Electrical NCSExpert for beginners
Old Jul 6, 2012 | 12:53 PM
  #151
Hubs's Avatar
Hubs
Rear fogs working
Okay , had some more time today , got my fogs to work . Thank you GTECKO , followed your directions , couple of hiccups on my part but great directions !
Coded the retro fitted rear fogs in my 2007 MCS JCW . With downloaded program from here V.38 Datens . Changed the line
" NEBEL_SCHLUSSLEUCHTE " to aktiv which I found in the IHKA module .
Made my day , thanks for the great thread . Cheers !
Unbelievable " In my excitement I see my rear fog light on dash light up , look in back see driver side fog on and come run and post my success . When my wife and son come home I go out and show them my working fogs . My son points out the passenger side is not turned on . Well get out my volt meter sure enough do not get 12 volts on passenger wiring harness . Anyone have a pdf of the wiring harness? If not I just may go back in and program them off again .
Old Jul 6, 2012 | 03:09 PM
  #152
Hubs's Avatar
Hubs
Maybe just coded wrong ?
Looking at spread sheet again , looks like code I used maybe was only good for a 2009 justa . Maybe that is why only one fog light came on . Maybe I did not activate the modules correctly for the MCS.
I see on spread sheet that you can add a line to VO . $5AA to VO use CAS and FRM module .... Can anyone explain in a little more detail how you do this . Do you just add this $5AA to the end of the list of codes found in your FSW_PSW.TRC file for CAS and FRM or does it need to go somewhere more specific .
Old Jul 9, 2012 | 08:08 AM
  #153
bit_bucket's Avatar
bit_bucket
Quick question. I know this can be used to add retrofits but has the success been with new retrofit modules or used ones?
Old Jul 9, 2012 | 11:02 PM
  #154
bit_bucket's Avatar
bit_bucket
There was a doc posted on the second page of this thread by GTECKO that has the instructions you need. One caveat, when the instructions say to switch ECU right after the CAS programming you need to select FRM as we don't have an LM in our cars. YMMV
https://www.northamericanmotoring.co...-change-vo.pdf
Old Jul 10, 2012 | 06:47 PM
  #155
GTECKO's Avatar
GTECKO
Thanks bit_bucket
Old Jul 11, 2012 | 03:37 PM
  #156
Hubs's Avatar
Hubs
Thanks to "a.decrease" for holding my hand and GTECKO for the great tutorial . I finally have my retro fitted rear fog lights working . I can confirm adding into the VO , code $5AA into CAS and FRM module . will turn on " both rear fog lights " in a 2007 MCS .
I followed GTECKO's guide installed his program , then updated to DATENS v.45 and wrote over the origingal EDIABAS program that came with GTECKO's download to EDIBAS 7.2.0 . The reason for this was when loading the FRM module with original program I received a faulty vin error code, by using EDIABAS 7.2.0 no more error . Thanks "Chernobyl" for this fix . Wow I have rear fog lights ! and they turn on ....
Old Jul 21, 2012 | 03:37 PM
  #157
chuckdiesel's Avatar
chuckdiesel
my brain is spinning. among the array of different threads, and posts of people having issues, I can't even begin to feel confident to get started. there are conflicts with file downloads, which is the right cable to use, and which datens you needed.
I have scoured NAM threads, linking to other NAM threads, linking to BMW threads (headache).
I would appreciate someone to clear this up for me.
I have a '12 (May build).
Which cable?
Which version of software?
Which datens?
Anyother info would be greatly appreciated. PM me if more appropriate.
Thank you!
Old Jul 29, 2012 | 02:50 PM
  #158
GTECKO's Avatar
GTECKO
Everything is in this thread... you might maybe get the newer datens when they come out because I can't just update them on the site every time.
Tutorial is on page 1, spreadsheet linked too with the module you can change and that have been verified by members. I mean, it took me a while to write this tutorial and NO ONE every had a problem following it. Some ppl are having issue with coding and that is different.
The download links are ALL working ... I mean, I find it frustrating when ppl write stuff like that.
