Official MINI DRLs Fitted
Old Aug 20, 2014 | 07:52 AM
  #676
komet155's Avatar
komet155
I would prefer to ground it close to where I'm mounting the control unit, that is inside the cowl area by the firewall. I much rather not try to fish the wire through the firewall to find a ground inside the passenger compartment.
It will be a few weeks before I can complete this install due to extenuating circumstances, but I'll let everyone know when I have an update.
Old Aug 26, 2014 | 02:41 AM
  #677
WhiteSilverMCS's Avatar
WhiteSilverMCS
anyone in socal have experience in installing this? Anyone want to help?
Or if anyone knows a successful shop or dealer in Los Angeles / orange that has installed these successfully let me know
Old Aug 26, 2014 | 04:38 AM
  #678
JCW_Coupe's Avatar
JCW_Coupe
wish I was closer to help, i did mine alone, GL!
Old Aug 26, 2014 | 05:28 AM
  #679
MikewithaMini's Avatar
MikewithaMini
Me too. The hardest part was locating the correct wire at the footwell module. I also made a doh! In the darkness of the underdash I managed to plug the relay in the wrong way. That made for some frustration figuring that out. I was surprised it fit out of clock! Pretty straight forward. I replaced my bumper with an aero when I did the install.
Old Aug 26, 2014 | 10:15 AM
  #680
WhiteSilverMCS
Please refer me to a dealer in socal that has done it correctly. I don't want the wrong wire to be spliced into etc.
Old Aug 28, 2014 | 09:54 AM
  #681
WhiteSilverMCS
no one has a recommendation that has gotten it done??
Old Aug 29, 2014 | 08:31 AM
  #682
bmrguy03's Avatar
bmrguy03
If I had still lived in SoCal I would have helped you. Sorry. If you are near Santa Ana you may want to try Crevier MINI. That's the only dealer I ever trusted taking my MINI to.
Old Aug 29, 2014 | 09:06 AM
  #683
zcast's Avatar
zcast
If you want to drive it up to Vegas, I can help you with it. Otherwise, if you want to do it there, I can Skype/Facetime with you and step you through it.
-Z
Old Aug 29, 2014 | 10:00 AM
  #684
KilmerPT's Avatar
KilmerPT
Here's a pic of the gray wire you tap into just above my thumb for reference. You can follow it towards the top of the pic where I did the tapping with the blue wire. Goodluck!
Old Aug 29, 2014 | 11:49 AM
  #685
WhiteSilverMCS
is this in the dirvers side?, the rest of the install the manual is pretty clear then??
Old Aug 29, 2014 | 12:45 PM
  #686
KilmerPT's Avatar
KilmerPT
Yes, it is the driver's side. You can see the dead pedal in the pic actually. If you read through the whole thread, there is basically more than enough info to do the install either by taking the bumper off or an alternative way by taking off the headlights. I personally took off the bumper because I also installed an FMIC at the time.
Edit: Here's another pic of the socket X14260 you do not want to tap into: it is gray with a black casing. The correct one is black/black which is X14261. Hope that helps.
Also, there is an error in the pic of the instructions where the wiring bundle appears to be coming from the floor going up, but it is actually coming from the top going down.
Attached Thumbnails Official MINI DRLs Fitted-image-1919793135.jpg   Official MINI DRLs Fitted-image-1362366392.jpg
Old Sep 1, 2014 | 11:12 PM
  #687
WhiteSilverMCS
anyone in socal install this correctly and is willing to help me? I am scared lol.
Ill compensate you somehow plz haha
Old Sep 2, 2014 | 05:28 AM
  #688
JCW_Coupe's Avatar
JCW_Coupe
its really straight forward, just wire connections and routing....but somebody has to be in that area
Old Sep 2, 2014 | 07:56 AM
  #689
WhiteSilverMCS
Should I remove he bumper? Or do the headlight thing?
