Navigation & Audio OEM navigation upgrade-Hopefully a how-to guide.
Old Feb 5, 2016 | 08:08 AM
  #176
ahorvath's Avatar
ahorvath
In your VO do you have $620 if you don't just add it and that should fix your voice control issues.
Old Feb 20, 2016 | 09:56 AM
  #177
orionrs's Avatar
orionrs
I have news about my CIC retrofit.
This morning I instaled the Combox with the bluetooth antena. I pass the USB cable, Combox cable and optical fiber cable to the foot rest.
I am very afraid of making a mistake.
Any advice?
@ahorvath , what do you thing about bluetooth antena position?
Old Feb 21, 2016 | 12:04 PM
  #178
ahorvath's Avatar
ahorvath
It should work our cars are small so I don't think it will be a issue. My antenna is under the center console which is covered with plastic same as the box cover. I see you have a Chili red Mini I have the same color.
Old Feb 21, 2016 | 01:33 PM
  #179
orionrs's Avatar
orionrs
Yes! this is my chili red
I´m worried about the 26 pin Combox conection. I have doubts about how take off the pines of aux and mic from the radio conection.
Old Feb 21, 2016 | 03:11 PM
  #180
ahorvath's Avatar
ahorvath
Very nice here is a picture of mine.
You don't have to remove the pins you can splice the wires together if you want. I have a pin removal tool set so it was not a big deal to remove the pins. It is a pain with out the tools.
Old Feb 22, 2016 | 12:47 PM
  #181
orionrs's Avatar
orionrs
Beautiful chili red and black!
This weekend I continue the work!
Old Feb 27, 2016 | 11:49 AM
  #182
orionrs's Avatar
orionrs
News,
I installed today the centre tunnel with Idrive.
@ahorvath I have doubts about the BLNC wire of AUX and MIC, it´s a normal wire???
Old Feb 27, 2016 | 12:37 PM
  #183
ahorvath's Avatar
ahorvath
Originally Posted by orionrs
News,
Yes, the BLNC wire is a regular wire with thicker than normal outside cover. I used speaker wire for it.
Old Mar 4, 2016 | 01:19 PM
  #184
Dimitris Sofianopoulos's Avatar
Hello everyone,i retrofited a cic unit to my car and i would like to retrieve the vin from the cic unit in order to get an fsc code so i can update the maps, any ideas? Apart from this I try to retrofit a combox now, the combox harness one side i bought the connectors and i can see the order of the cables, the other side how is connected to the cic unit and where does the mic connects to. sorry for my ignorance, i am doing my first steps on this!
Old Mar 5, 2016 | 11:16 AM
  #185
ahorvath's Avatar
ahorvath
You don't have to connect the combox other side to the CIC only to the mic and the AUX connector.
Old Mar 5, 2016 | 01:48 PM
  #186
orionrs's Avatar
orionrs
@ahorvath sorry for another question.
What pin of the main conector is for;
10 AUX GND
23 AUX NF L
24 AUX NF R
My wires don´t have the colour of the scheme
I have; Grey, Brown, White
And, in my car I only have a BLNC wire from the MIC, I don´t have BLNC wire in AUX, It´s normal?
Thanks!!!
Old Mar 5, 2016 | 01:51 PM
  #187
orionrs's Avatar
orionrs
Today work
Old Mar 7, 2016 | 05:31 AM
  #188
orionrs's Avatar
orionrs
All working ok
I don´t have to code by ICOM, all working OK
Old Mar 7, 2016 | 06:03 AM
  #189
ahorvath's Avatar
ahorvath
Congratulation, great job enjoy your new system.
Old Mar 7, 2016 | 07:31 PM
  #190
bratling's Avatar
bratling
Super Moderator
All working ok
Very nice! enjoy the fruits of your determined work! :-D
Old Mar 15, 2016 | 06:24 AM
  #191
FlipnMinnie's Avatar
FlipnMinnie
All working ok
What did you have before? The stock speedometer with no nav?
Old Mar 15, 2016 | 01:54 PM
  #192
orionrs's Avatar
orionrs
Yes, Mini Boost CD
Old Mar 27, 2016 | 05:54 AM
  #193
sveenn's Avatar
sveenn
Hi. I would like to upgrade my speedometer too. But I'm unable to find a speedometer with the cut-out for the screen. Do you have any advice for me what keywords I need to use in my parts search?
Old Mar 27, 2016 | 06:01 AM
  #194
bratling's Avatar
bratling
Super Moderator
Try searching eBay for Mini Cooper R56 nav speedometer or Mini Cooper R56 nav. There were a couple of them listed a few weeks ago.
Or, I have one I'd be willing to sell — I bought some extra parts while doing my install. It's not cosmetically flawless but it works fine. Let me know if you want pics.
Old Mar 27, 2016 | 08:44 AM
  #195
ahorvath's Avatar
ahorvath
There are two kind of screens one for the CCC and the other is for the CIC. Make sure that it is for the right radio. If you have the black radio single unit than you have a CIC if you have the double unit than it is a CCC.
You can also look for the screen at Car-Part.com.
This is a CCC unit from 2010 or older Mini R56
Old Mar 28, 2016 | 05:00 PM
  #196
Black-eyed-Purple-Mini S's Avatar
Glad to have this post. Very informative, just wish I could get someone to do this for my MINI.
Old Apr 1, 2016 | 10:12 AM
  #197
Everything is ok! will add pics later!
Old Apr 15, 2016 | 10:35 AM
  #198
Velcro combox to floor
Old Jun 7, 2016 | 05:08 PM
  #199
jigo's Avatar
jigo
I'm starting to get the parts to do the Nav upgrade, but am unsure on the radio I got.
It's from a 2011 R60 with a 1/20/2011 production date.
From the vin it shows it had option 606 Navigation System Business not 6UM Mini Navigation System.
Any idea if this will work?
Old Jun 7, 2016 | 06:04 PM
  #200
ahorvath's Avatar
ahorvath
Exactly the same unit I installed in my retrofit. I think you will be fine. I still don't know what is the deference between 606 and 6UM it has Mini connected, it uses the same combox and same screen. I think somebody just changed the code or something.
