PDA
View Full Version : SCCA Solo and ProSolo
Pages : 1 2 3 4 [5] 6
  1. ProSolo Mini's at Nationals?
  2. STX (Street Touring X) Optimal Azenis tire temp?
  3. Solo My first auto X school
  4. STX (Street Touring X) 15x6.5 or 16x7 for STX?
  5. SMF (Street Modified FWD) Comprehensive list of ways to lighten?
  6. Solo ccr autocross #6
  7. Solo Whats the Verdict on the V710 vs A3S04/A3S05's?
  8. ProSolo So what happened in Oscoda?
  9. H Stock Tires/Wheels Priority: Size,Tire & Weight
  10. H Stock Solo II restructure for 2006?
  11. Solo SCCA moving some cars into GS & HS
  12. Solo FedEx Field, Md 06.12.2005 MINIpics
  13. D Stock Aero Kit and Stock Class?
  14. D Stock Kumho V710 215/40 16 Pressures?
  15. H Stock My Autox Alignment
  16. STF (Street Touring FWD) Finally Back At It
  17. Solo Autox with Stock 4season runflats?
  18. D Stock Wheel Spacer Sources?
  19. STX (Street Touring X) Thinking about going to STX!
  20. H Stock Falken Azenis RT215 vs RT615
  21. STX (Street Touring X) Need auto-x tire info
  22. Solo Topeka Nationals Warmups SEPT 10-11 SIGN UP NOW!!!
  23. H Stock "S" Side Skirts legal in HS
  24. D Stock Thanks Oasis Tan!
  25. Solo Which is the Fastest Color?
  26. H Stock New HS MINI on the way...
  27. SMF (Street Modified FWD) The Good News: My Mini Won SM...
  28. Solo FYI, Stock camber problem solved with out camber plates.
  29. Solo carolinas autocross #5
  30. Solo Damage P/S fan with a cone?
  31. D Stock DA shocks and no FSB
  32. Solo Would wider factory wheels sell?
  33. STX (Street Touring X) Cold Air Intake Mods in STX
  34. STX (Street Touring X) Azenis RT-615 205/40/16
  35. D Stock water spray. is it legal?
  36. D Stock ANOTHER wheels and tires thread...sorry.
  37. Solo V700 autocross tire pressures
  38. H Stock H-Stock Tire question
  39. Solo Rotating 6 tires through during an NT
  40. Solo Tire expense per year for serious autocrossers
  41. Solo Who is heading to Atwater for the National Tour Event This weekend?
  42. Solo carolinas autocross 4
  43. D Stock wheels and tires
  44. ProSolo Atwater ProSolo
  45. D Stock Alta Cold Air Intake, what does this mean?
  46. Solo Helmet Help- First Timer
  47. D Stock R-Comp Tire Recommendation for a Novice?
  48. H Stock 205/50/15 Azenis Tires - not THAT impressive
  49. Solo The Tire Rack for Sale
  50. STX (Street Touring X) What's new?
  51. D Stock Source for inexpensive 16x6.5 wheels?
  52. Solo What air pressure for Hoosier 05s
  53. D Stock Check HS forum
  54. H Stock Houston National Tour
  55. Solo Tires for Stock classes
  56. Solo 2005 contingency from MINIUSA.com?
  57. D Stock G Stock: To "R" or not to "R" right away
  58. D Stock 2005 MCS Weight
  59. Solo carolinas autocross #3
  60. Solo Awesome Chiles photo at San Diego
  61. Solo Torque on lug nuts?
  62. Solo LSD in SanDiego is good
  63. Solo Harness bar
  64. Solo damper adjustment necessity?
  65. D Stock 2005 Mcs Lsd
  66. D Stock V710 psi?
  67. SMF (Street Modified FWD) How important are coil overs for SM?
  68. D Stock Rear camber setting on 1/1/05 MCS?
  69. D Stock JCW suspension
  70. D Stock Hoosier A3S04 PSI
  71. H Stock rain tires
  72. Solo carolinas autocross and school
  73. Solo FYI 05's after 1/1/05 come with adj. rear camber!
  74. Solo 16" Wheel Suggestions
  75. Solo Kid Karting!
  76. Solo Need Shocks!!!
  77. Solo Solo 2 and the MINI. Stock vs other classes
  78. FSP / DSP (Street Prepared) 02-04 JCW MCS Mis-Classed???
  79. D Stock Helmets: a question for Randy Webb
  80. H Stock New Kids On The Block (ok, really new HS cars)
  81. STF (Street Touring FWD) RT-615 pricing out today...
  82. Solo SCCA Solo 2 Rule Book ONLINE
  83. H Stock Who's running HS in 2005?
  84. Solo Auto-X at Knight's Stadium on Feb 6th
  85. D Stock Best tire size for MCS in GS?
