so I'm not sure if it's related. Disconnecting the car battery for ~5mins fixed it once and everything was working, but then it started doing it again the next day (stuck in boot loop). Now a disconnect doesn't fix it. This is a 2015 MCS.
How can I tell if the NBT module is fried?
(posted in the audio forum as well, but not much action there)
Old Jul 18, 2024 | 08:12 AM
johnnys2quick's Avatar
johnnys2quick
Did you install software on the head unit for the carplay? If so can you remove it to test?
Old Jul 26, 2024 | 09:13 AM
VOmini's Avatar
VOmini
Problem solved. For anyone in the future, Replaced the NBT unit, it will work without coding, but you won't have your options (Nav) until it's done. If you get NO SIGNAL, check your connections.
VOmini
Navigation and Audio
Jul 17, 2024 12:36 PM
kfmuller
Mar 11, 2024 09:04 AM
RareAir23
Sep 12, 2012 10:35 AM
Swank1975
Feb 16, 2010 04:47 AM
