Official MINI DRLs Fitted
Old Jul 8, 2014 | 01:59 PM
  #651
We have them in currently stock if anyone is looking for them.
http://www.ecstuning.com/Search/SiteSearch/63122338554/
TheZlog- post up some pics when you get them installed. They will look great.
Old Jul 8, 2014 | 06:08 PM
  #652
walk0080's Avatar
walk0080
Old Jul 8, 2014 | 08:34 PM
  #653
bmrguy03's Avatar
bmrguy03
Originally Posted by walk0080
To me that actually sounds very reasonable for a dealership install cost.
I agree. I think they are only charging 1 and half hrs for installation which is a steal.
Old Jul 9, 2014 | 04:26 AM
  #654
TJANK's Avatar
TJANK
Originally Posted by TheZlog
Just got my tracking number today! Going to wait a couple weeks probably to get them installed. Mini of Portland (oregon) quoted me ~$200 for the install. i'm on the fence on whether I should shop around or just have them do it. I just don't have the time to try and do it myself unfortunately :|
That is a very good deal! It took me about 5 hours myself since I tried working around taking the entire bumper off, but eventually removed it. Now since I could easily do it in 2 hours with the lessons I learned. My dealer initial told me 4 hours since they had not done one before.
Old Jul 9, 2014 | 04:56 AM
  #655
scottab36's Avatar
scottab36
That price is a steal. I've done this install twice and both times it's taken no less than 4.5 hours.
Old Jul 10, 2014 | 05:55 AM
  #656
walk0080's Avatar
walk0080
Old Jul 14, 2014 | 05:59 AM
  #657
TJANK's Avatar
TJANK
I noticed this morning that one of my halos is not working but the fog lights and top halo are working on that light. I hope it is simply a loose connector!
Old Jul 14, 2014 | 03:30 PM
  #658
zcast's Avatar
zcast
Installing these on my wifes CM All4. Pretty straight-forward, as I had installed them on my R58 JCW without issue. But now, after installing them on the CM tot he same pin 12 grey wire on the black footwell module connector, I am getting a lighting system error from the car. The headlights (Xenons) and full halos are coming on with the headlight switch in the "off" position. (The car does not have Auto-Headlights). i have reseated the red splice connector 4 times now on that same grey wire (in different spots along the wire) but nothing changes. Checked the connectors at each light. Check the connections for the ground and hot. All look good.
Could I be tapping into the wrong grey cable (pin 12 of the black footwell module). Could I tap into something else to try to see if that is the issue?
-Z
Old Jul 14, 2014 | 05:10 PM
  #659
TJANK's Avatar
TJANK
-Z
I assume you set your daytime running lights to the off position. "To ensure proper functioning of the LED daytime running lights, the daytime running light option of your vehicle may not be reactivated via the onboard computer."
Old Jul 14, 2014 | 05:22 PM
  #660
TJANK's Avatar
TJANK
My DRL's have been working perfectly for the past few months, but this morning one of my full halos went dim. Both fog lights still work, both partial halos still work, and only one full halos works. The other one is barely visible (very dim) almost like it is not getting enough power. I disconnected the connectors to the that fog light and reconnected them--still no full halo.
Any ideas? I suppose the next step is to remove the bumper and temporarily reconnect the dim fog light to the other side connectors and see what happens. I could at least isolate if the issue is with the light itself or something else like a crimp in the wire.
Old Aug 15, 2014 | 07:33 AM
  #661
komet155's Avatar
komet155
That's disturbing to hear, especially because it's such a pain in the @ss to remove the light units for replacement or testing.
How long did you have them on the car and did you have any issues with wiring during install? How about wet weather driving? Did you go through any really big puddles recently?
Old Aug 15, 2014 | 07:37 AM
  #662
JCW_Coupe's Avatar
JCW_Coupe
thats what the warranty is for
Old Aug 15, 2014 | 08:02 AM
  #663
TJANK's Avatar
TJANK
I had them installed and it worked for about 9 months. Currently, I removed and sent the one bad fog light back and I am waiting for a replacement from Mini. I recall washing my Mini the day before but really did not notice it until the next day when I pulled up at a stop light and saw the reflection in the vehicle in front of me.
I am glad I only needed to remove the one fog light and not the entire wiring system. It was definately the sealed light problem since when I plugged in the bad light into the opposite side plug, the halo did not work there also. I really need to take photos, since I have one of the original fog reinstalled and the new halo type. The LED is significantly brighter then the regular fog light.
Old Aug 15, 2014 | 08:25 AM
  #664
komet155's Avatar
komet155
I'm glad to hear you got it figured out. I noticed the other day that the lights are sealed units and so none of the interior components are removable for replacement. If anything burns out inside, the entire housing needs to be swapped out.
