Electrical Countryman-Specific Coding - R60 Guide
Old Jun 6, 2020 | 08:18 PM
  #1301
Dragonzsoul's Avatar
Dragonzsoul
Originally Posted by Lindsay Carter
06/2013 r60 jcw. Can't get the stupid selective locking to work either. I hate having to hit the button twice lol
How did you get the fogs to work when unlocking the car?
Old Jun 6, 2020 | 08:50 PM
  #1302
Lindsay Carter's Avatar
Lindsay Carter
I set the fog lights as welcome lights to active.
Old Jun 6, 2020 | 09:20 PM
  #1303
Dragonzsoul
I did too.. You used bimmercode?
Old Jun 6, 2020 | 09:31 PM
  #1304
Lindsay Carter
I do use bimmercode. What year is your mini?
Old Jun 6, 2020 | 10:31 PM
  #1305
Dragonzsoul
2012. I've tried it on, off, but no luck!
Old Jun 8, 2020 | 05:37 AM
  #1306
geekd4d's Avatar
geekd4d
Try NCS expert, I have had mixed results with bimmercode.
Old Jun 8, 2020 | 10:49 AM
  #1307
Dragonzsoul
I'm a bit intimidated with NCS expert..
Old Jun 11, 2020 | 10:56 AM
  #1308
aabcds's Avatar
aabcds
EDIT: Nevermind. I finally found a download link for it.
Anyone have spdatens_V67 and would be willing to share with me? I registered at BMWCoding.com over the weekend but my profile hasn't been approved yet so I can't view/download attachments. I found the post with the daten file but don't have access to it. Did a Google search for the past 15 minutes but haven't found a valid download link except at nsc-expert.com which is charging $15 to download it.
http://www.bmwcoding.com/showthread....-SPDATEN-V67-0
Old Nov 1, 2021 | 02:32 PM
  #1309
crr_guy's Avatar
crr_guy
Google Docs
The google docs links keep telling me 404 not found.
Old Nov 2, 2021 | 08:17 PM
  #1310
mikey_t's Avatar
mikey_t
If you're referring to the link that Theta posted, that happened back in 2011.....
Old Mar 12, 2022 | 03:23 AM
  #1311
LaxU531's Avatar
LaxU531
Hi, the old CHAMP module has changed because it has broken into the new (used) one with the same numbers, but you know, the VIN and the configuration are not correct, which means that practically nothing works except the radio. How do I upload my car's VIN, set all the configurations? by NCS Expert? or can it be uploaded via USB? In addition, NCS does not want to connect to the MINI and shows "Vin is faulty". I tried to bridge pin 7 with 8 and the other way around and nothing. Anyone have a good SP daten to mini from 2011? Please help...
Old May 16, 2024 | 08:59 AM
  #1312
Alexr54's Avatar
Alexr54
Can anyone confirm if these codes are valid and if my description fits?
$520 - Fog lights (this is to activate fog light button in the center dash switch bank for halogen fog lights?)
$5A1A LED Fog lights ((this is to activate the fog light button in the center dash switch bank for LED fog lights?)
$522A Xenon Light (This is to change the VO to show Xenon Headlamps in place of halogen?)
Is there any similar VO for LED tail lights, side markers, 3rd brake light?
Old May 21, 2024 | 06:48 PM
  #1313
Alexr54's Avatar
Alexr54
Its quite sad to see there is so little interest in coding these R60's these days. There is only so much that Carly can do, and changing the VO is not one of them.
As these R60's age i figured more people would be into modding them like i'm doing now. Sort of a refresh.
Anyhow i did manage to code in the fog lights and the xenon's for both CAS/FRM using NCSExpert (On Windows 11). Although i'm still not sure if there is a VO# for LED Fogs specifically. I just used the standard $520 for fogs and $522 for Xenon headlamps.
I didnt code anything in for the rest of the LED's i put in (side markers front/rear, turning lights, tail lights, 3rd brake light), i just turned off any checks for them, so no warnings will popup.
Not sure if this is the right way to go about this or not, so i did whatever seems to work.
