Electrical NCSExpert for beginners
Old Dec 20, 2013 | 03:42 AM
  #301
bratling's Avatar
bratling
Super Moderator
Originally Posted by cerenkov
If you order from ecutool.com, it comes from china AND it arrives in 3 days via DHL
Maybe the DHL thing is new. When I ordered earlier this year, it took over six weeks to arrive and USPS handled the US end of things.
Old Dec 20, 2013 | 04:47 AM
  #302
erider's Avatar
erider
before i send this back, could this be a Pin 8 issue since i have a 2010? I could remove the pin and try it if its a possiblilty
Old Dec 21, 2013 | 11:24 AM
  #303
ctweber's Avatar
ctweber
can you explain how you solved the faulty vin issue?
Sorry this was a reply to a specific comment many pages ago but I goofed somehow and commented on the main topic
thanks
Old Dec 23, 2013 | 03:59 AM
  #304
claw's Avatar
claw
thanks
I don't know which comment are you referring, but normally that issue is solved by buying a new cable... a working one
Old Dec 25, 2013 | 10:59 AM
  #305
ptkacik's Avatar
ptkacik
New cable, still problems
Do I need to run a Laden.bat file? Where does it and the REVTOR.PFL file come from?
When I unzipped the R50.zip in the "Mini Cooper Coding\Datens (v38)" subdirectory, there was no laden.bat file in R50\R50\daten to copy to c:\ncsexper\daten\r50. There was also no REVTOR.PFL file in the profile directory.
When I unzip RR1, there is a LADEN.BAT file in its daten subdirectory and it only differs (from laden.bat in R56) in the first line. It also puts a REVTOR.PFL file in the profile subdirectory.
So I ordered the ecutools cable and it came DHL in 3 days.
HELP! I am on my third laptop and millionth hour of trying to get this working.
Old Dec 25, 2013 | 11:17 AM
  #306
ptkacik's Avatar
ptkacik
As a test, I edited the LADEN.BAT file to have R50 on the first line and ran that. I then copied the REVTOR.PFL file generated by the RR1 zip file to NCSEXPER\PFL and when I ran NCS expert, it went OK until I ran F3 where I chose R50 and then it said my ECU choices were EWS or KMB and no CAS option. I stopped there.
Old Dec 26, 2013 | 10:41 AM
  #307
ptkacik's Avatar
ptkacik
Used alternate for CAS and it worked
OK, so I got tired of waiting and since CAS wasn't an option, I used the first choice (EWS?) and kept going. It worked like it was supposed to so I reprogrammed the airbags (OC3 nicht_active), cleared the codes, and now the light is off. I hope this wasn't a mistake but it seems OK.
Old Dec 26, 2013 | 11:53 AM
  #308
cerenkov's Avatar
cerenkov
I believe that you are following instructions for a R56. CAS (and FRM) contains the vehicle order information for an R56. For a R50 it seems like it's different as you found out. It doesn't really matter as long as it can read the vehicle order, if you selected the wrong module it would just give an error, you wouldn't actually harm anything. You made no mistake. code on
Old Jan 30, 2014 | 08:03 AM
  #309
whrisk's Avatar
whrisk
question deleted, found the info i needed
Old Feb 11, 2014 | 10:10 AM
  #310
igzekyativ's Avatar
So I read this whole thread and I am still confused..
I have a 2012 JCW and 2013 JCW I want to code. I have a new laptop that I use for work and such, and it is running windows 7 professional 64-bit.
Will I have to run a windows XP VM?
I've downloaded these files:
Mini Cooper Coding.rar
SP-V45-R56.rar
ncsdummy.zip
Mini_R56_Code.xlsx
Do I need BMW Standard Tools 2.12 or to update EDIABAS? If so, what is the newest version and does someone have a link?
This seems to be the cable I need.. am I right?
Old Feb 11, 2014 | 10:49 AM
  #311
cerenkov's Avatar
cerenkov
Originally Posted by igzekyativ
So I read this whole thread and I am still confused.. I have a 2012 JCW and 2013 JCW I want to code. I have a new laptop that I use for work and such, and it is running windows 7 professional 64-bit. Will I have to run a windows XP VM? I've downloaded these files: Mini Cooper Coding.rar SP-V45-R56.rar ncsdummy.zip Mini_R56_Code.xlsx Do I need BMW Standard Tools 2.12 or to update EDIABAS? If so, what is the newest version and does someone have a link? This seems to be the cable I need.. am I right?