Give it a try at least ...
Old Jul 30, 2012 | 08:07 AM
  #159
chuckdiesel
Yes.. completely fair and adequate response. I will dig in and attempt it.
Has anyone successfully coded a '08-'12 using GTECKO's recommended cable? The website description indicates it's applicable to '08.
http://www.ecutool.com/BMW-INPA-KCAN_1939.html
Old Jul 30, 2012 | 08:16 AM
  #160
GTECKO's Avatar
GTECKO
Has anyone successfully coded a '08-'12 using GTECKO's recommended cable? The website description indicates it's applicable to '08.http://www.ecutool.com/BMW-INPA-KCAN_1939.html
Me - My car is a 2009 MCS ... worked perfect, hence why its linked on the thread. Not sure on the new 2012 version, we used MY personal cable on a 2011 model and it was fine.
Old Aug 5, 2012 | 05:19 PM
  #161
Roca68's Avatar
Roca68
Yes, I also have had success with the cable GTECKO recommends on my '09 Justa Classic. I also followed his great instructions. I did however upgrade to the BMW Tools 2.1 software version to use a newer version of EDIABAS: 7.2.
Old Aug 13, 2012 | 04:31 PM
  #162
GTECKO's Avatar
GTECKO
to my Man Roca68 - Thanks for reassuring members
Old Sep 6, 2012 | 09:12 PM
  #163
calforhelp's Avatar
calforhelp
Can anyone please confirm that datens V46.3 will work with a 2010 R55?
Also, what is the proper procedure for changing your datens version from one to another?
Old Sep 8, 2012 | 07:39 PM
  #164
DrZ's Avatar
DrZ
No options on INPA main screen?
After installing the package linked in the first post (many, many thanks GTecko) I can communicate with the vehicle OK, and I've made some simple coding changes to verify that communication seems to be working.
However, I'm currently seeing a CEL and the fan comes on and runs non-stop when the ignition is on, and so I thought it would be interesting to see what INPA has to say about it.
However, on the INPA main screen I don't have any vehicle selection options, so there doesn't seem to be any way to progress to read or reset codes. I've read about needing more scripts for INPA, but I haven't been able to work out where they would come from, or how I'd install them.
Am I missing something fundamental about INPA here?
Old Sep 8, 2012 | 07:45 PM
  #165
calforhelp's Avatar
calforhelp
I don't think INPA reads CEL codes. What year is your MINI? There is a recall of sorts for some sort of temperature sensor on the N18 engines. I had mine go bad and the fans ran at full speed whenever the ignition was on or the car was on.
A trip to your dealer will have it repaired for free in a few hours if that is the problem you are experiencing.
Old Sep 8, 2012 | 07:49 PM
  #166
DrZ's Avatar
DrZ
Well, that would certainly be part of the problem. What does?
I thought I'd fixed my signature to include vehicle details, but obviously not. This is on an 11/11 R55 JCW, so N14.
I first noticed the behaviour after reconnecting the battery at the end of the installation for a new driver's seat, but I can't say for sure it hasn't done it before. The CEL dates to the same point; it's possible that the two are unrelated.
Old Sep 8, 2012 | 07:56 PM
  #167
calforhelp's Avatar
calforhelp
I'm not exactly sure which program will read the CEL codes but I believe there is a program in the BMW Tools suite that will but I'm interested to find out as well.
I'm also not 100% positive that the recall was only for the N18 engine, it could have been for others. It's still worth a call to your dealer since it's the same symptom that I was experiencing and your car should still be under warranty unless you've racked up a lot of miles.
Old Sep 8, 2012 | 08:26 PM
  #168
DrZ's Avatar
DrZ
Thanks for the sanity and pointers. NHTSA is showing several TSBs for the '11 build that might be applicable as well, so in she goes; sorry for the distractions folks.
Old Sep 14, 2012 | 09:02 AM
  #169
an2's Avatar
an2
After some minor scares (I flattened my battery, and screwed up my KOMBI) I managed to get everything behaving.