Also not really sure if i need to remove any VO's for the original halogen headlamps and parking lights, im sure this info is somewhere in this thread but not easy to find.
Old May 21, 2024 | 07:16 PM
  #1314
furnitremkr's Avatar
furnitremkr
Hi I am new and I just saw the post I tried
to down load the guide and got the old 404 error message is a new download link available
Bruce
Old May 21, 2024 | 07:28 PM
  #1315
Alexr54's Avatar
Alexr54
Bruce
any links on here are probably ~10 years old. They 99% won’t work.
what exactly are you trying to download?
Old May 26, 2024 | 12:15 PM
  #1316
Alexr54's Avatar
Alexr54
Oh well i would have helped however i could. But seems you don't need any help now i guess.
Im still trying to figure out how to wire the front fog lights properly so the button bank in the center console will turn them off/on.
As of now i added the VO for the fog lights (520A). Although i saw another VO for LED Fog Lights which is what i have, but didn't use that one.
I replaced the button bank with a new bank that has the fog light button in it. Plugged it in and the rest of the buttons work fine, the fog light button does nothing, i am sure because the fogs are not wired in correctly. Still trying to figure that out.
Which # in the FRM should the left/right fogs go into? Any relay? etc...
There is just no info for this online, and nno one seems to know - which kinda stinks for me.
Old Jun 29, 2024 | 10:11 AM
  #1317
Ngineluv's Avatar
Ngineluv
Help R60 Frm failure
Took my mini to the local shop for an oil/filter change and work on my cv axle. After the work, they claimed my FRM died and couldn't roll up my windows.
So now I'm searching through threads to better understand:
  1. Does the 2011 R60 have an FRM, BCM, or both? I ask because some forums that discuss FRM failure say the part number for R60s is 61356827072. But when I search OEM part vendors with my specific VIN, it says the module won't fit.
  2. Which would be the point of failure if the windows and turn signals don't work?
  3. Can I reprogram the FRM/BCM myself?
  4. What is the current software needed to code?
  5. Is there a getting started guide anywhere?
Thanks in advance!
Old Jun 29, 2024 | 11:52 AM
  #1318
Alexr54's Avatar
Alexr54
Thanks in advance!
In a R60 the BCM would be the DME. This is in the engine area where the 3 large main connectors go.
The FRM is in the cabin on the side near the pedals behind a panel. The FRM goes bad much more often than the DME.
Although bad coding can break both.
The FRM controls basically everything related to lights and windows. If this is bad your car will still start but you'll have a lot of random issues.
The DME is basically the brain of everything else. And if this is bad your car won't start, it will just click.
Most people use Carly for basic coding now. That's the easiest way.
But for more advanced coding best bet is still NCSExpert, with NCSDummy.
In use with a K+DCAN connector.
With this you still cant do things like code a DME and Program Key Fobs.
To code the DME its a bit more complicated.
You can use ISTA-P with a ICOM Next connector.
Do not attempt this using a K+DCAN connector. Its way too slow and will screw things up. While the ICOM Next uses the fiber connection, which is 100x faster then the serial OBD.
To program key fobs (i know this wasn't asked but figured i would share while i'm at it) you can use something like a XTools D8S with a KC100.
I've programmed many key fobs for my 2012 R60 with those tools.Yep, they are costly - but so is going to a dealer for a new programmed FOB. Eventually the tools pay for themselves.
Hope this helps.
Old Feb 24, 2025 | 03:20 AM
  #1319
pyth0n's Avatar
pyth0n
Hi everyone! Can please someone share working links for Mini Setup Tools 2.10.0 or newer version? Thanks in advance!
Old May 27, 2025 | 07:39 PM
  #1320
EdgardoC's Avatar
EdgardoC
Hello, i was wondering.if theres a chance for the programming basics links to be uploaded again. I wanna try to program some functions on my 2011 Countryman S.
sch
14
Feb 15, 2025 08:49 AM
BlackNorton
Aug 18, 2020 03:37 PM
VariableR58
Apr 25, 2016 02:02 PM
Carlo Recio
Jun 28, 2015 12:41 PM
z3bum
Electrical
Jul 18, 2012 07:55 PM
