F55/F56 Replace water pump 2014 Cooper S w/ 2L turbo
Old Dec 2, 2025 | 08:46 AM
barrywebb's Avatar
barrywebb
Good morning.
Apologies if this question has already been answered but I looked and didn't see anything.
My Mini dealer identified a leaking thermostat housing. They want a lot of money to replace it. So I'm looking for a video guide that covers the Cooper S with the 2L turbo B48A20A engine? Lots of guides for the 1.6L engine but none that I can find for the 2L.
mini doesn't sell the thermostat housing separately but third parties do. Any thoughts as to buying just the thermostat housing?
Any help/advise appreciated.
Thanks!
Old Dec 2, 2025 | 12:27 PM
Hello,
Here you go.
https://www.northamericanmotoring.co...et-got-qs.html
Old Dec 2, 2025 | 03:35 PM
barrywebb's Avatar
barrywebb
Thanks for that link. I had seen that post and watched the video. The problem is the BMW has so much more space to work with than the Mini so although is was a great video, it just doesn't get me closer to knowing how to change the pump/thermostat housing.
I do have to say that the tech working on the BMW was top notch.
Old Dec 3, 2025 | 04:03 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Check this thread:
https://www.northamericanmotoring.co...lant-leak.html
It is for an F54 JCW, but the engine is similar. He does replace the thermostat along with the oil filter housing, so should give you an idea of what is needed.
Old Dec 3, 2025 | 04:39 AM
barrywebb's Avatar
barrywebb
Thanks! I'll take a look
Old Dec 3, 2025 | 04:49 AM
dannieh42's Avatar
dannieh42
I just change my "heat management module" (which replaced the thermostat starting in 2020) last weekend. Even though the part functions a little different, removal and installation is very similar. My advice is take the time to remove the fan shroud. There is VERY little room there and the plastic edges on the shroud are sharp and cut your hands up working in that tight space.
The three bolts on the bottom are very hard to reach and impossible to see without a borescope (which thankfully I had). With the shroud still in place, a socket on a 3" extension is too short and 6" extension is too long. I had to use a 3" extension and a swivel wrapped in tape to reach them. Without the tape the swivel would droop and would not go on the bolt. Removing the fan shroud would have saved time and made the job much easier.
Old Dec 3, 2025 | 06:52 AM
barrywebb's Avatar
barrywebb
Thanks for the input.
On the 2L engine, the water pump/thermostat is to the left of the crankshaft so I'm not sure why the radiator shroud would need to be removed in this instance unless it's to remove the hoses going to the thermostat housing. Was that the case with your heat management module?
Thanks again for your help
Old Dec 3, 2025 | 07:15 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
That part of the engine bay is tight against the radiator fan. Removing the fan and shroud allows for more open access.
Richard Reynolds
Mar 15, 2017 07:02 PM
richard2008
Sep 26, 2014 02:24 PM
BMBULBE
Apr 18, 2013 09:19 AM
Ch28Kid
Jul 12, 2012 03:12 PM
hyneso1961
Jun 18, 2012 07:15 PM
