Electrical Countryman-Specific Coding - R60 Guide
Old Aug 6, 2012 | 05:21 PM
  #326
Koopah's Avatar
Koopah
Originally Posted by threar
Looks like the one I have.
+1 Mine has the same label.
Old Aug 6, 2012 | 05:47 PM
  #327
pyrrhusmj's Avatar
pyrrhusmj
ste
As the audio/video is now being controlled by your iphone, you'll likely need to play audio in the background on your phone (either pandora or via the iPod apps).
This is starting to make a bit more sense, especially finding out that Motion X works. Motion X supports "video out" mode (specifically for external video displays like in-dash media centers). Normally to do this, you need the special component/composite cables from Apple, but it seems that the MINI connected cable works just like one. Therefore, seems that if you find an app that supports Video Out and it *should* play on screen (thd sooner than latere native video player has supported this mode for a long time).
If this is true, then something like Netflix should also work in the same way.
Now, if I'm right (as this is still just a theory), that could also mean that if you were to install one of the many Video Out cydia apps (jailbreak apps) that would mean you could then seen your screen and most applications on the dash. Might be worth testing.
It might be tested sooner than later.
Old Aug 6, 2012 | 06:14 PM
  #328
xenor's Avatar
xenor
That is a relief that I got the right one.
Now, if I read correctly, I just need to figure out the Windows 7 64bit issues. I will have to tackle that once the car arrives.
Old Aug 8, 2012 | 01:38 AM
  #329
Nimrandir's Avatar
Nimrandir
This sound very interesting.... I read that BMW released an app also for android... If they release it also for mini connected it will be interesting... The android community is very "hack-oriented" I'd expect to find a modified Mini connected app that will show everything you see on your mobile...
Old Aug 14, 2012 | 01:07 AM
  #330
esse.erre's Avatar
esse.erre
Originally Posted by xenor
I haven't even taken delivery of my Countryman, but I ordered a cable...
Can anyone confirm that this cable will work?
I ordered and received the exactly same cable, and I wasn't able to connect my R60 to the laptop. (see https://www.northamericanmotoring.co...npa-cable.html).
I would ask you a feedback regarding this issue (it works or it doesn't).
Any other suggestion?
Old Aug 15, 2012 | 02:56 PM
  #331
hyde76's Avatar
hyde76
I have the same cable but when it arrived, the CD was cracked. The company sent me links to download the software needed for the cable and it all worked. For those of you having cable / laptop issues, you can try these links for the software.
http://www.mediafire.com/?b161d515134r222
http://www.mediafire.com/?5xbfd6f9x7wbakh
http://www.mediafire.com/?453a7v00vrpzffr
http://www.mediafire.com/?1evgcaj3q225l0o
Old Aug 19, 2012 | 08:26 PM
  #332
icuc's Avatar
icuc
How do I turn off the taillights with DRL on. I don't want the tail lights and licence plate lights to be on at the day time. Anyone know?
I tried these two values but didn't work
DRL_TFL_MIT_SL_2 --> Not Active
DRL_TFL_MIT_KZL --> Not Active
Old Aug 20, 2012 | 06:53 AM
  #333
threar's Avatar
threar
I wanted to make sure and cross post the iPhone thread here. Lots of good info over there.
Old Aug 21, 2012 | 05:48 AM
  #334
TRIPLE_O's Avatar
TRIPLE_O
Do you have these other functions? If so, set them to nicht_aktiv and it should work.
DRL_TFL_MIT_RL_BL_2
RL_BL_2_MIT_TFL
Old Aug 22, 2012 | 05:37 PM
  #335
PepeR60's Avatar
PepeR60
Thanks to Theta for this thread! Well, after the wife finally getting annoyed enough at having to manually unlock the doors every time to get the boys out of the back, I was given the okay to code the mini. Can someone please advise on what to look for when purchasing a cable from ebay? Are they all the same (ie will they all work)? Some people have posted that thy had problems with their cable, but never saw a post on the solution. Thanks in advance.
Old Aug 22, 2012 | 06:05 PM
  #336
TRIPLE_O's Avatar
TRIPLE_O
If you want to have complete peace of mind, order this one. It is the recommended, hassle free solution. They have 2 options for ordering
1) ONLINE STORE:
http://www.one-stop-electronics.com/...&product_id=16
2) EBAY:
http://www.ebay.com/itm/160845701117...84.m1439.l2649
I could recommend another one that I ordered in addition to the one above (it works well) but that's your call. There are many K+DCAN cables out there but not all of them may give desired results.
Old Aug 22, 2012 | 07:34 PM
  #337
PepeR60's Avatar
PepeR60
Thanks Triple O! That's a bit more expensive, but I do want the peace of mind and would rather spend more money once and get the right one.
Old Aug 22, 2012 | 11:31 PM
  #338
TRIPLE_O's Avatar
TRIPLE_O
You're welcome! Very smart decision. You should be able to offer them about $85-$90 on their eBay page. It's not much of a difference, but it's a quality cable and it will pay itself off in the longrun.
Old Aug 30, 2012 | 10:08 PM
  #339
xenor's Avatar
xenor
Well I figured I'd try tonight to code the "one touch" feature on my sunroof.