Old Sep 2, 2014 | 09:36 AM
  #690
TJANK's Avatar
TJANK
I tried without removing the bumper and in the end removed the bumper. Removing right away would have saved me hours. Keep in mind you will need a few replamement plastic expanding rivets for the wheel trim--since once you punch the center out it is difficult to find the little pieces. Everything else was a torx or nut. Also, the windshield washer fluid resovior is on the driverside behind the bumber so it blocks access to the fog light.
Simply pop the center grill off the bumper to access the torx bolt, remove the first three fasterners on the black wheel well trim and partially pull the trim to expose another torx bolt. Remove the fasteners from the underside of the bumper and the bumper is off.
Old Sep 2, 2014 | 09:53 AM
  #691
komet155's Avatar
komet155
Is there only one torx bolt on each side under the wheelwell trim?
How many along the underside?
Thanks.
Old Sep 2, 2014 | 12:57 PM
  #692
KilmerPT's Avatar
KilmerPT
Helix has a good video on how to remove the bumper to give you an idea of what to expect. However, some of those fasteners can be a real PITA the first time you do it compared to their video.
Old Sep 2, 2014 | 09:27 PM
  #693
WhiteSilverMCS
cheapest i got quoted for in socal at a dealer is 400$ so far.....
im probably just going to have to man up.
Old Sep 3, 2014 | 08:01 PM
  #694
WhiteSilverMCS
anyone in socal have one and want to install it together?
We can do two, and help each other!
Also I had a question for whoever that can answer it.
When im snaking the blue line into the firewall, where does it go through? How do i go through the black plastic stuff that covers the grommet on the firewall?
Old Sep 4, 2014 | 02:16 PM
  #695
WhiteSilverMCS
So i just did this today, it went well, people have to make sure they clamp down hard on the blue and grey lines. I was nervous after i didn't see the full circles but went back and pushed down really hard and they finally lit up.
Like everyone says, they are well worth it and looks amazing.
They are bright as hell.
I got quoted 400-600$ and no cheaper in LA area so i went on ahead and accomplished it today and am happy. Asides from breaking a few clips here and there. Everything went smooth.
Old Sep 4, 2014 | 02:26 PM
  #696
WhiteSilverMCS
This right here is all you really need to install the fogs lol
Im so glad you posted that
mine is up and kicking =)
Old Sep 4, 2014 | 06:06 PM
  #697
JCW_Coupe's Avatar
JCW_Coupe
damn i missed this one, i did everything without removing the headlight or the bumper, just removed the GP skidplate and the front wheel well liners...
Congrats on the install...
Old Sep 4, 2014 | 10:21 PM
  #698
KilmerPT's Avatar
KilmerPT
This right here is all you really need to install the fogs lol Im so glad you posted that mine is up and kicking =)
Very glad to hear your install was a success and that my pic was of help! I'll drink a beer to that!!
Old Sep 21, 2014 | 03:56 PM
  #699
TJANK's Avatar
TJANK
One of my DRL halo rings went dim (basically out) and as I wait for a replacement which is being shipped to me this week, I thought I would take photos with the original Mini OEM fog light installed on the left and the new Mini DRL installed on the right.
When all lights are in off position. MINI DRL halo turns on. OEM on left, correctly is off when all lights are in off position.
When headlights are turned on and fog lights off: the DRL only the partial halo lights and the OEM turns on upper marker lights. Note the OEM is definitely more yellow and the DRL is brighter.
With headlights on and fog lights activated: the OEM lights the fog light and upper marker lights, the DRL lights again light up the upper halo and activates fog. Again DRLs are a much whiter light.
Attached Thumbnails Official MINI DRLs Fitted-_mg_4968v2.jpg   Official MINI DRLs Fitted-_mg_4980v2.jpg   Official MINI DRLs Fitted-_mg_4984v2.jpg
Old Sep 21, 2014 | 07:06 PM
  #700
komet155's Avatar
komet155
How long did you have the set on the car before one went dim?
