Navigation & Audio OEM navigation upgrade-Hopefully a how-to guide.
Old Nov 16, 2015 | 01:55 PM
  #101
Awesome, looks like the combox is functional, you might have a mic already in the upper console wired ? Did you see one there ? On newer MINI i think its prewired.
Old Nov 17, 2015 | 05:07 AM
  #102
ahorvath's Avatar
ahorvath
I had Bluetooth installed with my boost/cd so all I had to do is extend the wires from the radio connector to the combox.
Combox Media 26 POL connector wiring:
1 Power T30
14 Ground
10 AUX GND
23 AUX NF L
24 AUX NF R
22 AUX BLNC
25 MIC+
12 MIC-
11 MIC BLNC
Old Nov 17, 2015 | 05:59 AM
  #103
Great, did not know if you had that option ordered. This is a great how to.
Old Nov 19, 2015 | 12:02 PM
  #104
ahorvath's Avatar
ahorvath
Anybody looking for a emulator this one enabled all the options on my retrofit and it only cost $46.00.
http://www.aliexpress.com/item/New-C...724382900.html
Old Nov 21, 2015 | 07:43 AM
  #105
ahorvath's Avatar
ahorvath
Retrofit success.
After the FSC emulator install everything is working as it should. I was able to update the map to the 2016 version, voice control works and now I have SiriusXM and Mini Connected.
Old Nov 21, 2015 | 08:15 AM
  #106
orionrs's Avatar
orionrs
Originally Posted by ahorvath
Retrofit success.
Congratulations!!
I hope many pictures and comments of the installation, and also get the parts to be mounted soon in mine .
Old Nov 25, 2015 | 06:11 AM
  #107
vikislap's Avatar
vikislap
Navigation retrofit
Hi I start my project .... Retrofiting navigation to my base all4 countryman.
Have one question I have already connected ccc and screen but screen does not show any pict. Just get white for the while and some lines I can see on it . Today I will go to coding it to my car but do you have expirience if you plug it and power up its should work or need to programed first to your car because I just thinking that screen is bad...? Thanks for any help or suggestion
Old Nov 25, 2015 | 06:47 AM
  #108
ahorvath's Avatar
ahorvath
You don't need to code the car for the screen to turn on. I did all my coding on the end. Make sure all your connections are good and all cables are connected as the second pictures shows on page 4 on this tread. Check your 8 pin connector on the side of the screen.
Old Nov 25, 2015 | 07:10 AM
  #109
vikislap's Avatar
vikislap
Thank you so much for your fast respod but do I need the combo box? I mean I prited out wiring diagrams and I connected the connector on back of screen 12 where is just 4 connected and the side connector which is 10 with sheeld gos to the ccc unit. But nothing no luck. I mean its same if the side 10 pin con. Is connected.
Old Nov 25, 2015 | 07:11 AM
  #110
vikislap's Avatar
vikislap
Looks like the screen is bad ....
Old Nov 25, 2015 | 07:27 AM
  #111
ahorvath's Avatar
ahorvath
No you do not need the combox for the screen to work but you will need one if you want Bluetooth or USB/aux to work. Are you retrofiting a CCC or CiC?
Old Nov 25, 2015 | 07:38 AM
  #112
vikislap's Avatar
vikislap
I had regular radio and cluster so I instaled new cluster with screen cluster works good. And also the cd navi unit replaced my old cd radio unit .... And the joystick in midle.
Joystick works radio works but no screen yet ... The ccc was oem from countryman and screen was older R56 maybe thats why does not work? But screen its just screen it should work right?
Old Nov 25, 2015 | 09:50 AM
  #113
ahorvath's Avatar
ahorvath
No there is two versions of the screen. What year was the countryman and what year was the R56?
Old Nov 25, 2015 | 09:58 AM
  #114
vikislap's Avatar
vikislap
I am sure that the dvd unit was countryman 2012 and screen/cluster was from 2009 but those statement about fitment said its fit countryman too. But you know they can say what they want.
Old Nov 25, 2015 | 01:25 PM
  #115
vikislap's Avatar
vikislap
The creen ser.num fg/25521/000al8c3316141
P/num 3451496
Fsv:c6.30.01
Old Nov 25, 2015 | 01:49 PM
  #116
ahorvath's Avatar
ahorvath
The problem is that the Radio is a CIC and the screen is CCC they are not compatible with each other. They both fit in the countryman but they are two different versions of the navigation system. If you want to keep the radio than you will need a screen that have this connectors on the side. You will also need the display cable from my post on the 4 page of this tread.
Old Nov 25, 2015 | 01:50 PM
  #117
ahorvath's Avatar
ahorvath
Make sure that the screen is from a 2011 or newer Mini.
Old Nov 25, 2015 | 02:07 PM
  #118
vikislap's Avatar
vikislap
The problem is that the Radio is a CIC and the screen is CCC they are not compatible with each other. They both fit in the countryman but they are to different versions of the navigation system. If you wan to keep the radio than you will need a screen that have this connectors on the side. You will also need the display cable from my post on the 4 page of this tread.
Wow I see perfect thanks for your help ...
I will order the screen originaly from countryman and I will return this parts to get refund..... I am more familiar with audis and vw this is my wifes car...
Old Nov 25, 2015 | 03:27 PM
  #119
vikislap's Avatar
vikislap
Hi just one more thing the red video cable I found one but what is the black connector it is power ground and can bus ? Thanks Vik
Old Nov 25, 2015 | 04:04 PM
  #120
ahorvath's Avatar
ahorvath
Yes Pin 1 is 12v, Pin 3 Ground, pin 5 Can Low, Pin 6 Can High. The CAN cables have to be connected to the back of the radio and the joystick. Also if you want navigation, voice control, Bluetooth, satellite radio and presets to work you will need an emulator between the radio and the other CAN bus cables. I posted a link for the one I ordered it was only $46 and it works perfect.
Old Nov 25, 2015 | 04:38 PM
  #121
vikislap's Avatar
vikislap
You are the Man,
Thanks for all help I will let you know how I am doing with it... And Happy Thanksgiving day...
Old Nov 26, 2015 | 01:24 PM
  #122
vikislap's Avatar
vikislap
Hi,
How are you today ? So I did order the emulator like you said and tomorrow will get the cable and order for screen but not sure if I will order the screen if its gonna fit the speedo or have I return all and buy new screen with speedo( they are selling it separetly and I can keep this old just replace the screen. Could you please verify it for me?
Thanks Vik
Old Nov 26, 2015 | 02:22 PM
  #123
ahorvath's Avatar
ahorvath
Where are you getting your parts from?
Old Nov 26, 2015 | 02:39 PM
  #124
vikislap's Avatar
vikislap
Some parts from car-part.com some on ebay some like wiring here I'm working in garage we are buing car from auctions after accident for parts and send them over sea.. Bmw, audis mb and lot more.
We have mini but no countryman yet ...
I do electrical work and diagnostig some programing
Old Nov 26, 2015 | 03:19 PM
  #125
ahorvath's Avatar
ahorvath
I would get a new speedo with the screen because I can't tell you for sure if it will fit your old speedo. I saw some on car-part.com for $125 with the screen. Just an FYI do not clean the screen with Windex it will take off the anti glare coating from the screen. I learned the hard way.