I've had my kit in the garage for a few months now, slowly preparing for doing the install myself. I had explored alternatives to mounting the control unit in the suggested location strapped to the underhood fuse box and found a suitable spot under the passenger side cowling, not far from the battery.
I've modified the upright plastic piece that snaps into the bulkhead close by to accept the control unit. It fits in there neatly. I'll run the wires through a small hole drilled in the upper edge of the bulkhead just to the right of the front of the battery. I'll post pictures once it's done and I figure out how to upload to photobucket.
Old Aug 15, 2014 | 08:31 AM
  #665
You cant get the individual lamps yet, like encase someone damages the front corner and the light in a accident, but you can get the module only now on its own encase its damaged in a wreak or something else.
Old Aug 15, 2014 | 08:51 AM
  #666
TJANK's Avatar
TJANK
I've modified the upright plastic piece that snaps into the bulkheadright by there to accept the control unit. It fits in there neatly. I'll run the wires through a small hole drilled in the upper edge of the bulkhead just to the right of the front of the battery. I'll post pictures once it's done and I figure out how to upload to photobucket.
Keep in mind that depending on where the LED were ordered from, there may be only a 1 year warranty on parts (or two years from some Mini dealers). For installation, I would highly recommend removing the front bumper. I tried working around it but I would have save hours by simply removing it first. In the end I removed the bumper and was able to fasten the wires properly. Not to mention the windshield fluid resovoir is in the way. I was glad I ordered a replacement plastic expanding rivets for the wheel well trim from ECS (their shipping costs are outragiously expensive! for a 99 cent part will cost just under $10 for shipping-- which is still cheaper than dealership pricing), since once you punch out the center, it was difficult to locate the little plastic pin. Most of the other fasterers are torx screws and/or bolts.
Old Aug 15, 2014 | 09:03 AM
  #667
komet155's Avatar
komet155
I got mine from MINI Parts Store in OH ( http://thebmwminipartstore.com/ ). They're also an advertiser on this site. Since it's an actual Mini dealership it it would come with the standard new parts warranty. I thought ahead when I ordered and also got a dozen each of various clips for trim I plan on having to remove for this project as well as future ones. It saved on shipping having them sent in the same box with my lights and GP2 sport steering wheel.
One of the other things I was trying to figure out ahead of time was whether I should bite the bullet and remove the front bumper or try to reach through the wheel well. Im just going to remove the front bumper although I am afraid I'll scratch the paint while handling....may wind up attaching some foam sheeting (the kind they ship electronics with) to the bumper exterior with painters non-marring masking tape in case I accidentally bump or scrape it against the concrete floor of my garage.
Keep in mind that depending on where the LED were ordered from, there may be only a 1 year warranty on parts (or two years from some Mini dealers). For installation, I would highly recommend removing the front bumper. I tried working around it but I would have save hours by simply removing it first. In the end I removed the bumper and was able to fasten the wires properly. Not to mention the windshield fluid resovoir is in the way. I was glad I ordered a replacement plastic expanding rivets for the wheel well trim from ECS (their shipping costs are outragiously expensive! for a 99 cent part will cost just under $10 for shipping which essentially gets you to a similar dealership pricing), since once you punch out the center, it was difficult to locate the little plastic pin. Most of the other fasterers are torx screws and/or bolts.
Old Aug 15, 2014 | 10:11 AM
  #668
komet155's Avatar
komet155
I was just browsing around on http://thebmwminipartstore.com/ and noticed that they offer a small parts flat rate shipping for $6.45 -anything that can fit in a 12x12x5-1/2 box. That will come in handy when I order some more small part soon....touch up paint, wheel center caps, etc.
I was glad I ordered a replacement plastic expanding rivets for the wheel well trim from ECS (their shipping costs are outragiously expensive! for a 99 cent part will cost just under $10 for shipping-- which is still cheaper than dealership pricing)....
Old Aug 15, 2014 | 12:57 PM
  #669
TJANK's Avatar
TJANK
That is a good price.
Old Aug 17, 2014 | 10:36 AM
  #670
komet155's Avatar
komet155
UPDATE: My alternative CU placement project is proceeding...slowly. Today I finally mounted the control box in that new location. It fits like a glove. I ran the blue wire across the cowl area to the waterproof grommet and ran it through under the dashboard. For now it's stashed inside the plastic footwell trim. I connected the hot wire to the accessory post on the positive battery terminal. It also fits there perfectly. I've temporarily pulled the in-line fuse since I'm not ready to have power to the C.U. yet. I connected the ground wire to the ground terminal, sandwiched in the space the bolt runs through.
For now, I've tucked away the cables that will run to the lighting units because I'm not about to remove the bumper today and deal with all of that.
I have already drilled a round notch in the upper edge of the bulkhead at the bend near the battery so I can run the cables neatly through there.
So, now the CU is neatly mounted. All I have to do is remove my front bumper, attach the new lights, run the cables forward along the right side of the car, attaching to existing cables, then across to the light on the left side.
