PDA
View Full Version : Electrical
  1. How To R59 or similar retrofit rear parking sensors
  2. How To F56 Retrofit Rearview Mirror
  3. Electrical Mini/BMW Connector Feature - Question
  4. Electrical Coding tail lights to be more bright?
  5. Electrical How to remove the ignition switch toggle
  6. Electrical Rally light brackets
  7. Electrical Aftermarket Remote Starter - Eurostart
  8. Electrical F56 2015 Mini Cooper S - Replaced LED Headlights - Coding Data invalid
  9. Electrical Wiring F56 for RV Toad Tow
  10. Electrical Adding factory fog lights
  11. Electrical Ok to bypass lighting wiring harness?
  12. Electrical Question Regarding Coding/Programming features
  13. Electrical Gauge Question
  14. Electrical Complete list of part to replace a Bis01
  15. Electrical Aftermarket speedo for non HUD cars
  16. Electrical 2015 constant 12v?
  17. Electrical Retrofit coding Voice Control and Enhanced Bluetooth
  18. Electrical Help with coding rear PDC
  19. Electrical Can I connect to ANY ground point?
  20. Electrical Rally lights brackets
  21. Electrical Looking for O2 sensor signal in dash (or nearby)
  22. Electrical *Request* Location of RGB controller (Excitement Package)
  23. Electrical Chang non power folding door mirrors for power folding ones
  24. Electrical Help with Bimmercode errors
  25. Electrical Aftermarket full LED headlamps for halogen models
  26. Electrical Passenger airbag warning light deactivation interruption.
  27. Electrical F55 cruise control retro fit?
  28. Electrical Wireless charging mod for larger phones
  29. Electrical Help. Amber angel eyes
  30. How To *Need Help* Coding to turn on door handle LEDs
  31. Electrical Trailer Wiring
  32. Electrical Union Jack sequential tail lights
  33. Electrical Mini F56 Hella 500 Fog Lamp Install
  34. Electrical Fog light kit replacement for F56 without factory fog lights
  35. Electrical rear fog light
  36. Electrical Retrofit footwell lights and glovebox light
  37. Electrical F55 Foglight swap to Driving Lights. Is this possible?
  38. Electrical Retrofit fog led lci
  39. Electrical F5x OEM LED Headlight & Fog/driving/DRL swap - what do I need?
  40. Electrical 2020 F56: Permanently Turn Off "Intelligent Safety"
  41. Electrical Looking to upgrade my halogen headlights with LED replacement bulbs
  42. Electrical Is there any mirror tap guides to hardwire v1 for 2020 clubman?
  43. Electrical Speedometer change
  44. Electrical Overhead light upgrade
  45. Electrical F56 Battery Relocation - Done
  46. Cooper (non-S) Best OBD module for Bimmercode app, R55?
  47. Electrical Hyper Flashing
  48. Electrical Rally Lights
  49. Electrical Fog Light Kit (without DRL) for F56 w/ Halo/LED Headlights?
  50. Electrical conFUSED
  51. Electrical Electrical Guru? Garage Remote
  52. Electrical NBT EVO HU upgrade question
  53. Electrical Front Fog Light Coding
  54. Electrical how to unplug original h8 foglight bulb
  55. Electrical Door, puddle lights, Mini logo projection, F55
  56. Electrical Airbag light blinking after ACSM2 Update
  57. Electrical Factory ECU reflash?
  58. Electrical Mirror Tap
  59. Electrical Coding a 2015 Mini Cooper S
  60. Electrical LED Taillight Bulbs
  61. Electrical Car Stalling
  62. Electrical headlight trigger wire (+ output wire)
  63. Electrical F60 Auto Dim Homelink mirror retrofit
  64. Electrical Esys coding for R57 yet?
  65. Electrical New mini owner
  66. Electrical Headlight Swap: Angel Eyes + Projectors
  67. Electrical MINI Fog Light Accessory...anyone have hands on experience?
  68. Electrical CEL/Limp Mode with JB4 map 1?
  69. Electrical Replacement clocks
  70. Electrical Adding 2nd reverse light? F54
  71. Electrical Need ideas on how to cleanly run wires to the roof
  72. Electrical LED DRL/Fog Swap Question - Why does it need a control module?
  73. Electrical Ecliptech ShiftP2 shift light (renew + video)
  74. Electrical Anyone running a Lithium ION battery?
  75. Electrical Starnill COB LED H4 replacements
  76. Electrical F56 Headlamp, fog lamp, and DRL replacement
  77. Electrical LED rally lights wiring question
  78. Electrical Fiamm Air Horns
  79. Electrical Aftermarket Auxiliary Lights
  80. Electrical Liteblox Battery
  81. Electrical Retrofitting Additional LEDs along door
  82. Electrical What does this do?
  83. Electrical JB4 ODB routing
  84. Electrical Aftermarket alarm?
  85. Electrical Homelink toggle hack options?
  86. Electrical Best Upgrade for reverse lights
  87. Electrical Accessory Gauge Wiring
  88. Electrical So... anyone ever mess with the Active Sound?
  89. Electrical code for Trim Wheel Arch socket
  90. Electrical Better than the cigarette lighter for external GPS or phone ?
  91. Electrical LED Headlights?
  92. Electrical Lock/Unlock chirp using fuel door actuator?
