Electrical Countryman-Specific Coding - R60 Guide
Old Oct 21, 2012 | 05:48 PM
  #401
Theta's Avatar
Theta
wza,
Looking at the time stamp of your PM vs post, it looks like you're all sorted out. Congrats!
Old Oct 21, 2012 | 07:46 PM
  #402
wzabrouski's Avatar
wzabrouski
What is the change to roll down, roll up windows with the keyfob?
Old Oct 21, 2012 | 07:48 PM
  #403
Theta's Avatar
Theta
Close Windows & Sunroof w/ Lock on Keyfob
KOMFORTSCHLIESSUNG_FB
aktiv
Old Oct 22, 2012 | 01:21 PM
  #404
wzabrouski's Avatar
wzabrouski
Is there any way to have fogs come on with the headlights? Also for some reason all codes worked except doors unlock when keyfob is removed?
Old Oct 22, 2012 | 03:01 PM
  #405
hyde76's Avatar
hyde76
Check your coding for a typo on the unlock with keyfob removed. I've got it working just fine.
Old Oct 22, 2012 | 03:07 PM
  #406
Theta's Avatar
Theta
Fogs on with headlights isn't possible, sadly - I was searching for that forever. I also tested a few hardware modules from previous generations - no dice.
For now, we'll have to push the button.
Old Nov 11, 2012 | 09:17 AM
  #407
TRIPLE_O's Avatar
TRIPLE_O
It is possible on BMW's with the FRM3 module.
See if you guys have SL_FKT_MIT_NSW in your FRM modules.
Old Nov 11, 2012 | 02:48 PM
  #408
wzabrouski's Avatar
wzabrouski
We do have this in our TRC file and it is set to nicht_aktiv
Old Nov 11, 2012 | 02:49 PM
  #409
Theta's Avatar
Theta
Interesting... must... try...
Old Nov 11, 2012 | 03:07 PM
  #410
TRIPLE_O's Avatar
TRIPLE_O
Please note that although the option may be in the overall trc file, does not mean your car has the option. It can only be determined if you read the FRM module and find it in there.
The coding index (which determines what options can be coded) isn't actually read until you read the module for the first time.
Old Nov 11, 2012 | 03:12 PM
  #411
Theta's Avatar
Theta
Just read v45 - we do have that in the FRM. Doesn't mean it will work, but it won't hurt to try!
Old Nov 11, 2012 | 03:15 PM
  #412
wzabrouski's Avatar
wzabrouski
If I didn't have to drag my home PC into the garage I would be all over this today. It would be awesome if this works!
Old Nov 11, 2012 | 05:47 PM
  #413
wzabrouski's Avatar
wzabrouski
No ****. It works! Warning, it does completely disable the fog light switch in the interior so you cannot turn the fog lights off. The fogs will also come on automatically with the parking lights.
Old Nov 11, 2012 | 06:13 PM
  #414
Theta's Avatar
Theta
Wow - awesome! This is going on the front page!
Old Nov 11, 2012 | 06:24 PM
  #415
wzabrouski's Avatar
wzabrouski
Triple is there anything else on the BMW side that might be compatible with the Mini's?
Old Nov 11, 2012 | 07:03 PM
  #416
TRIPLE_O's Avatar
TRIPLE_O
Sounds good, I had emailed an R60 owner and he said it worked but at that point you guys had tested it already!!
Generally, there are many options that cross over from BMW, is there something specific you're looking for?
The mini options from the first page do cover a lot of items, I just noticed the foglight one was an ongoing issue.
Old Nov 11, 2012 | 07:18 PM
  #417
wzabrouski's Avatar
wzabrouski
Auto sport mode? Rather than having to push the button.
Old Nov 11, 2012 | 07:19 PM
  #418
Theta's Avatar
Theta
That would be mind-blowing seeing as how it requires hardware on these 2nd gens. Seriously doubt this is possible, but I could be wrong.
Old Nov 11, 2012 | 08:42 PM
  #419
pyrrhusmj's Avatar
pyrrhusmj
You need a cheap laptop I had one, the screen seems to have quit working...... probably from keeping it at weird angles in the car.
Old Nov 11, 2012 | 10:11 PM
  #420
TRIPLE_O's Avatar
TRIPLE_O
From what I know, it is not possible but if I come across it, I will let you guys know.
Old Nov 12, 2012 | 10:17 AM
  #421
hyde76's Avatar
hyde76
Looking at an R57 Cabrio (2013) for my wife. Can anyone tell me where I can find coding options for an R57? I can't seem to find much of anything online.
Old Nov 12, 2012 | 10:21 AM
  #422
TRIPLE_O's Avatar
TRIPLE_O
Primarily, all of the options will be the same as the R56/R60
Old Nov 12, 2012 | 10:23 AM
  #423
hyde76's Avatar
hyde76
well, so I figured that much but specifically I'm looking for things involving the soft top, options that a hard top may not have. Unless I can code opening the top like I coded the sunroof but I would think on a convertible there would be different options.
Old Nov 12, 2012 | 10:38 AM
  #424
Theta's Avatar
Theta
Best bet would be to go the the Gen2 coding thread - I'm sure there will be sunroof options over there like in the Gen1s.
Old Nov 12, 2012 | 08:52 PM
  #425
TRIPLE_O's Avatar
TRIPLE_O
I've coded an R52 to open and close the convertible top with the keyfob but have not come across any R57 owners yet. I will tell you that on earlier BMW's (E46's and E93's) I have been able to code this as well, but after software updates BMW has disabled this feature on convertibles without comfort access (E93, E63, E88). We are still looking at some coding workarounds though.
I don't know if this feature is disabled on the R57 Mini.