  86. Solo Avon Tech R's first event
  87. STX (Street Touring X) Hankook R-s2 Z212 sizes
  88. Solo Central Carolinas Region autocross
  89. D Stock Koni Adjustable Shock settings
  90. D Stock No short-shifter in G Stock?
  91. D Stock Wheel weight vs. performance
  92. Solo What classes for next gen Minis?
  93. STX (Street Touring X) Spring T&T at VMP
  94. D Stock First Newbie Questions For The Year
  95. D Stock Down and dirty grip ratings
  96. ProSolo Fontana ProSolo
  97. Solo Adjustable shocks for Stock classes
  98. Solo I'm starting to have autox withdrawal symptoms
  99. STX (Street Touring X) STX Question
  100. ProSolo 2005 ProSolo and National Tour Dates
  101. STF (Street Touring FWD) 15x7 or 16x7.5 ??
  102. D Stock 17" or 16" wheels for auto-x?
  103. D Stock Is this a legal rim?
  104. Solo Need New Place To Play
  105. SMF (Street Modified FWD) Hello all!
  106. Solo Annual Tech?
  107. H Stock Shocks....
  108. Solo 2005 PAX/RTP Index - Released
  109. Solo Four extra rims/tires in the back?
  110. Solo JCW factory install??
  111. SMF (Street Modified FWD) What's the most rubber I can get with Wilwood 11.75" brakes for SM?
  112. D Stock Looking for new rims for 2005
  113. D Stock Moving class
  114. Solo Trailering a Mini
  115. Solo How about D-mod?
  116. D Stock Staying or Leaving or Trading-in?
  117. Solo 05 MCS in D-Stock?
  118. FSP / DSP (Street Prepared) ASP for JCW kit MCS in Solo II
  119. D Stock Poughkeepsie (NY) Sports Car Club Autocross
  120. STX (Street Touring X) Swaybar end links
  121. Solo HK audio weight
  122. D Stock remain in g-stock?
  123. D Stock LSD details ?
  124. D Stock Tires worn on tread edge...
  125. D Stock Brakes
  126. H Stock 15" tires: Victos, V710s, S04's, or Avon?
  127. Solo SCCA Region Bragging
  128. Solo Seat Time
  129. H Stock What's the REAL offset of the o.e. 16s?
  130. STF (Street Touring FWD) STS at 2004 Nationals
  131. H Stock Whats low down on the "missing part" mod?
  132. Solo Topeka Results are coming up
  133. STF (Street Touring FWD) SCCA NWR STS ... Finally
  134. Solo Solo II nationals in Topeka, KS. Anyone??
  135. Solo Autocrossing?
  136. Solo Kumho V710 Reinstated
  137. D Stock MINI USA, Please give us crashbolts!
  138. Solo SE Divisional 28-29 Aug
  139. Solo Autocross this weekend
  140. H Stock H-Stockers, where are you?
  141. Solo Contemplating jumping ship??
  142. Solo Does anyone know how to contact CG-Lock?
  143. D Stock Best street tire for 2-driver car?
  144. STF (Street Touring FWD) new Azenis
  145. D Stock Avons, Hoosiers or the V710 ?
  146. H Stock Studs; what size & where to buy?
  147. Solo Do or Don't
  148. FSP / DSP (Street Prepared) FSP Hawaii Region
  149. FSP / DSP (Street Prepared) Mod list for DSP, here goes the Moola!!!
  150. FSP / DSP (Street Prepared) 15X8 wheels????
  151. D Stock Made my day
  152. D Stock Hoosiers on closeout
  153. H Stock Hoosiers on close-out
  154. D Stock Xenons Vs Regular headlights
  155. D Stock Koni DA effects on MCS??
  156. Solo Mini Contingency money??
  157. Solo FSP (F Street Prepared) forum? Interested?
  158. D Stock solo 2 fastrack rule change proposal G stock
  159. ProSolo Wendover ProSolo and Aug's Party
  160. D Stock Autoweek Warranty Thread Merged --> MINI Talk
  161. STX (Street Touring X) A few pics from the June autocross @ FedEx
  162. D Stock Transporting race tires, take a peak!!!
  163. H Stock Helmets
  164. Solo Wanted Topeka Drive
  165. SMF (Street Modified FWD) Suspension adjustments/set up
  166. Solo Grissom Solo2 7/18/04
  167. STF (Street Touring FWD) Baptism of Goldielocks
  168. H Stock Finally ran my mini on concrete...
  169. SMF (Street Modified FWD) Why and how to add camber plates for Auto-X?