GTECKO: Can I suggest you update the datens in your all-in-one package to 45 or better? My '07 was in recently and they did some ECU updating, and it doesn't seem to be happy with the v40 datens. It read the KOMBI ok, but going to reflash it resulted in a lot of strange errors - no tacho, no fuel gauge, and a constant blinking error icon that looked like it was telling my my spoiler was open . A bit of panic later, I updated to the v45s, defaulted, and everything was fine.
Everyone else: I also strongly advise that you hook up to a battery charger of some kind for the duration. I know people have said it before, but working on the ECU sucks battery. I was hooked into a charger set to 25A and still saw a good 1V drop over the few hours I was working on it, with a <6mo old battery. (This was after killing it the first time.)
After all that though: I got my alarm heartbeat, shut off the passenger seatbelt alarm (for the dog), switched off my CDN DRL, and turned on comfort closing and mucked about with the one-touch. Now I just need to figure out why my sunroof one-touch closes, but not opens; and why my windows don't one-touch close. And once I get access to the spreadsheet, I'm sure I'll find even more to play with....
Old Oct 6, 2012 | 07:27 AM
  #170
Bugler's Avatar
Bugler
Can this program be used to reprogram my radio? I had to replace my head unit and the one I got was from a year newer car that must have had different options on it and now my aux plug doesn't work. Everything else works though, nav, bluetooth, cd, radio... and no it's not the connections. I already checked it.
Old Nov 19, 2012 | 12:48 PM
  #171
busvol's Avatar
busvol
Successful Rear Fog Lights on MCS 2009
I just completed installation of rear fog lights on my MCS '09. I can confirm a few things in addition to instructions mentioned earlier:
The 2 pdf files of GTECKO are essential! Study them well.
- You need to update to EDIBAS 7.2.0 otherwise errors from FRM module.
- update to DATENS v.45
- INPA K+CAN cable was ordered from:
http://www.uobd2.com/wholesale/bmw-i...FQqk4Aod0QIA1w
for $27.99. Got no error messages and cheap.
- you need to default CAS module with empty .MAN file
- in addition to all things mentioned before you need to change the line in FRM module NSL_EINSEITIG_EINGEBAUT (rear fog lights only one side) from linke_seite (left side, aka driver side) to nicht_aktiv (not active)
I've discovered this after the install when only my driver side rear fog light was on. I was even able to change it to rechte_seite (right side aka passenger side) only, just for kicks.
Bottom line everything works fine, both lights are working.
I live North of Boston, in case anyone needs help.
Old Nov 21, 2012 | 04:43 PM
  #172
GuyPavelo's Avatar
GuyPavelo
Hey guys.
So i followed all the install instructions... On multiple computers with the same results here...
I can see the car, but when i try to read the car with expert, i get bad vin.
Tried everything i can think of... Any ideas why i may be seeing this? I found another thread, but there was no mention of what remedied the issue...
Im in Ct, if anyone could give a hand id be MASSIVELY grateful...
Old Jan 22, 2013 | 02:12 PM
  #173
tassoslabr's Avatar
tassoslabr
Hello,
I got the D-KAN usb to OBD, follow the guide and when I try to start NCSexpert I keep getting the 'vin is faulty' with COAPI-2020: no answer from ECU and IFH-0009 NO RESPONSE FROM CONTROL UNIT
I use Windows 7 (winXP compatibility mode) on a MCS 2007
Please could you give me some help???
thanks to everyone
Old Jan 22, 2013 | 02:15 PM
  #174
calforhelp's Avatar
calforhelp
Originally Posted by tassoslabr
Hello,
thanks to everyone
Please post a link to the cable you bought. I can almost guarantee that your problem is your cable.
Old Jan 23, 2013 | 08:55 AM
  #175
tassoslabr's Avatar
tassoslabr
I got the BMW Inpa K CAN from ebay....
http://www.ebay.com/itm/NEW-BMW-INPA...item35c2e10d0a
is that the problem?
