Electrical Countryman-Specific Coding - R60 Guide
Old Sep 5, 2012 | 12:18 AM
  #351
couper1's Avatar
couper1
Hi
Can you give me a ebay link for the correct cable?
Old Sep 5, 2012 | 12:56 AM
  #352
Theta's Avatar
Theta
couper1,
Quite simply type in "bmw k+dcan cable" in the eBay search bar. Any of those clear-type cables with the K+DCAN white label will work. They're all the same hardware inside. DO NOT buy any blue or black cable - stick to only these.
Here is an example of that search on eBay: http://www.ebay.com/sch/i.html?_nkw=...p=15&_osacat=0
Old Sep 5, 2012 | 08:50 AM
  #353
bmwr606's Avatar
bmwr606
Originally Posted by Koopah
Over-clocking the flux capacitor?
no no no ... you don't overclock a flux capacitor, you overdrive it with higher voltage!
be verrryyyy careful
scott
Old Sep 5, 2012 | 09:11 AM
  #354
bmwr606's Avatar
bmwr606
i have found this thread very informative and i plan on doing a bunch of coding mods, but have not see any mention of this:
with headlights OFF, can i set "flash to pass" (pull back on turnsignal stalk) to flash the fog lights instead of the xenons?
thanks
scott
Old Sep 9, 2012 | 10:04 AM
  #355
Minique2's Avatar
Minique2
MD coder
Does anyone know somone in maryland who does this? I'm a mac person and thought if somone knows how to do this in 5 min, it might be easier than me borrowing someones pc, buying a cable, figuring out how to do it, and inevidabby messing up spending coutless hours falling out of love with my car.
Old Sep 9, 2012 | 10:34 AM
  #356
TRIPLE_O's Avatar
TRIPLE_O
Originally Posted by xenor
Ok I will try those things.
Also, anyone else please watch the video. Perhaps someone will see a critical step I am missing.
Sorry I have been off this thread for a while, threar was mostly correct (but although it worked), you will want to follow this procedure: after you edit and save your man file and go back into NCS Expert,
1) hit F5 for basic functions and select "coapiReadSgGetFswPsw" and then hit "ok"
2) hit F2 and select SG_CODIEREN and then hit "ok"
3) hit F3 to execute job
Originally Posted by couper1
Hi
I provided information on this a couple of pages back.
thanks
scott
Don't think it can be done, but post your FRM/NFRM file and I can see if there is an option in there for that.
Originally Posted by Minique2
Does anyone know someone in maryland who does this? I'm a mac person and thought if somone knows how to do this in 5 min, it might be easier than me borrowing someones pc, buying a cable, figuring out how to do it, and inevidabby messing up spending coutless hours falling out of love with my car.
Pm'd
Old Sep 10, 2012 | 05:44 AM
  #357
oxspeed's Avatar
oxspeed
What part of Maryland are you in? We can probably help you - we are in Pasadena, MD.
Thanks,
Rick
Old Sep 23, 2012 | 11:49 AM
  #358
Hoydi Cheng's Avatar
Hoydi Cheng
Hey guys.. this guide worked perfectly for me - 2012 Canadian R60. Any chance we have a way of disabling the TPMS warnings? That was the main purposes for coding.. although the rest was pretty cool =)
Old Oct 9, 2012 | 08:19 PM
  #359
wzabrouski's Avatar
wzabrouski
Is there a way to code the fogs on without headlights? I know this was possible on my R53 with the FES module. Just curious. Thanks!!
Old Oct 9, 2012 | 08:26 PM
  #360
Theta's Avatar
Theta
Just turn the light stalk to the first click (running lights), then turn on the fog lights.
No coding required.
Old Oct 9, 2012 | 08:36 PM
  #361
wzabrouski's Avatar
wzabrouski
How dumb do I feel... Never tried that. I guessed I assumed it was the same as the R53.
Old Oct 9, 2012 | 08:56 PM
  #362
Theta's Avatar
Theta
No worries! Glad that helped!
Old Oct 10, 2012 | 07:28 PM
  #363
pyrrhusmj's Avatar
pyrrhusmj
DUH
Old Oct 17, 2012 | 09:20 PM
  #364
wzabrouski's Avatar
wzabrouski
For some reason, I am getting the error that the NCS expert file is not compatible with the version of Windows I am running. I made the change to run the program with the Windows XP SP2 but still am having no luck. Any one else have this issue?
Old Oct 17, 2012 | 09:22 PM
  #365
Theta's Avatar
Theta
Which OS are you using? If I understand correctly, you're setting compatibility mode w/ Windows XP SP2.
Old Oct 17, 2012 | 09:27 PM
  #366
wzabrouski's Avatar
wzabrouski
Correct. Windows 7
Old Oct 17, 2012 | 09:29 PM
  #367
Theta's Avatar
Theta
NCSExpert only runs on 32bit versions of Windows 7. Are you running x64?
Old Oct 17, 2012 | 09:33 PM
  #368
wzabrouski's Avatar
wzabrouski
64 bit. So there is no way it will work with my OS?
Old Oct 17, 2012 | 09:37 PM
  #369
TRIPLE_O's Avatar
TRIPLE_O
Not unless you install a VM.
Old Oct 17, 2012 | 09:47 PM
  #370
wzabrouski's Avatar
wzabrouski
Vm?
Old Oct 17, 2012 | 10:15 PM
  #371
TRIPLE_O's Avatar
TRIPLE_O
Virtual Machine. You can run a Windows XP virtual machine on your Windows 7 64 bit computer.
Vm?
Old Oct 17, 2012 | 10:35 PM
  #372
wzabrouski's Avatar
wzabrouski
How would I go about doing that? Sounds pretty involved.
Old Oct 17, 2012 | 11:04 PM
  #373
Theta's Avatar
Theta
Way back in the thread we tried to help some users with this, but there's no simple answer. Here are your choices going from easiest to hardest:
1) Find an older Windows XP / Vista x86 or Win7 x86 laptop to use temporarily.
2) If you have Windows 7 x64 Pro, use the Virtual XP function built-in to run the program.
3) Use a tool like VMWare to create a virtual system (WinXP or Win7 x86).
I wish I could make it easier on you.
Old Oct 18, 2012 | 06:08 AM
  #374
wzabrouski's Avatar
wzabrouski
I was reading about that last night. To use the Windows VM tool, you have to have Windows Professional. It is not available for the home edition.
Old Oct 18, 2012 | 08:32 AM
  #375
Sliksunny's Avatar
Sliksunny
I ran VM on windows 7 pro 64bit it would not recognize the cable.
