Navigation & Audio OEM navigation upgrade-Hopefully a how-to guide.
Old Dec 3, 2015 | 08:39 AM
  #126
vikislap's Avatar
vikislap
Originally Posted by ahorvath
I would get a new speedo with the screen because I can't tell you for sure if it will fit your old speedo. I saw some on car-part.com for $125 with the screen. Just an FYI do not clean the screen with Windex it will take off the anti glare coating from the screen. I learned the hard way.
Hi so I have instaled new speedo with screen same as you said and cable for screen from dealer for 44$ and all is on ... Now just waiting for emulator and grey speedo disc with km/h and I hope all will work great. Thanks again fr your help...
Old Dec 7, 2015 | 06:48 AM
  #127
orionrs's Avatar
orionrs
@ahorvath
Could you explain how do you coded???
Thanks!
Old Dec 7, 2015 | 07:16 AM
  #128
vikislap's Avatar
vikislap
Originally Posted by orionrs
@ahorvath
Thanks!
Hi,
I am waiting to get emulator this thursday so will do the coding friday or monday and let you know I can also take some pictures
Cheers
Old Dec 7, 2015 | 07:18 AM
  #129
orionrs's Avatar
orionrs
Originally Posted by vikislap
Hi,
Cheers
I would be so grateful!
Good luck!
Old Dec 7, 2015 | 07:25 AM
  #130
ahorvath's Avatar
ahorvath
First you will need a ICOM or OPS with MOST connection do not try it with OBD it will fail and it takes a week before it fails. I used NCS expert to edit the VO added the following options adjust to your need. I installed a Champ2 navigation system and combox for Bluetooth phone, A2DP and USB/AUX input.
Add to VO
$6FP – Mini Visual Boost
$6NE – Bluetooth and USB Audio
$6NF – Smartphone Integration
$6NM – Mini Connected
$6UH – Traffic Information
$6VC – Control Combox
$6UM – Mini Navigation System
Remove from VO
6ND – Bluetooth Hands Free Interface
6FC – Radio Mini Boost Cd
After the VO is correct I used winkfp to edit the VIN number on all the parts that I changed. Again use only MOST connection to do this. There is a program on the net called Easy Connect that will setup your Ediabas to work with the ICOM. I am not sure if you have this or not. PM me if you need it. After everything was coded I used ISTA/P to sync everything. ISTA will complain that you need to replace everything that you just put in ignore it and continue. Here is a good link with pictures how to do this.
http://www.bmwcoding.com/showthread....na-clone)-MOST
Old Dec 8, 2015 | 07:46 AM
  #131
orionrs's Avatar
orionrs
Add to VO
Remove from VO
Hey there,
It is impossible to codify with NCS Expert ?
I don´t have ICOM and see that it is an expensive cable.
My CIC is in French and I need it in Spanish . ICOM also need ?
Sorry for my bad English and thanks for your help!!
Old Dec 8, 2015 | 03:10 PM
  #132
ahorvath's Avatar
ahorvath
I think there is a way to change the VIN with Tool32 but I couldn't find a tutorial on how to do it. You can change the language under settings on the CIC. You should have Spanish if not you will need to code it and you will need a ICOM with MOST connection no other way.
Old Dec 9, 2015 | 02:38 PM
  #133
orionrs's Avatar
orionrs
Where do you put the Most connection??
Thanks a lot!
Old Dec 9, 2015 | 04:41 PM
  #134
vikislap's Avatar
vikislap
Hi, so I have instaled emulator today and hope I will do the coding this friday ... Could you please tell me after emulator instaled should work some more thing's ? Or now I need to coding it to get all that things like navi bluetooth to work?
Thanks Vik
Old Dec 9, 2015 | 06:19 PM
  #135
ahorvath's Avatar
ahorvath
You will need to code the car and add all the options to the VO. After that you should have Navigation, Voice control (if your car had this before), Mini Connected and you should be able to save the radio stations under preset. If you are in the USA SiriusXM should be available also.
Old Dec 9, 2015 | 06:21 PM
  #136
ahorvath's Avatar
ahorvath
On the back of the radio you will see to fiber optic connectors one will be glowing red and the other will be blank. This is the most connector.
Old Dec 12, 2015 | 10:03 AM
  #137
vikislap's Avatar
vikislap
Hi, just would like to asko you one more thing I have ista p eom bmw do you think its gonna work we do all programing on bmw with this ? I just newer try it before on mini so I will work on it monday hope I can do what I need
Old Dec 13, 2015 | 05:31 AM
  #138
ahorvath's Avatar
ahorvath
Yes you can use ISTA-P but it will not change your VIN# in the new parts if you want to change the VIN number use WinKFP or Tool32. ISTA will tell you that you have to replace everything that you just installed try to skip the messages eventually it will work.
Old Dec 15, 2015 | 01:46 PM
  #139
orionrs's Avatar
orionrs
I have a cuestion. The CIC takes 2 USB original , but in the electric plane only see one.
CIC - Glove
Combox - dashboard
It is correct?
Old Dec 15, 2015 | 05:06 PM
  #140
ahorvath's Avatar
ahorvath
Yes the one in the glove box is for map updates and the one from the combox to the dash is for phone communication and charging.
Old Dec 16, 2015 | 10:38 AM
  #141
+1 glove box is the USB map update for the Newer nav units. Older ones used the DVD / CD.
Old Dec 16, 2015 | 02:42 PM
  #142
orionrs's Avatar
orionrs
Where do you put the most conection? And where the Bluetooth antena?
Thanks and sorry for all questions
Old Dec 16, 2015 | 07:07 PM
  #143
ahorvath's Avatar
ahorvath
MOST connects to the back of the radio and the Bluetooth antenna connect to the combox.
Old Dec 17, 2015 | 06:23 AM
  #144
orionrs's Avatar
orionrs
Yes, but, where do you conect the ICOM? the optic fiber go directly CIC to Combox
The Bluetooth antena I know that conect in the combox, but, where it is placed?
I ask forgiveness for my language
Old Dec 17, 2015 | 03:25 PM
  #145
ahorvath's Avatar
ahorvath
Sorry for the horrible drawing but I just did this quick. So you will need to make a fiber connection between the radio and the combox. Also you will need a loopback adapter for it so when you disconnect the ICOM you connect the loopback in place. My bluetooth antenna is installed under the hand break right above the airbag controller.
Old Dec 22, 2015 | 01:07 PM
  #146
orionrs's Avatar
orionrs
Thanks a lot!
I only need;
Bluetooth Antena and wire
Optical Fiber Cable (from globebox to Combox)
Plastic box under the front seat.
Thanks!
Old Dec 24, 2015 | 07:51 AM
  #147
ahorvath's Avatar
ahorvath
The Bluetooth cable is discontinued by MINI so I had to find it online at this place https://www.pasternack.com/. Look at Ebay for the plastic box I saw some for cheap. Ebay also have the optical cables.
Old Dec 24, 2015 | 08:22 AM
  #148
Which one ? Whats the part number?
Old Dec 26, 2015 | 04:28 AM
  #149
orionrs's Avatar
orionrs
This optical fiber is oK?
and, I need this?
Thanks!
Old Dec 26, 2015 | 02:27 PM
  #150
ahorvath's Avatar
ahorvath
Yes that looks correct. You will need one more longer cable going to the combox.
