Drivetrain CAI for R56 (home made)
Old Jan 12, 2008 | 07:54 PM
  #351
byhsu's Avatar
byhsu
Which filter is the best to get? any links to where to buy it? Also the silicone tube I need to get is the 90 degree elbow 2.75 inch right.
Old Jan 13, 2008 | 03:22 PM
  #352
MiniJayhawk's Avatar
MiniJayhawk
Originally Posted by th3118
Sorry, I was out of town for the weekend.
The filter I got from PepBoys is the same as this one:
http://store.summitracing.com/partde...5&autoview=sku
Summit only show it in red, you could call and I'm sure that could get blue, if that what you want.
th3118 --- I just found these at a local auto parts store, but all of them said they were oiled. Is your filter oiled? I thought you said you were running a dry filter?
Old Jan 13, 2008 | 05:03 PM
  #353
minipete07's Avatar
minipete07
I'm running an AEM Dry-flow filter and the elbow is from siliconeintakes.com
Old Jan 13, 2008 | 05:17 PM
  #354
lxjose9xl's Avatar
lxjose9xl
What size is the elbow? I want to order from that site, but want to make sure i'm getting the right size.
Old Jan 13, 2008 | 05:41 PM
  #355
minipete07's Avatar
minipete07
3" to 2.75" reducer and you need the 3" stainless coupler.
Old Jan 13, 2008 | 05:53 PM
  #356
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
No, never said that, no problem with the oiled one, it's better to have it on a elbow, away from the MAF sensor.
It's 2.75 on the MAF end, if you find a 2.75 filter then the whole elbow can be that size. I found a 3.0 filter so I got the one the goes from 2.75 to 3.0
Don't forget the Stainless Steel Joiner.
Hope that helps.
Old Jan 13, 2008 | 07:15 PM
  #357
MiniJayhawk
Thanks! Have you ever taken it apart to see if you have oil buildup on the MAF sensor like some others have had here?
Old Jan 14, 2008 | 12:44 PM
  #358
Mini'mon's Avatar
Mini'mon
I own an R53 and I'm helping a buddy with an R56 to make a CAI.
I want to remove the plastic elbow (the one that normally goes into the stock airbox) and mount a silicone elbow on the end to go into a CAI box like Dorkboy's box from earlier in this thread.
Dorkboy told me that I could just carefully turn the elbow upward and the plastic will give enough to turn 90 degrees. However, I want to guarantee an airtight seal.
I know that the end of that tube is an oval, and a silicone elbow will conform to that shape. Does anyone know what size ID elbow I should be looking for -or- the circumference/OD of that oval at the end of the tube? I don't have access to his car and I want to order some parts today.
Thanks for your help!
Old Jan 14, 2008 | 03:55 PM
  #359
pillar's Avatar
pillar
im a little confused... isnt there a "fresh air pipe" that connects to the OEM Air Box? Should it just be left alone. If you are to not use the Air Box, what should be done with the fresh air pipe?
btw... this homemade stuff is absolutely amazing... i was just worried that it just wouldn't look as sweet but damn...
thanks guys
Old Jan 21, 2008 | 08:25 PM
  #360
bushman66's Avatar
bushman66
I ordered the Silicone Intake Parts and the 3" diameter AEM 9" Dryfilter. I'm not a big fan of oiled or foam filters, and this seemed like the best bet...and the fact that it came in under $100 for all the parts is a bonus. That's ~$200 I can apply toward my Alta Catback system...
Old Jan 21, 2008 | 10:16 PM
  #361
ghosthound's Avatar
ghosthound
if anyone wants, i have a like new K&N filter that i used around the block with this mod. It was too loud for me so i took it off and went back to stock.
Old Jan 22, 2008 | 07:14 AM
  #362
ENGINE 58's Avatar
ENGINE 58
my filter gets here today. we will talk later .
Old Jan 22, 2008 | 05:07 PM
  #363
ENGINE 58's Avatar
ENGINE 58
ok its later and wow what a sound coming out of that engine. i will try and get pics up this week.
Old Jan 23, 2008 | 03:19 PM
  #364
ENGINE 58's Avatar
ENGINE 58
ok i think my filter is too big so i ordered a smaller k&n filter. noise is just a lil crazy so i will try a different filter.
Old Jan 23, 2008 | 10:44 PM
  #365
byhsu's Avatar
byhsu
Which one did you get? 3.0" Dryflow Air Filter Short Neck 5" Element
or the 3.0" Dryflow Air Filter Short Neck 5" Element with Hole for AIT Sensor
Thanks.
Old Jan 23, 2008 | 10:58 PM
  #366
byhsu's Avatar
byhsu
OK, I need to get a an elbow for the ^ above intake, do I need a 3" to 3" ? and two clamps, for size 3", correct?
Old Jan 24, 2008 | 09:58 AM
  #367
minipete07's Avatar
minipete07
I got the 3" short neck 9" long dryflow http://www.aempower.com/ViewProduct.aspx?ProductID=320.....Also the elbow is 3" to 2-3/4" reducer http://www.siliconeintakes.com/produ...0f65c92aa54cc2...and then you also need http://www.siliconeintakes.com/produ...0f65c92aa54cc2 to hook up the filter to the elbow, it's up to you if you get the t-clamps they sell you would need http://www.siliconeintakes.com/produ...0f65c92aa54cc2 and http://www.siliconeintakes.com/produ...0f65c92aa54cc2 .....that should help!
Old Jan 24, 2008 | 10:08 AM
  #368
minipete07's Avatar
minipete07
A foam filter should make it not as loud....
Old Jan 24, 2008 | 12:04 PM
  #369
byhsu's Avatar
byhsu
Thanks for providing the links, that really helps a lot.
Old Jan 25, 2008 | 09:17 AM
  #370
ENGINE 58's Avatar
ENGINE 58
hey minipete . i did the same setup you have . silicone intakes elbow and everything. the only thing i did different was the true flow foam filter. its big. i dont have a turbo back exhaust so that filter might be a lil big for my setup. im going to save it for when i get the alta dp or in case some other company comes out with a newer and cheaper dp. the true flow filter is open on all sides so im thinking that the open end is what gives me the noise i dont want.
Old Jan 25, 2008 | 09:26 AM
  #371
ENGINE 58's Avatar
ENGINE 58
so im giving the smaller k&n a try.
Old Jan 25, 2008 | 09:31 AM
  #372
lxjose9xl's Avatar
lxjose9xl
that k&n is what i'm currently using. I really like soudn volume, not too loud, btu not too quiet.
Old Jan 25, 2008 | 01:30 PM
  #373
minipete07's Avatar
minipete07
Hey Engine58,
Well it's worth the try with the K&N..might make a little louder as i think foam quiet things up a bit...i think DDMWorks did a trial on that...but the size of the filter might have something with it...but in my eyes, the bigger the filter the better flow, you can never have to little restriction on the intake part of it!
Old Jan 25, 2008 | 02:55 PM
  #374
Terry @ BMS's Avatar
Terry @ BMS
Has anyone monitored the air intake temperatures through the OBDII system to see if the cone filter is dramatically different than the stock air box temperature wise?
Old Jan 25, 2008 | 05:24 PM
  #375
ENGINE 58's Avatar
ENGINE 58
lxjose9, that is what im after , more flow not to loud. minipete i like the way you think brother, big flow more air in , still just think i need the downpipe before i can use this filter to its full potential. i will try and get some pics up soon , it looks pretty decent . red and blue .
