R56 My full engine built will be here.
Old Mar 24, 2015 | 08:13 AM
  #276
Tigger2011's Avatar
Tigger2011
Alliance Member
Why am I hearing the sound track from JAWS playing in the background? Could it be that some snooty high end sports trash drivers are about to be savagely humiliated? Hmm...
Old Mar 24, 2015 | 10:48 AM
  #277
SPRINTCARS's Avatar
SPRINTCARS
Lmao !!! Thats a good one. I think you might be right. And to make this even alittle more better. Check out my next photo. Take note how ugly those heat shields are next to that nice new turbo. ALL I DID WAS REPLACE TO TURBO !! Thats my story I'm sticking to it.
Old Mar 24, 2015 | 10:49 AM
  #278
SPRINTCARS's Avatar
SPRINTCARS
Ugliest heat shields I've ever seen.
  #279
SPRINTCARS's Avatar
SPRINTCARS
bone stock !!
Old Mar 24, 2015 | 10:51 AM
  #280
SPRINTCARS's Avatar
SPRINTCARS
I think it's a pretty good sleeper. Ugly shields and all. Its just a JCW turbo. HONEST !! Trust me !
Hehehehe
Old Mar 24, 2015 | 11:03 AM
  #281
Grizld700's Avatar
Grizld700
Ceramic coated the shields eh? I was thinking of doing the same.... minus the "JCW" turbo
Old Mar 24, 2015 | 11:14 AM
  #282
SPRINTCARS's Avatar
SPRINTCARS
Yeaaaa i coated those awhile ago. Wish it was fresh. But I'm out of coating material.
Old Mar 27, 2015 | 09:36 AM
  #283
SPRINTCARS's Avatar
SPRINTCARS
Its gonna be a long weekend.
Old Mar 27, 2015 | 09:37 AM
  #284
SPRINTCARS's Avatar
SPRINTCARS
I do believe its ready to go in the car.
Old Mar 27, 2015 | 02:59 PM
  #285
TazMinianDevil's Avatar
TazMinianDevil
Going to run an oil cooler I see. I like how you did the coolant loop.
Old Mar 27, 2015 | 03:28 PM
  #286
SPRINTCARS's Avatar
SPRINTCARS
Thats the water line obviously. I might re-do some of that plumbing so i can utilize the aux water pump with an additional cooler just for the water before it goes into the turbo. Might be more headaches than its worth and a bit of over kill.
Old Mar 28, 2015 | 10:44 AM
  #287
SPRINTCARS's Avatar
SPRINTCARS
Had i known it was that easy to take the front apart i would have done it long ago
Old Mar 29, 2015 | 04:24 AM
  #288
scubbysnacks's Avatar
scubbysnacks
I noticed in one of your shots of the engine that it still has the old plastic water pump. If it hasn't been replaced recently might be a good idea to replace it with the updated aluminium one while the engines out of the car.
Old Mar 29, 2015 | 05:51 AM
  #289
SPRINTCARS's Avatar
SPRINTCARS
Good idea. That is the plastic water pump. Do you have any idea where to get a metal pump ?
Old Mar 29, 2015 | 02:15 PM
  #290
scubbysnacks
There are a few different manufactures of the pump Valeo, Hepu & Graf. I don't know which company produces the OEM part and as far as where to buy hopefully your fellow country man can help.
Old Mar 29, 2015 | 02:24 PM
  #291
SPRINTCARS's Avatar
SPRINTCARS
Its in the car. Bell housing is bolted up, flyweel to torque converter nuts are tight, passenger side engine mount is on. Gotta do the small stuff now.
Old Mar 30, 2015 | 06:31 AM
  #292
Right here, the Genuine is now metal and all the aftermarket ones right now. Comes with the gasket.
Water Pump 11517648827
http://www.ecstuning.com/Search/SiteSearch/11517648827/
Old Mar 30, 2015 | 12:13 PM
  #293
SPRINTCARS's Avatar
SPRINTCARS
DAMN AGAIN !! New fuel installed. Tried to install the vacuum pump. Turned the drive and it spit oil at me. Guess i need to order a new one of those now. Oh well, every part under the hood is gonna be brand new.
Old Mar 30, 2015 | 12:36 PM
  #294
Bad seal on the vacuum pump or internal seal ?
Old Mar 30, 2015 | 12:40 PM
  #295
SPRINTCARS's Avatar
SPRINTCARS
Prolly internal. I went to put it on and spun the drive. It spit oil out the vacuum port. It still creates a vacuum but since i have so many new parts. Might as well get a new one of those as well.
Old Mar 30, 2015 | 12:48 PM
  #296
Darn,
N14 engine vacuum pump. Pierburgh is the Genuine MINI manufacturer.
http://www.ecstuning.com/Search/SiteSearch/11667556919/
Old Mar 30, 2015 | 01:15 PM
  #297
scubbysnacks
My pump is starting to leak who manufacturers the OEM one and are they better then the other ones you can get?
Old Mar 30, 2015 | 01:24 PM
  #298
SPRINTCARS's Avatar
SPRINTCARS
Darn, N14 engine vacuum pump. Pierburgh is the Genuine MINI manufacturer. http://www.ecstuning.com/Search/SiteSearch/11667556919/
Thank ECS !! Be calling you wednsday morning. I don't necessarily need a genuine mini part. What i want is the best high quality part.
Old Mar 30, 2015 | 01:32 PM
  #299
You are welcome Sprintcars. Pierburgh is OEM.
scubbysnacks - They are all metal now, not plastic on the housing ( which leaks over time ) anymore. Had replaced mine with the Graf one. Graf and Saleri have been flipping back and forth for OEM supplier. On some of the aftermarket ones you will have to nug the engine motor over or engine a little away from the firewall / frame so the pulley will slide over the new waterpump end mount that has a little extended ****.
Install info here water pump and thermostat. When installing the new waterpump and the pulley
https://www.northamericanmotoring.co...placement.html
and Here
https://www.northamericanmotoring.co...acement-3.html
Old Mar 30, 2015 | 04:45 PM
  #300
scubbysnacks
and Here
Do you know anything about the Valeo branded water pump?