Buy the cable from ecutools.com linked in the first thread.
Old Feb 18, 2014 | 07:18 AM
  #312
Ian Torok's Avatar
Ian Torok
Similar Question
I have a MCS 13. I tried running the NCSExpert and it doesn't like Win7 64b, even after setting the properties to WinXP SP2 on the setup.exe.
Provided I can eventually get it to work, are there updated DATENS for the MCS13?
SP-V45-R56.rar
ncsdummy.zip
Mini_R56_Code.xlsx
Old Feb 18, 2014 | 07:33 AM
  #313
Agbullet25's Avatar
Agbullet25
My understanding is that V50 datens are the most current and will work with 2013 cars.
Old Feb 18, 2014 | 08:03 AM
  #314
Ian Torok's Avatar
Ian Torok
Thanks, I downloaded the 51.2 DATENS from the other coding thread
https://www.northamericanmotoring.co...r60-guide.html
Now just need to see if I can get the program to run in WIN7 64
Old Feb 21, 2014 | 05:44 PM
  #315
thays_91's Avatar
thays_91
This is driving my crazy! I've re-installed everything 4+ times and am still getting the "faulty vin" error code. I purchased the cable shown in the original post. I have version 51.2 Datens and a '13 Cooper S. Im also running Win XP on VirtualBox for Mac. INPA shows Battery and Ignition as on. Any ideas?
Old Feb 21, 2014 | 05:51 PM
  #316
cerenkov's Avatar
cerenkov
I almost have the same setup as you. I have a 2013S with Datens 49something BUT running Window 7 64bit bootcamped on a MacBook Pro. Is INPA running fine?
Old Feb 21, 2014 | 06:13 PM
  #317
thays_91's Avatar
thays_91
INPA seems to be running perfectly fine. If the car is turned on, it shows battery on, ignition on, if i turn the car off it shows battery on, ignition off.
The only reason I decided Win XP was to try to eliminate as many possible problems as I could. I didnt want to Bootcamp because the first time I dinnt allow enough HD space, VirtualBox will let me shut down the machine and allow more space and or RAM.
Also, we have more than just the same setup, our cars are almost twins, mine is Lightning Blue, White Top/Stripes and LED halo fogs, only I have the conical spokes.
Old Feb 21, 2014 | 06:57 PM
  #318
cerenkov's Avatar
cerenkov
Hmm. what EDIBAS version are you running?
Old Feb 21, 2014 | 07:45 PM
  #319
thays_91's Avatar
thays_91
hmm. What edibas version are you running?
7.2.0
Old Feb 21, 2014 | 08:12 PM
  #320
cerenkov's Avatar
cerenkov
7.2.0
I'm using 7.3. Try updating to the newest set of BMW Standard Tools. The version the I'm using is 2.12 not sure if that is the latest though.
Old Feb 21, 2014 | 08:19 PM
  #321
thays_91's Avatar
thays_91
Where did you get the newest ones?
Old Feb 21, 2014 | 08:52 PM
  #322
cerenkov's Avatar
cerenkov
I can't remember but the file I downloaded is called "R56_coding_package.zip". Let me know if you can't find it.
Old Feb 22, 2014 | 04:05 PM
  #323
thays_91's Avatar
thays_91
Im having problems finding that exact file. Could you send me a link to it or even email it to me? I thought I had found a newer version, deleted everything and started over again, but now I'm getting invalid chassis error.
So much trouble for just a few things, but i know after it will be so much better.
Old Feb 22, 2014 | 04:26 PM
  #324
cerenkov's Avatar
cerenkov
Im having problems finding that exact file. Could you send me a link to it or even email it to me? I thought I had found a newer version, deleted everything and started over again, but now I'm getting invalid chassis error. So much trouble for just a few things, but i know after it will be so much better.
I'll post a link to my google drive (give me a few hours).
It can be a PITA to get working but once you do it's kind of worth it.
Old Feb 22, 2014 | 05:08 PM
  #325
thays_91's Avatar
thays_91
Thank you!
