Must be summer, busy here
Old Jul 5, 2008 | 09:46 PM
  #1901
RJKimbell's Avatar
RJKimbell
Will try both Simple Green and Clay and update on the resulst.
Wish me Luck!!
Old Jul 5, 2008 | 09:52 PM
  #1902
MiniMaybee's Avatar
MiniMaybee
Just use Hydro to get off dried Hydro.
Old Jul 5, 2008 | 09:56 PM
  #1903
RJKimbell's Avatar
RJKimbell
Really?? OK, I'll try it!!
Old Jul 6, 2008 | 06:31 AM
  #1904
MINIFVR's Avatar
MINIFVR
Does anyone have a remedy for heavy wax residue?
My first coat of BW did not do much to get rid of it or hide it. Im going to put another coat on when the weather gets better. We'll see.
Old Jul 6, 2008 | 06:40 AM
  #1905
lotsie's Avatar
lotsie
You can remove wax with a 50/50 mix of water and alcohol mixed in a spray bottle. It will remove the wax, then you can treat with BW.
It's better to apply BW before you wax to prevent wax from getting on to black trim.
Mark
Old Jul 6, 2008 | 06:59 AM
  #1906
MINIFVR's Avatar
MINIFVR
Thanks. Yeah I know but the wax got on the trim 2 years ago when I was a detailing newb. Now I know what Im doing more or less so Im trying to correct my silly mistakes.
I thought of the alcohol method but I heard that it can dry out the plastic. A 50/50 mix sounds like it wouldn't be too harmful.
Old Jul 6, 2008 | 07:04 AM
  #1907
CR&PW&JB's Avatar
CR&PW&JB
Barely 10:00 and I've already washed and Hydro'd two MINIs. The other was under the car cover all week except for a nice, topless motoring trip to pick up some dinner last evening... just QD'd it.
Now, if the back muscles don't scream at me too much here in the next hour, I'm going to put my CR Cooper up on stands and paint the calipers.
Sunday... the day of worship and rest.
And hey, where's Heather ?? Why still no Banana Gloss for sale on her website ?? Hmmmmmm... too busy developing the next product, I bet.
Old Jul 6, 2008 | 07:13 AM
  #1908
MINIFVR's Avatar
MINIFVR
I wish I had the problem of washing 3 MINIs! We have had a rainy holiday weekend up here in PA so I haven't been able to wash the MINI in like 5 days. That may be a record.
  #1909
kenchan's Avatar
kenchan
the hotter it gets outside the earlier i go motoring and come back.
it was 70F already at 6:30am today when i pulled out my G. when i
got back it was only 72F, but i could feel the sun coming down pretty
hard. QD'ed and Clarity'ed. motoring was fun, car looks
great.
going to rotate the front tires later on today and pull her out for a
quick spin to re-torque the lugs. then Slick the wheels and
dust the interior.
oh yah, my G reached 20K miles today.
  #1910
ofioliti's Avatar
ofioliti
Originally Posted by RJKimbell
Yes...Hydro...apparently I oversprayed and did not notice it until it dried!!
I think miniyabee was suggesting that you spray Hydro on the spot to try to get it off.
Edit: didn't see the reply; you got it.
Old Jul 6, 2008 | 07:18 AM
  #1911
ofioliti's Avatar
ofioliti
And you might have to make several passes. After rubbing off once, let dry completely and see if you still have the white stuff. If so, rub again with the alcohol. Repeat.
Old Jul 6, 2008 | 07:20 AM
  #1912
MINIFVR's Avatar
MINIFVR
It is turtle wax that is on there too. I remember when I put it on. Careless to say the least. Oh well, you have to start somewhere I guess.
Old Jul 6, 2008 | 08:36 AM
  #1913
lotsie's Avatar
lotsie
I can't wait much longer, I NEED it
Mark
Old Jul 6, 2008 | 08:42 AM
  #1914
MINIFVR's Avatar
MINIFVR
What is banana gloss for?
Old Jul 6, 2008 | 09:54 AM
  #1915
CR&PW&JB's Avatar
CR&PW&JB
It's a wax but one that has some carnuba in it to add some deepness to the shine. It'll be especially great for dark colors (like CR and JB). It doesn't have a long life, like Epic, so you'll want to apply it over top of the Epic, about every two months.
Okay... got the calipers painted and they're curing. While I had the wheels off, gave them a good scrubbing on the back side.
I'm tired and my back hurts. But it'll be worth it.
Old Jul 6, 2008 | 10:10 AM
  #1916
lotsie's Avatar
lotsie
OK, I'm done working in the gardens, now it's time to wash/wax/swap some wheels, then clay/Amigo/Banana Gas Poco's roof. I have some of the test product left to get his roof done.
I need more BG
Mark
Old Jul 6, 2008 | 10:47 AM
  #1917
kenchan's Avatar
kenchan
got the front wheels rotated on my G and took a quick test drive to
check noise and vibration. found no prob.
while the wheel was off the car, i inspected for any leaks and checked
the joints, etc. i like how clean her underside is.
re-torqued the lugs. going to slick the wheels later on today.
Old Jul 6, 2008 | 11:56 AM
  #1918
MINIFVR's Avatar
MINIFVR
Then you shouldn't have scrubbed your back(side) so hard then.
Old Jul 6, 2008 | 11:57 AM
  #1919
BlimeyCabrio's Avatar
BlimeyCabrio
Went by Harbor Freight today and got this:
and this:
Wifey's Town & Country had a check engine light from an evaporative system leak (possibly loose fuel cap). I was going to clear with my ScanGaugeII, but for some reason I can't get the ScanGauge to sync with the T&C. Baffled the folks at LinearLogic also. And the folks at AutoZone will read the codes, but won't clear them. WTF.... So the new HF scan tool worked great, read the codes in plain english, and let me clear them. No more CEL. Yeah. This is a nice little fairly inexpensive code scanner...
And ken was right - the infrared thermometers are addictive.... I was running around measuring the temperature of EVERYTHING in sight.... I got it both to check temps on various car parts, and also to check tire temps for proper inflation and alignment guidance. Pretty cool.
Old Jul 6, 2008 | 11:59 AM
  #1920
MINIFVR's Avatar
MINIFVR
Not bad. Thats pretty nice! ^
Old Jul 6, 2008 | 12:01 PM
  #1921
MINIFVR's Avatar
MINIFVR
I also bought some stuff for the MINI today. I was not planning on buying anything until the spring but ALTA was having a 10% off sale so I picked up a 15% and 539 belt, and some colder NGK's from JSCspeed. Probably won't get them installed for a few months though.
Old Jul 6, 2008 | 02:20 PM
  #1922
lotsie's Avatar
lotsie
Wheels are almost done, just need to wax 1 more then mount them. The wheels on the car, not me on them
Mark
Old Jul 6, 2008 | 02:31 PM
  #1923
kenchan's Avatar
kenchan
lotsie- yah, those IR thermometers are cool. just make sure you dont try measuring
reflective things like mirrors or chrome cause that laser can bounce off and hit your eyes.
Old Jul 6, 2008 | 02:36 PM
  #1924
BlimeyCabrio
Don't give lotsie credit for my credit card debt, sucka.
Old Jul 6, 2008 | 03:07 PM
  #1925
ofioliti's Avatar
ofioliti
OK, got the new wheels on. I likey!
Here's a pic. Will post more later ... gotta do some more yard work.
