Electrical NCSExpert for beginners
Old Jul 9, 2013 | 01:57 PM
  #226
fxmartin's Avatar
fxmartin
Hi all,
I try to install and code my Mini R56 (2006) but i have an error which are returned :
ERROR! Modul: LFCDHDIA.CPP (A_PL2FRX.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000
COAPI-2000: EDIABAS or SGBD error
BIP-0009: Faulty BEST version of description file
Does someone know how i can resolve it ?
I curently use the V45 files.
Thanks for all
Old Jul 10, 2013 | 09:41 AM
  #227
calforhelp's Avatar
calforhelp
Originally Posted by fxmartin
I try to install and code my Mini R56 (2006) but i have an error...
I believe that would be because you don't have an R56. You have an R53 if it is an S. Or an R50 if it is not an S.
There's another thread around here somewhere with instructions on coding these older cars.
Old Jul 10, 2013 | 10:01 AM
  #228
JonsR56's Avatar
JonsR56
Here you go
https://www.northamericanmotoring.co...onal-info.html
Hi all,
Thanks for all
Old Jul 10, 2013 | 12:55 PM
  #229
fxmartin's Avatar
fxmartin
Hi sir,
i'm sure that's a R56 cooper 120cv ! not R53 the interior of the car aren't the same !
Regards
Old Jul 10, 2013 | 03:00 PM
  #230
fxmartin's Avatar
fxmartin
Hi all,
I check again my cars card and my Mini is still a R56.
Moreover, i try the V40 files and it doesn'y work anymore.
This time i took the full error code and it is :
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000
CODIERINDEX_LESEN
>> ERROR! Modul: COAPI.CPP, Proc: coapiReadCodierIndexFromSg, LineNr: 05, ErrorNr: 2000
CODIERINDEX_LESEN: A_PL2FRX
SG_CODIEREN
I want to precise That i CAN read the modul, it's when i want to execute the job that i have this error
Thank you very much everyone.
Old Jul 16, 2013 | 05:46 AM
  #231
fxmartin's Avatar
fxmartin
Hi all,
i solved my problem alone.
I reinstall a proper version and moreover i install Ediabas 7.2.0.
And now that works.
But, i have new problem, it's normal i think...
I successfully coded my car but, the new function aren't activated !
I know it's paradoxal, but after coded the car, i shut down for around 1 minute, and try the new function. It doesn't work.
I read the module again and the new function are clearly coded.
Does i need to do something ?
I try to disconnect the battery to restart the system but it doesn't work anymore.
Thanks for all for any help.
Regards,
Old Jul 20, 2013 | 06:40 PM
  #232
Gaspar Crespo's Avatar
Gaspar Crespo
HI
i am having the problem about VIN is Faulty, and i also dont know in the instruction pdf what is the model of the folder to be created on ncsxpert ? is it R56 (in my case) or is it V38 ?? I wish the instruction would say something like "create a folder Named XYZ etc" instead they just say to copy all files to ??
So this is what i need to ask:
1. is it a folder that needs to be created with the name R56 (in my case) or V38 V40 or we take all the files from the unrar datens (in the tutorial will be V38) and copy them to the datens folder?
2. If we see the battery On etc on INPA but get a VIN is Faulty at NCSexpert, does it means that is the cable or the datens?
Please need help
thanks
R56 january 2008 N14, D-Can cable bought on ebay $45, and true winXP notebook.
Old Jul 22, 2013 | 11:50 PM
  #233
fxmartin's Avatar
fxmartin
Hi sir,
If you asking this question is because you don't have read all the topic and thé instruction to install ncsexper. You have two pdf in the pack for the r56 which explain how to install and how to code.
I think you have problems with your daten. The v38 or 40, 45 are the R56 files for ncsexper and need to be extract and install correctly to work.
If the inpa doesn't work ncs can't work because he read your VIN
Old Jul 23, 2013 | 06:53 AM
  #234
nutsofamily's Avatar
nutsofamily
files and auto bat install
download install from nutsofamily.com for files and bat install
if your cable is wrong you will never get it to work
Please need help
thanks
Old Jul 23, 2013 | 02:32 PM
  #235
Gaspar Crespo
Hello FX
Well i did read the instructions, and this its the bottom of my question:
step 2: (after the extraction part):
you will need to copy/paste the files in these subfolders accordingly:
All files in “daten” → C:\NCSEXPER\DATEN\XXX (where XXX is your chassis code)
The XXX is my main questions, so based on my car (R56) SHould i create a folder named R56 and will show like this:
C:\NCSEXPER\DATEN\R56 ??? and then copy the files (not folders) from the datens V38 extract to the new R56 folder??
