Solo Trailering a Mini
Old Nov 14, 2004 | 11:47 AM
cincymcs's Avatar
cincymcs
Trailering a Mini
I have an 05 MCS on order. I didn't notice any tiedowns underneath the cars at the dealer. For those that trailer their cars to races, how do you secure your cars to the trailer? I've heard that tying down via the rear trailing arms is a no-no, as they are easily bent.
Old Nov 14, 2004 | 04:25 PM
MacGuruTX's Avatar
MacGuruTX
The Mini has an eyelet that screws into the bumper for the tiedown. When you receive your car, its one of the things that your MA will go over with you. Stores in the boot and there is a small cover that goes on to the bumper to hide the threaded hole.
Old Nov 14, 2004 | 05:44 PM
MandaBoo's Avatar
MandaBoo
HI CincyMini! I'm assuming that you're in Cincinnati. What kind of racing are you planning on doing with your Mini? My hubby and I started auto-xing this year when he got his Evo and I'm waiting for my Mini to be built in January. In the area we tend to go to Scarlett Oaks and Wright State to auto-x. Maybe we'll see each other next year. Have fun waiting for your Mini!
Old Nov 14, 2004 | 06:30 PM
pezhead444's Avatar
pezhead444
I don't think it would be that good of an idea to tie down the car using the tow hooks, probably tying down the frame would be your better bet. There should be plenty of places on the frame to tie off from, heavy-duty thick steel is your best bet. :smile:
Old Nov 15, 2004 | 03:22 AM
BGarfield's Avatar
BGarfield
Nope, the tow eyelets are NOT for tieing down to a trailer.
The jacking blocks on the bottom of the car are removed, in their place is a slot (common to all BMWs), in that slot you insert what's called a "T Hook" that has an eyelet. To THAT eyelet, you put your strap hook on, crisscross the straps attaching to the trailer and that's it.
Believe it or not, some people have hooked to suspension components and/or used wheel straps, I recommend against that.
Brian
(trailering my '02...the RIGHT way)
Old Dec 2, 2004 | 01:50 PM
wheelspnr's Avatar
wheelspnr
Tie downs for trailering ..
by any chance, is the "T" hook someone referred to the same as the "T" hook used to tie-down C5 corvettes ? if not, where might one buy these ?
JC in StCharlesMO
Old Dec 4, 2004 | 12:01 PM
carl_aka_carlos's Avatar
carl_aka_carlos
Jerry, did you ditch the zed ought six for a Mini?
Carl in St. Louie
Old Dec 4, 2004 | 02:25 PM
DR61's Avatar
DR61
T-hooks for BMW's
JC in StCharlesMO
Bob Tunnel sells the T-hooks that fit BMW's:
http://www.tunnellracing.com/
Cheers,
Dave
Old Dec 5, 2004 | 04:46 PM
cincymcs's Avatar
cincymcs
After the Jacking Blocks are removed...
Brian, et al:
Once you remove the jacking blocks for towing purposes, how do you safely jack up the car? Does this create issues when you take it to the dealer for service?
Jim Z
O5 MCS on order
Old Dec 5, 2004 | 06:55 PM
BGarfield's Avatar
BGarfield
My jack has a flat rubber pad, so I simply place that in the same location as the hole, or where the block used to be. If your jack has "teeth", put a block of wood on it to jack where the holes are.
I've towed my car TO the dealer on the trailer, it wasn't an issue, and I wouldn't expect it to be since the cars have those holes there for a reason. Now, I'm sure a non-race friendly dealer would want to know why you're towing it, or why the blocks are gone. But, the blocks install within a minute total. Removing them takes about 5 minutes if you're not fast.
Not sure what Bob sells them for, but when I called him and he didn't have any, they just referred me to Northern Tool.
Brian
Dec 23, 2015 10:36 AM
bc219
Aug 10, 2015 11:22 AM
Dashdog
Aug 10, 2015 06:17 AM