Then, I have to make that connection for the one blue wire at the footwell unit, but I may first mount up my JCW gauges so I can access the FCU for both connections at the same time.
Bulkhead upright piece I trimmed. The red outline shows the part cut out in order to get the CU to fit up against the flat portion:
Diagram showing the upright piece position as well as where I cut the round notch for the main cable to come through:
This shows the prepared upright piece....ready to accept the C.U. Note there's some additional plastic trimmed, the pointy piece remaining wasnt going to do me any good. Make sure you install this before attaching the C.U. It's much easier that way:
Prefitting the CU to make sure it will fit neatly:
The CU in place under the cowl:
Hot wire fits under the nut on this battery terminal:
Negative wire ring terminal sandwiched in the squeeze area on the terminal. It fits around the bolt that goes through there:
Blue wire routed down under upright to go across cowl area:
This is only a supplement to other extensive write-ups for the full install to show this alternate placement. You may want to refer to other posts to see how to remove the watertight seal cover, etc.
Marked for cutting out the bulkhead notch:
One hole cut here:
The other right behind it to enable the cowl cover to fit and seal properly:
Test fitting of the cable running through bulkhead. Nice & neat, just the way I like it:
You can view the entire gallery here, including how I cut the hole using a step drill bit:
http://s875.photobucket.com/user/komet155/library/
Hope this helps!
I did some exploratory surgery today to see where I can neatly fit the control unit (since taping or zip tying it to the fuse box doesnt look right to me) and, after figuring out how to remove the wiper arms and cowl (good practice since I'm sure there will be several times I'll have to do this) I looked around under the cowl to see where I can stow the box and still run the wires where they need to go.
My first instinct was to check for room under the wiper linkage which required removal of the whole assembly (more practice). Unfortunately, there's not enough room to fit and neatly secure the box there.
Well, at least I can say I have experience removing my wiper linkage assembly.
So, I looked over near the battery side and found an upright plastic piece just to the right of the battery under the cowl (part # 51712755865).
Number 6 on this diagram:
http://www.realoem.com/bmw/showparts...51&fg=75&hl=15
I tried to place it against that but there is a slope towards the bottom which prevented it from fitting up against the flat part of this piece. I removed the piece and started cutting a slot through this slope with my dremel. It came out a little sloppy since I was "in the groove" but it will allow me to secure it there. The wiring branches that go to the lights would have to come through the cowl (easily done by cutting a small notch in the upper edge of the cowl with the weatherstrip removed) and will still reach. As for the other 3 wires, the 2 that need to go to the fuse box will have to be lengthened a foot since the box will be closer to right side of the car. I thought about this and figured if I used a few posi-lock weathertite connectors I can add some length AND only need to drill a small hole for a grommet in the left side of the cowl to pass wires through since the wire will be cut (dont need to pass the whole spade lug connectors through).
OH, and I'll probably order a new piece #51712755865 just so I can cut more neatly and carefully. I have issues.
So, basically, all you'd see are some wires neatly exiting the cowl. Easy Beezy! Time for a beer (Sierra Nevada Ruthless Rye).
Old Aug 19, 2014 | 07:51 AM
  #671
TJANK's Avatar
TJANK
One hole cut here:
Hope this helps!
Thanks! (I would not connect the ground wire directly to the battery nor to a spot that already has a ground wire. The ground should be connected to a position with no existing ground wires--to prevent a ground loop from occuring.)
Old Aug 19, 2014 | 08:27 AM
  #672
komet155's Avatar
komet155
I've never heard of a ground loop. There are some other accessories already connected directly to the ground post of the battery (by the factory).
Old Aug 19, 2014 | 10:08 AM
  #673
MikewithaMini's Avatar
MikewithaMini
Original instruction call for the ground to be placed on a grounding stud existing with many other ground wires. This ground is located and reachable with the fuse block moved out of the way.
Old Aug 19, 2014 | 10:34 AM
  #674
komet155's Avatar
komet155
Yes, I know that the official instructions call for grounding it there but since I've chosen to mount the control unit under the cowl (close to the battery) instead, I've looked for alternate positive and negative connections. Hot will be on the accessory post which is part of the terminal assembly and ground will be on the battery negative terminal UNLESS I can find another convenient ground post close by. I haven't looked very hard for one because I thought going directly to the battery would be OK.
Old Aug 19, 2014 | 03:30 PM
  #675
MikewithaMini
Yes, I understand your choice. Not particularly easy to get to, and there might be others more easily accessible, but there is one on the inside right hand internal rocker panel. It is located about mid-seat. The trim of course needs to be removed and you know how to do that from getting to the footwell module. Your wire length would have to be extended for sure.
The reason for my response was from what you had said about staying away from multiple grounds on a single point (as I understood) which is what the original instructed ground point is. There is a lot of grounds on that post.