  170. Solo Wanted: An idiot's guide to using a pyrometer
  171. ProSolo Congrats to Garfield on the Prosolo Challenge Victory!
  172. Solo New to AutoX
  173. D Stock Anyone else running a 17" wheel/tire setup?
  174. FSP / DSP (Street Prepared) SCCA Solo 2 Rules for Street Prepared class
  175. SMF (Street Modified FWD) SCCA Solo 2 Summary of Rules for Street Modified
  176. H Stock Ran against a Ralliart Lancer
  177. Solo Clutch gone after 10,000 miles and 2 seasons of AX
  178. Solo JCW now in STU
  179. Solo We have Stock sized pulleys for interference fit hubs
  180. D Stock ** Help – Fast – G Stock People **
  181. SMF (Street Modified FWD) where to get 15x8 4x100 36-38et?
  182. ProSolo Toledo Pro Solo Lodging
  183. STX (Street Touring X) Price of Entry has been lowered by MINI USA
  184. Solo MCS a slow auto x'er??
  185. D Stock 2005 MCS: LSD, lower gears, +7hp,--> back to D-stock ?
  186. D Stock How's everyone doing so far this season?
  187. STX (Street Touring X) P-Zero Corsa to be put on ST exclusion list!!!
  188. Solo 5/8 - 9 Solo School, SoCal $100
  189. Solo All MINI Autocross
  190. Solo Help!! Wheels for HS!!
  191. D Stock Sitting On Rev Limiter?
  192. D Stock Kumho V700s Falling Apart?
  193. D Stock Ever get 3rd gear ?
  194. Solo EP. FP
  195. Solo Atwater Pro and Nationals
  196. H Stock 205/50R15 Victoracer tire pressures?
  197. D Stock Wheel Spacers?
  198. D Stock Is a CG LOCK a good investment for a novice?
  199. Solo South Bend, IN Region SCCA Events
  200. H Stock h-sport rear sway not allowed on the MC for H-stock class?
  201. Solo Suggested tire pressures for Falken Azenis?
  202. Solo Get the Most out of Solo School?
  203. H Stock Front Swaybar
  204. H Stock Atwater Tour
  205. Solo Boston Evolution School Pictures
  206. H Stock Does the MINI need re-classing?
  207. D Stock Tire Pressures for Kumho Ecsta V700
  208. Solo Avon Tech R compound
  209. H Stock Tires??
  210. ProSolo Topeka Pro
  211. Solo Kumho Recall! Ecsta V710
  212. D Stock Best Alignment for G-Stock?
  213. H Stock Anyone tried Toyo's ?
  214. Solo Houston National Tour Event
  215. D Stock 04 lug bolts failure
  216. D Stock Confirmed! Cooper S does NOT fuel starve!
  217. H Stock Alignment for HS
  218. H Stock Difficulty mounting 205/45/16 Kumhos on stock 16s?
  219. D Stock What is the best Wheel and tire combo for RAIN!!!
  220. SMF (Street Modified FWD) So how are we faring? post your results here
  221. STF (Street Touring FWD) STS legal header??
  222. STX (Street Touring X) 15" Azeni Pressure ???
  223. STX (Street Touring X) Koni rear setup
  224. Solo WSCC Autocrosses - April 3rd and April 18th
  225. ProSolo Brian-quetsion about DSC
  226. Solo MINIUSA.com sponsor flare
  227. D Stock Mini Cooper S in 1st autocross, G-Stock!!!
  228. H Stock Wheel Size
  229. H Stock Affordable 16x6.5 wheels
  230. H Stock Damn that Audi 90!!!!
  231. STX (Street Touring X) I Win!
  232. D Stock Mini Cooper S G-Stock Mod list, any advice appreciated!
  233. Solo Check the Sig...
  234. D Stock Yucca Patrol is competing…
  235. STX (Street Touring X) Heat Cycling or Shaving Azenis?
  236. Solo Tech
  237. STX (Street Touring X) Mini Cooper S for STX solo 2 preparation
  238. D Stock Front bar replacement for G-Stock
  239. D Stock Butt Dyno says "YES" ! ! G-stock mods
  240. H Stock Race rubber tire wear
  241. Solo The Black Lake - Michelin Proving Grounds
  242. Solo Favorite Font for Racing Numbers?
  243. Solo Upcomming solo2 event
  244. D Stock old hoosiers or new hoosiers
  245. Solo What do you do about tires when it rains on race day?
  246. Solo CCR event #2, and school
  247. Solo What about brakes???
  248. H Stock Some suggestions please
  249. Solo Ramifications of 02/02 Build
  250. Solo San Diego Tour Saturday Night
