Official MINI DRLs Fitted
Old Jan 16, 2014 | 08:01 AM
  #551
MikewithaMini's Avatar
MikewithaMini
I tried....It doesn't work so good, least for me. Was think of getting a spec to Lamin-X to see if they need to do a special cut. The globe is deeper on the DRL based on the fit of the fog Lamin-X. It doesn't reach the edge and heat will be a requirement and perhaps thickness.
Old Jan 16, 2014 | 08:06 AM
  #552
Mike- Thanks for the info, I did not know if anyone tried that yet with the DRLs. So its a bit short and using a heatgun did not work ? How short is it, maybe it covers most of it would you say?
Old Jan 16, 2014 | 08:19 AM
  #553
MikewithaMini
It does cover most of it and I can see that if proper heat were applied and one has 3 or 4 hands, you may be able stretch it just to the edge. Ideally if it were larger, one could stretch it and trim off the wrinkle. Centering a cold one up I'm guesstimating from recollection between a 1/4 to 1/2" - 5/16"? - shy of full coverage. I had trouble getting it to flatten on the globe due to the roundness with a heat gun which I'm sure is at least partially user error. I was working with the DRL unmounted, straight out of the box. The Lamin-X piece I was using was the one that comes provided with the headlight w\washer kit for the R56.
Old Jan 16, 2014 | 08:45 AM
  #554
Yea, the heat and working it will helps with the contour and the curve, you almost have to stretch and press. Might get it to the edge.
The R56 headlight / fog kit uses the same piece in just the fog-lights. There are larger sheets which people use for custom applications. That would work well with the stretch and cut approach.
Here in the universal lamin -X. That way you have room to play.
http://www.ecstuning.com/Search/SiteSearch/Lamin-X_Universal/
Old Jan 16, 2014 | 09:13 AM
  #555
TJANK's Avatar
TJANK
Originally Posted by cerenkov
Ah, my connector is different. It has a non-removable (at least I think not is non-removable) cover that makes it impossible to tell which wire goes to which pin. I flat out guessed.
I thought the same but that cover is removable. It slides off to show all the wires.
Old Jan 16, 2014 | 12:21 PM
  #556
stash182's Avatar
stash182
Has anyone tried messing with NCS Expert? It would be cool to have the rings stay on for a minute after locking doors or shutting off the engine as well as full rings with headlights.
Old Jan 16, 2014 | 12:36 PM
  #557
SuperGreg's Avatar
SuperGreg
FWIW, full rings with headlights would be WAY too bright for oncoming traffic.
Old Jan 16, 2014 | 12:38 PM
  #558
stash182's Avatar
stash182
You think? they seem as bright as bimmer angel eyes which run w/ headlights.
Old Jan 16, 2014 | 01:38 PM
  #559
SuperGreg's Avatar
SuperGreg
They are much much brighter than BMW halos
Old Jan 16, 2014 | 04:44 PM
  #560
KilmerPT's Avatar
KilmerPT
+1. I see beemers everyday on my commute, these MINI halos are definitely WAY brighter.
Old Jan 17, 2014 | 11:19 AM
  #561
tigerwong58's Avatar
tigerwong58
I just ordered mine $ 625 installed, $ 425 for the hardware, $ 200 labor (2 Hours).
Old Jan 17, 2014 | 12:46 PM
  #562
komet155's Avatar
komet155
I feel your pain. My Cooper is a daily driver and my only car so I'm going to make sure I'm familiar with everything I need to do in advance so I dont have to spend time with the front end in pieces figuring out what to do next and how. Properly mounting that control box is a major concern because I don't want to just zip-tie it to the fuse box so you have to cut them to open the lid. I bought a used fuse box real cheap on ebay and am trying to figure out a neater way to strap it to the side while keeping the lid clear.
It's just as well my set of lights isn't even on it's way yet, gives me more time to prepare.
