Electrical Help with Bimmercode errors
Old Jul 16, 2022 | 06:37 PM
Mrpandahead's Avatar
Mrpandahead
Hi, I'm wondering if you can help me out. I have a 2023 Mini Cooper SE (electric) which I bought 2 weeks ago.
I used Bimmercode with my Android phone Samsung S21 and a Veepeak BLE adapter successfully to change settings in the car over the last week. A few days ago I changed a setting in the AC (automatic climate control) ECU section and got an error. The app would not let me restore the setting. It just shows unable to recover I have contacted the Bimmercode app developer and they said to use a enet cable which I ordered and is coming.
The strange thing is that I can still change other ECU sections such as Headunit or body domain controller with the app and veepeak. So I'm not sure the problem is with the veepeak. Since the error the defrost button blinks continually with the car on or off, the AC does not work at all(fans blow warm air), and the underhood car fan blows very loudly for hours while car is charging . I have disconnected the 12v battery to try to reset but it did nothing. I tried pulling various fuses to see if that would reset the AC ECU unit with no success.
If anyone can help me restore the AC/automatic air control part I would be really grateful.
Anyone with esys or Bimmercode expertise?
Thanks for any help you might be able to give!
Old Jul 16, 2022 | 10:33 PM
TVPostSound's Avatar
TVPostSound
Use the very first backup, see what happens.
Old Jul 16, 2022 | 10:57 PM
Mrpandahead
Not sure how to restore. When I click on the red error ECU it takes me to a screen that says recover, then when I press it says recovery not possible. I can't actually get to a screen that shows the ability to recover. What should I do?
Old Jul 17, 2022 | 02:09 AM
Mrpandahead
Fixed! Stephan from Bimmercode replied back once I got the enet cable and offered to remote into my windows laptop. He had me download esys but once everything was setup he was able to fix it in 2 minutes! Basically restored the automatic AC ECU back to stock. Everything back to normal! Whew!
Brady Phillips
Jun 19, 2023 09:14 AM
lordgrinz
12
Jul 10, 2008 03:59 PM
ericscottf
Jul 21, 2005 02:00 PM
jhooper
Jul 5, 2005 01:42 PM
jsun
Jun 26, 2003 11:30 AM