Thats my simple question.
And my second question was, im reading my battery on INPA, so its my cable ok?
And please i do like to read and follow instruction but i didnt get that one.
thanks again for your help
Hi sir,
Old Jul 23, 2013 | 04:30 PM
  #236
nutsofamily
chassis code is r56.
If you simply download and run the bat file then all things get placed accordingly thanks to Chernobyl.
If you can read your vin then the cable works.
Simply getting ignition lights does not mean you have the correct cable. You have to actually read from your cars computer.
Old Jul 24, 2013 | 10:08 AM
  #237
fxmartin's Avatar
fxmartin
As nutsofamily said, you must run Laden.bat in your daten folder.
This bat file will create a R56 folder automatically.
If you want to be sure that it works, after done this step, run NCS Exper and try to read the module.
If you get an error tell us.
Regards
Old Aug 5, 2013 | 04:13 AM
  #238
Minin's Avatar
Minin
Hi there, is it possible someone tell me the code for ncsexpert in order to change the gong sound? In my car the sound comes from a little speaker in the speedometer I want this sound to come from the speakers.!
Old Aug 12, 2013 | 01:52 PM
  #239
cerenkov's Avatar
cerenkov
Thanks to GTECKO and NUTSOFAMILY
just two comments:
1.) Get the cable listed in the first post!
2.) The program versions from NUTS will work with Win7-64bit
PS: I'm using a 2012 Macbook Pro with Win7-64bit bootcamped
So far I have done the seatbelt chime delete, 1 touch sunroof, next I'll configure the DRL's.
Old Aug 24, 2013 | 07:47 AM
  #240
phaelenx's Avatar
phaelenx
Is there anyone in the State of Florida or within a reasonable distance from Tallahassee, FL that could do these mods to my car?
Old Aug 24, 2013 | 08:31 AM
  #241
StPeteAPB's Avatar
StPeteAPB
If not, go remote with Okee at CodeMyCar.com (Tripl3 O Coding):
https://www.facebook.com/Tripl3OCoding
He did an awesome job with my car!!
Old Aug 28, 2013 | 06:25 PM
  #242
OreoPanda's Avatar
OreoPanda
Any one have any issues with the auto unlock option? I programmed mine to do it, and have the car setup to auto lock. When I take the key out it only unlocks the drivers door. Is this what it is supposed to do or is it supposed to unlock all of the doors?
Old Aug 28, 2013 | 08:51 PM
  #243
bmrguy03's Avatar
bmrguy03
I ran into this issue a couple months back as well and figured out why.
It depends on what setting you have to unlock your car by your key fob. If you have your car set to unlock JUST the driver's door with 1 push of the unlock button on your fob and 2 pushes to unlock all doors, then it will only unlock your drivers door upon removing your key. However, if you set you car to unlock ALL doors with just 1 push of the unlock button on your fob, then all the doors will unlock upon removing your key. You can change the setting by accessing your personal settings via the tachometer or, if you have MINI Connected, I believe you can change it by the settings screen on Connected.
Old Sep 5, 2013 | 09:44 PM
  #244
Gaspar Crespo
HI
Where can i get ediabas 7 and datens v46? thanks
Old Sep 12, 2013 | 03:29 AM
  #245
zre's Avatar
zre
Is there an expert in the CT to do somes re-coding?
Old Sep 28, 2013 | 06:47 PM
  #246
cactusjk's Avatar
cactusjk
Can you use a KIWI Wifi to connect to NSC Expert running on a PC to adjust codes? I am trying to turn on the rear fog in a 2013 R56 JCW.
Old Oct 13, 2013 | 08:27 AM
  #247
cactusjk's Avatar
cactusjk
Still looking for some help.
Also, can someone point me to a thread that just covers how to code the VO for the rear fogs using NCSExpert. Lots of these threads deal with other options.
Old Oct 13, 2013 | 09:14 AM
  #248
Kevdog's Avatar
Kevdog
Here is a link to a step-by-step PDF which helped me enable my rear fogs.
http://nutsofamily.com/wp-content/up...-CHANGE-VO.pdf
The final thing I had to do was to change NEBEL_SCHLUSSLEUCHTE to aktiv in IHKS. I don't know if that will apply for you, but it will probably be a similar setting.
Old Oct 13, 2013 | 09:25 AM
  #249
cactusjk's Avatar
cactusjk
Thanks! I have switch installed and now will take my time figuring all this out.
Old Oct 15, 2013 | 07:59 PM
  #250
cactusjk's Avatar
cactusjk
is the cable listed in the first post the right one for a 2013 R56?