This talk of 3 hr install time gives me an inferiority complex. 11pm - 2am last night i spent on just the wiring set up. wipers wouldnt come off without a fight and don't get me started on squeezing that control box next to the fuse box.
just too busy to tackle the JCW bumper removal... might bite the bullet and have the mechanic finish it. already removed my rally lights / grill. Hopefully theyll cut me a deal for all that prep. With the money I saved on my group buy, I'll put toward the mechanic. hope i can drive my car with all this stuff removed / loose.
Just not the DIY'er I used to be with all of life's responsibilities! Wish Milwaukee had the Dallas DIY community.
Old Jan 21, 2014 | 10:11 AM
  #563
stash182's Avatar
stash182
Lol, you'll be fine buddy. That UK install guide is clutch. wouldnt worry about the zip ties. if you manage to fit it next to the fuse box, itll be in so tight you won't need them or the double sided tape.
Old Jan 21, 2014 | 10:13 AM
  #564
stash182's Avatar
stash182
I concur. Didn't actually look at them head on til yesterday when i tried photographing them and realized they're blazing. Still, it'd be nice to have them come on when you lock / unlock the car.
Old Jan 21, 2014 | 12:19 PM
  #565
KilmerPT's Avatar
KilmerPT
The top section turns on when you unlock the car via key fob
Old Jan 21, 2014 | 12:29 PM
  #566
MikewithaMini
I was unable to fit the control module between the shock tower and affixed to the fuse box. I had to go on the engine side of the controller. I couldn't even slip it in with the fuse block loosened, kind of sandwich them down together. I have not yet installed the lights themselves say I can't go ooooo yet. I did discover that the gray wire on pin 12 is the same wire that is requested by the extra driving lights. I'm hoping since I don't yet have the lights installed that is the reason I don't have brights and the extra driving lights depend on the brights to work. I have an aero II bumper with brake duct kit ready to install and that is when the lights go on!
Old Jan 21, 2014 | 12:44 PM
  #567
stash182's Avatar
stash182
yeah but that top 1/4 section is real meh. i'll just have to get my "standing outside the car" lighting kicks by installing some ghost lights under the doors. gotta stop there before i go all ricer on this.
Old Jan 21, 2014 | 02:51 PM
  #568
KilmerPT's Avatar
KilmerPT
Post pics when it's done!
Old Jan 21, 2014 | 02:52 PM
  #569
KilmerPT's Avatar
KilmerPT
Those are really neat; me likey!
Old Jan 25, 2014 | 04:34 PM
  #570
MikewithaMini
I have gotten mine installed today. I have a problem I thought I would quiz you guys on before tearing back in to it. I've got no halo. I've disabled the running lights.
0 - nothing.
1 - top half
2 - top half
Fogs work.
Extra driving lights work with Hi beam as they should.
Blue wire is to gray at pin 12 which is also the same wire that controls the extra driving lights. I'm going to have to guess that I didn't get a good connection at pin 12?
Old Jan 25, 2014 | 05:08 PM
  #571
MikewithaMini
0 - nothing.
1 - top half
2 - top half
Fogs work.
That was it! Smashed the wire connector again and it clicked. Works like a champ!
Old Jan 27, 2014 | 12:06 PM
  #572
MikewithaMini
I like!
Old Jan 27, 2014 | 12:18 PM
  #573
SuperGreg's Avatar
SuperGreg
I like!
very nice!!
Old Jan 27, 2014 | 12:30 PM
  #574
MikewithaMini
very nice!!
Thanks Greg! I'm now debating extending the stripe, leaving it as is, or , taking it off and getting what I've been told are "Corvette Stripes." Two hashmarks just above the wheels at an angle on both sides, then leave the back, which matches the front all the way to the diffuser. Whaddya think?
Sorry - off topic.
Old Jan 27, 2014 | 12:41 PM
  #575
KilmerPT's Avatar
KilmerPT
I like!
Looks great!
