Must be summer, busy here
Old Jul 9, 2008 | 05:08 AM
  #1976
BlimeyCabrio's Avatar
BlimeyCabrio
I usually do Amigo by machine, and Epic by hand. I don't see the big benefit of doing Epic by machine, personally.... a few drops at a time on a skinny applicator, and I can do the whole car in 5 minutes... over-application hasn't been a problem for me.
Old Jul 9, 2008 | 05:22 AM
  #1977
CR&PW&JB's Avatar
CR&PW&JB
I just feel I can get a thinner application and I'm less likely to miss any spots with the buffer, Paul.
But you're right about the time, it's about the same with machine as it is by hand.
Old Jul 9, 2008 | 05:45 AM
  #1978
MiniMaybee's Avatar
MiniMaybee
Does your PC get really hot - like glove wearing hot? Last weekend while using it I was really feeling the heat. I'm taking it into DP on Friday to check it out.
Old Jul 9, 2008 | 05:49 AM
  #1979
kenchan's Avatar
kenchan
before pulling out my MCS this morning i looked at the amigo apped
rear bumper in the morning sun. it's a difficult test.
nnnnnn.... honestly speaking it's only marginally better. and most
of that could be from Best of Show cause it has a lot of filling capabilities
too.
im not sure if im complete sold on the product. it looked good under
artificial light but under the morning sun it's a difficult test to pass.
if by percentage, i would give it maybe 5% improved vs non-amigo'ed
app. i think Hydro does a better job hiding light swirls (not that i use
Hydro on my hobby cars).
maybe i'll just use it on my commuters mainly.
Old Jul 9, 2008 | 05:54 AM
  #1980
BlimeyCabrio
Since I usually only do Amigo by machine, hard to say for me... and I don't rely on it to really hide significant swirls, but to get the "glaze" look (which you really only get by machine)...
Old Jul 9, 2008 | 06:11 AM
  #1981
CR&PW&JB's Avatar
CR&PW&JB
Yeah, Chuck, mine gets VERY warm. Not so hot that I can't hold it though.
Old Jul 9, 2008 | 09:31 AM
  #1982
MiniMaybee's Avatar
MiniMaybee
I had to break out my shop glove. Prior to last weekend it would get warm, but not hot. Must be time for a lube change and tune-up. It probably has over a 1,000 hours on it by now.
Old Jul 9, 2008 | 02:06 PM
  #1983
kenchan's Avatar
kenchan
no i dont think so. the finish was clean and had the just polished
glaze even by hand. but it's not enough to hide it from the sun.
Old Jul 9, 2008 | 02:16 PM
  #1984
BlimeyCabrio
Don't argue with me. I'm the ken of Amigo. You're just the ken of ken, newb.
Old Jul 9, 2008 | 02:27 PM
  #1985
Some Guy's Avatar
Some Guy
Thats why when ever I apply I Amigo by had I still work it around a little bit. You arent going to be getting anywhere close to the most you can out of it without working it at least a little bit.
Old Jul 9, 2008 | 02:28 PM
  #1986
kenchan's Avatar
kenchan
i over rank you by over 21K posts, sophmore.
*books blimey's 3-ring geek's binder*
Old Jul 9, 2008 | 02:30 PM
  #1987
ofioliti's Avatar
ofioliti
Dirty wash water fight !!!
Old Jul 9, 2008 | 02:32 PM
  #1988
BlimeyCabrio
Being more chatty (or owning more Griot's products) doesn't necessarily mean you're smarter. I should know.
Old Jul 9, 2008 | 03:43 PM
  #1989
MINIFVR's Avatar
MINIFVR
Old Jul 9, 2008 | 03:46 PM
  #1990
CR&PW&JB's Avatar
CR&PW&JB
Yeah... we all know post count is not directly related to IQ. If it were, I would have 50,000,000,000 posts to my credit.
Old Jul 9, 2008 | 04:03 PM
  #1991
MINIFVR's Avatar
MINIFVR
+1 (for me)
Old Jul 9, 2008 | 04:05 PM
  #1992
MINIFVR's Avatar
MINIFVR
I did something very bad today. For whatever reason my hose did not have the nozzle on it when I went to wash the MINI. I just shrugged it off and washed the car anyway. While I was hosing down part of the back side panel I accidentally brushed the paint with the naked hose end. Got a scratch for that. (slap on the wrist). You think I'd know by now... gotta learn sometime.
I just realized that my post above is no longer valid because of this!
Old Jul 9, 2008 | 04:26 PM
  #1993
kenchan's Avatar
kenchan
gahahahaha!!!
*hoses blimey and CRPWJB with Griot's 9position nozzle in JET mode*
that'll teach ya who's got the goods.
Old Jul 9, 2008 | 04:27 PM
  #1994
kenchan's Avatar
kenchan
dont worry noone thought it was anyway from the first place.
*kenchan shows off griot's 9position hose nozzle*
Old Jul 9, 2008 | 05:01 PM
  #1995
lotsie's Avatar
lotsie
too.
I have never thought of Amigo as a swirl remover, but a glaze.
Here is how I see it;
The products we use on our cars are like sanding and finishing wood. You start with a course abrasive, like 60 grit paper(DP Cut) then you move up to 120 grit paper(DP Swirl) then 220 grit(DP Finish) then 400 grit(DP Amigo) then you move on to the finish(DP Epic)
If you use a fine abrasive at the start on wood, like on an imperfect car paint surface, you are not getting down deep enough into the surface to remove imperfections, your just working the upper parts of the imperfections, wood or car paint.
So you need to use the most aggressive product necessary to remove the imperfection. With car finishes, the best way to get there is to work from lest aggressive to most, as you don't want to unnecessarily work the paint/clear coat.
I have been sanding, finishing wood for over 30 years, and the concepts, techniques and procedures are very similar.
Mark
Old Jul 9, 2008 | 05:14 PM
  #1996
CR&PW&JB's Avatar
CR&PW&JB
gahahahaha!!!
I admit it. I had that coming.
Old Jul 9, 2008 | 05:42 PM
  #1997
kenchan's Avatar
kenchan
lotsie- i am aware amigo cleans and fills very light swirls but does
not polish. this is why i bought the product because i dont want to
polish my rear bumper too much more; ive already removed quite a bit
of clearcoat in the past while polishing. it looks great in low light as
most cars do. but in the sun the amount of filling amigo does is only
comparable to what a typical wax can do from my findings. in fact,
i think Hydro does a better job hiding swirls.
this is why im not really thrilled about the outcome. it's like extra work
for a very minor improvement. my expectations were much higher per
the readings. that's all.
Old Jul 9, 2008 | 05:49 PM
  #1998
lotsie's Avatar
lotsie
Ken, I know you know what you want, do want to try some of my Banana Gloss, it does what I want, and may just do what you want
Mark
Old Jul 9, 2008 | 05:57 PM
  #1999
kenchan's Avatar
kenchan
yah, i think i have enough products right now.
Old Jul 9, 2008 | 05:59 PM
  #2000
Some Guy's Avatar
Some Guy
Side by side of hydro and amigo by OG. Ken you actually posted in this thread.
https://www.northamericanmotoring.co...ighlight=Amigo
