Electrical rear fog light
Old Sep 22, 2020 | 04:44 PM
Scott's's Avatar
Scott's
rear fog light
Has any one switched the rear fog light to work with the brake lights, if so can it be done with out using the Bimmer Code App, spoke to a couple of dealerships and was told by both that the only changes they could make are to the key fob, was also offered some advice not to go into expert mode on Bimmer Code App, was told quite costly to re flash ECU. I have a 2020 oxford edition with the single fog light in the lower bumper.
Old Sep 22, 2020 | 06:08 PM
SFMCS's Avatar
SFMCS
Wire tap. Easy, works fine. If tou have LED tail lights, you will need LED bulbs (amazon) for the fogs. There is even a hole to feed the wires.
Old Sep 23, 2020 | 12:15 PM
Scott's's Avatar
Scott's
Do you remember what color wires are pos and neg, and would I go to one tail light, seeming how I only have the one fog light?
Old Sep 23, 2020 | 01:08 PM
SFMCS's Avatar
SFMCS
After nicking all of the wires from the schematic, I just end up using a meter. Just do not park in the shade like I did and the lights come on. They apparently change from model to model and years to year. Amazon does have some new wire taps that are great. Jelly filled and secure weather proof.
Old Sep 23, 2020 | 03:59 PM
Walt's Avatar
Walt
Its a pretty easy change using Bimmer Code. Check out https://www.northamericanmotoring.co...ke-lights.html
However, as a few others have reported, after I made the change 1/2 of my brake lights stopped working. I didn't have time to play with it, and simply backed out the Bimmer Codes changes.
Old Sep 23, 2020 | 05:16 PM
sgscomps's Avatar
sgscomps
I activated mine using Bimmercode, left and right sides have to be activated, not sure how it works with only one light. I never had any issues with the main brake lights acting up like some other had. You can buy a new headlight switch with the working fog light button but then the fogs are on all the time not just with the brakes.
Old Sep 24, 2020 | 06:26 AM
Walt's Avatar
Walt
Yep.
See https://www.northamericanmotoring.co...ml#post4391354 and https://www.northamericanmotoring.co...ml#post4501652
rkw
Electrical
63
May 15, 2020 10:30 PM
William Choi
Feb 17, 2020 02:25 PM
A383Wing
Apr 30, 2019 02:05 PM
HiDezClubby
R55 :: Clubman Talk (2008+)
May 31, 2016 08:30 AM
Duck360198
Mar 3, 2009 04:39 PM