The good news is that I followed the instructions and got the cable working on my Windows 7 64bit pc. I installed a VM with Windows XP and that made it work.
Also, I was able to read the ECU and get the trace file populated for the SHD module for the sunroof. I changed the values, saved as my MAN file, and executed per the instructions.
The bad news is my changes did not take. I re-read the ECU again, and sure enough my changes were not present.
Any ideas what I was doing wrong?
Old Aug 31, 2012 | 07:29 AM
  #340
TRIPLE_O's Avatar
TRIPLE_O
1) Try to Save the TRC file as a .MAN file before you make any edits.
2) Make sure you set all of the proper strings to aktiv.
I would also note that a coded a mini this past weekend and the one touch close didn't take effect until after the car was shut down for 5 minutes (everything else worked immediately) Try coding another feature to see if it works.
Old Aug 31, 2012 | 07:40 AM
  #341
xenor's Avatar
xenor
I only know it didn't accept the changes because I read the ECU again and the 4 values I set to aktiv were still night_aktiv. I tried this several times. Perhaps I will save the TRC file as MAN before I make edits, as you suggest and try again.
The UI said "coding ended" after I clicked execute, and did so rather quickly.
Old Aug 31, 2012 | 05:22 PM
  #342
Koopah's Avatar
Koopah
Just to clarify...
The ".TRC" file contains the current status of settings as read by NCS Expert. For NCS Expert to change the settings, it needs a ".MAN" version version of the ".TRC" file with the new changes edited into it. Then, when you run you coding job, NCS Expert reads the ".MAN" file and writes all it's settings to the specific module.
The problem you are having could happen in at least three situations:
(1) a ".MAN" file does not exist;
(2) the only ".MAN" file found by NCS Expert is the 0-byte ".MAN" file "template";
(3) and unmodified ".TRC" file was renamed as the ".MAN" file (thus coding the module to its original state).
HTH,
Old Aug 31, 2012 | 06:58 PM
  #343
xenor's Avatar
xenor
Gave it another try a few minutes ago. No dice. I took a video of the entire process so whomever can tell me what I am doing wrong if anything.
Old Aug 31, 2012 | 07:10 PM
  #344
xenor's Avatar
xenor
If you care to watch this and tell me what I am doing wrong, please feel free. Thanks again.
http://youtu.be/nX0i3CYCxMk
Old Sep 1, 2012 | 05:41 AM
  #345
Koopah's Avatar
Koopah
If you care to watch this and tell me what I am doing wrong...
xenor -
NCS Expert may be sensitive to the case used in the ".MAN" file extension. Turn on your ability to see the file extensions in your file browser window and you will notice that the original ".MAN" file extension (if you saved it) uses the upper-case ".MAN" file extension. I believe you saved your changed file as ".man". I'm not sure whether this is the issue, but it's worth a try.
Another thing to try is to make sure to close NCS Expert after you have executed your job, completely turn off the car, wait a few minutes, then turn it back on and test for the change.
Also, out of habit, I've always closed NCS Expert to edit the ".MAN" file, then gone back in to execute the job. Not sure this will make any difference, though.
Let us know...
Old Sep 1, 2012 | 05:59 AM
  #346
xenor's Avatar
xenor
Ok I will try those things.
Also, anyone else please watch the video. Perhaps someone will see a critical step I am missing.
Old Sep 1, 2012 | 07:44 AM
  #347
threar's Avatar
threar
Watched the video. When you do a "Read ECU" that sets the job to CODIERDATEN_LESSEN, which means the "Execute Job" is "Read" and not code. When you first start up the program (before hitting "Read ECU") the default job is SG_CODIEREN, which basically means "write ECU" (or, take your TRC file and write to the current ECU). If before your last step of "writing" you should hit F2 (Change Job) and switch to SG_CODIEREN then you'd write the new TRC file to the currently selected module.
Also, Koopah's method is basically what I use; the reason that it works is because the Default job is SG_CODIEREN which means that it's ready to write.
Last edited by threar; Sep 1, 2012 at 07:46 AM. Reason: Grammar and mentioning Koopah
Old Sep 1, 2012 | 08:05 AM
  #348
xenor's Avatar
xenor
SUCCESS! I read the trace file, closed the program, made my changes to my MAN file, and started up the program and went through the process. I didn't pay attention to the default job, but I will keep an eye out for SG_CODIEREN from here out.
My sunroof opens with one touch!
Thanks for you guys' help!
Old Sep 1, 2012 | 08:40 AM
  #349
Koopah's Avatar
Koopah
SUCCESS!...{snip}
Excellent! Welcome to the R60 Koding Klub!
Of course, now you'll want to change EVERYTHING! Will changing-over to LEDs be next? Weather radio? Killing the key gong? Over-clocking the flux capacitor?
Old Sep 1, 2012 | 09:08 AM
  #350
xenor's Avatar
xenor
I will do selective LED replacement (parking lights and HID fogs, CREE backup light LEDs)). I've already done the entire interior in LEDs. Leaving the fogs on with high beams. I might enable the weather radio (never heard this before). Disable window stop rolling up when door is opened. Seatbelt warning (I always wear my seatbelt, but sometimes am pulling out of a parking spot and it's already yelling at me).
