Navigation & Audio OEM navigation upgrade-Hopefully a how-to guide.
Navigation & AudioAudio upgrades, bluetooth, and navigation discussions surrounding the Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs.
Hello!
My name is Sandro, from Rome.
First of all, I would like to thank you guys for the big work you shared. You encouraged me to try to install a sat nav (and combox) by myself on my 2008 Mini Cooper.
I looked for some schematics on the web...uselessy.
This is my problems: I have a "quadlock (?)" connector for the radio and an AV in connector, with cutted wires (see pictures).
I would like to identify every wire before removing my OEM boost cd.
Anyone knows where I could find schematics?
Tank you very much.
I used the diagram on page four on this tread. My Mini did not have a AV plug so I don't know what all the wires are. Did you try to go to the dealer and ask them for a printout.
You will need a new Navigation radio and emulator. Or you can purchase the FSC codes from the dealer but it is super expensive and most will tell you that it cannot be done.
So my current screen will work? Just trying to decide if I'm going to go for it.
Okay, I have a 2008 Mini Cooper Clubman S. So my factory upgrade is the CCC unit. I have someone who can code all the codes. Do I need the emulator? Or is that just for the CIC model?
I have factory BT and and voice
I see in thr post above me you guys say it's needed, but what does it do, that the coding can't do?
Hi, why upgrade to the slow CCC when you can upgrade to the champ2 unit ?
Price are the same but not for the same result !
With the CCC you don't need the emulator as it's only for FSC based system.
Whats the actual advantage of the newer one? Where specifically did the emulator go?
I figure it should be cheaper to go CCC as I just need the Speedo and the DVD/brains as I already have the combo box. I haven't been able to find a good comparison of the 2 Nav units, and both are up-to-date maps.
1. Does anybody have the wiring diagram for the CCC? (So not the one on page 4/ I dont have a combox)
2. Does anybody have the part number for the 12 pin connector that goes in the back of the screen?
3. Does anybody know how I can get my navi and parking sensors to work together? (instead of getting a fealure every time I reverse)
I think I can help with two of th4ese:
1. wiring diagrams. I was going to post a link to the wiring diagrams at bmw-planet.com, but it appears the site is down. I do, however, have PDFs/images I saved from the diagrams I used when retrofitting my 2009 CCC system, attached below.
In particular, here's the wiring diagram for the back of the radio/CCC head unit:
2. 12-pin connector. I don't have a part number but I did find one courtesy of eBay and a salvage yard in Lithuania. The seller I used appears to have a current listing for it: http://www.ebay.com/itm/BMW-CCC-Navi...kAAOSwpDdVKIX6
It says BMW but it's the same part.
(It is not possible, as far as I can tell, to order the connector itself from MINI/BMW.)
On #3 I'm not sure; in theory if the car has been coded with the sensors they *ought* to simply work.
Originally Posted by ThomasvdB
That would be about it for now. Sorry if my English sucks but it's not my native language.
Your English is better than a lot of people who grew up allegedly speaking and writing it.
You earned yourself some very positive karma points
Thanks a lot!
Hi everyone. Im interested in doing this retrofit also. I have a 2011 mcs, I've been reading and reading this thread and I am still a little confused on a few things. First I keep hearing ccc and cic I'm guessing that the different models of radio? When I do this the spedo with the screen does it have to match ccc or cic or is that I guess a universal part? Sorry if this is a dumb question. Just trying to understand as much as I can before tackling this project.
