Electrical NCSExpert for beginners
Old Mar 5, 2022 | 11:12 AM
  #501
cut7's Avatar
cut7
Has anyone figured out why the passenger side window won't auto-up, even though it's configured to do so in NCSexpert? (See attached picture.) It works on the driver's side but not the passenger side. Auto opening works on both sides; as does comfort opening & closing with the remote.
Old Mar 5, 2022 | 11:38 AM
  #502
TVPostSound's Avatar
TVPostSound
Try a window reset.
Close the door, roll window down by holding switch, NOT one touch keep holding switch when down for 5 more seconds.
The roll window up by holding switch NOT one touch, keep holding switch when up for 5 more seconds.
Cant hurt.
Old Mar 5, 2022 | 11:45 AM
  #503
walkinghispath's Avatar
walkinghispath
If it’s an 05-07 car it doesn’t have the force sensor in the motor on the passenger side so won’t do it.
Old Mar 5, 2022 | 12:28 PM
  #504
cut7's Avatar
cut7
I have always thought that it had something to do with the jamming protection. Can I get a window motor from an earlier car & put that in? Will that work?
Old Mar 5, 2022 | 12:33 PM
  #505
cut7's Avatar
cut7
Originally Posted by TVPostSound
Try a window reset.
Cant hurt.
Well, I tried that, it didn't work. Thanks anyway.
Old Mar 10, 2022 | 02:11 PM
  #506
cut7's Avatar
cut7
Can anyone verify this? It seems correct. Can you get a motor from an earlier car (that would — ostensibly — have the force sensor in it). Would that work?
Old Mar 12, 2022 | 09:10 PM
  #507
cut7's Avatar
cut7
Can someone read their R53 KMB (Instrument cluster type) module & post the trace file here, please. (Post the text of the entire trace, or a link to the actual trace). The reason I need it is I'm having trouble reading my KMB module, I get an error; everything else reads fine. Preferably someone with a tach & speedo on the steering column & a chrono pack in the center.
Alternatively, if someone is reasonably close to me (that has a car spec'd as mentioned above) I will come to you, read the trace file, & help you code your car for free!
Old Mar 24, 2022 | 10:16 AM
  #508
littler50's Avatar
littler50
Hello,
how can I disable rear wiper washing function in NCS expert for Mini R50? Where is it located
thanks
Old Mar 25, 2022 | 03:59 AM
  #509
DogfaceSGM's Avatar
DogfaceSGM
Can NCS expert set the time instead of using the radio?
I have done a lot of searching on replacing the stock radio with an aftermarket. The only thing that appears to be an issue is you can no longer set the time. I would think with all the functions of NCS, it would be able to do this. I am just not sure which module it would be in.
Old Oct 2, 2024 | 11:30 AM
  #510
artoms's Avatar
artoms
Does anyone have the latest links? The ones in the first post have expired
Old Oct 2, 2024 | 12:21 PM
  #511
DogfaceSGM's Avatar
DogfaceSGM
Shoot me a PM.
Old Oct 2, 2024 | 12:59 PM
  #512
DogfaceSGM's Avatar
DogfaceSGM
I am not sure if it is because you are a new user but I cannot send a PM to you. I am not sure of forum "etiquette" for that. It let me add you as a friend.
Old Oct 2, 2024 | 05:34 PM
  #513
DogfaceSGM's Avatar
DogfaceSGM
I am assuming it will not let you PM me as well.
Old Oct 3, 2024 | 02:23 AM
  #514
artoms's Avatar
artoms
@DogfaceSGM Yes, it's the same for me - confusing! I've checked around the forum but the "gears" representing the user's reputation claim to be only cosmetical. I'm not sure if it's a time restriction thing..
Could you send me an email please? It's my username on this forum + @gmail.com
Old Oct 3, 2024 | 04:06 AM
  #515
DogfaceSGM's Avatar
DogfaceSGM
Before you get too deep, I think you might want to read the last entry in one of my threads.
https://www.northamericanmotoring.co...eardown-9.html
As stated, I am no expert by any means. Unless I have done it myself, I am not sure I can answer questions you have. If you look in this thread above my posts, the last one is dated 3-4-2022 and wasn't answered. The few things I have done are:
Corrected speed in digital speedometer
Factory reset my cars modules
Code Xenon Lights
Code JCW Brakes
If you are still interested, let me know.
Old Jan 20, 2025 | 12:39 PM
  #516
aztksmooth's Avatar
aztksmooth
Hello can you PM me new links? I have an r56. Thank you!
Old Feb 18, 2025 | 11:44 AM
  #517
squawSkiBum's Avatar
squawSkiBum
Moderator
Late to the party!
Yes I know I'm 10 years late. In 2021 my much loved and modded R56S was turned into a charcoal briquet when my garage burned down. I was without a Mini until a few months ago when I picked up a GP2 and came back to NAM. I'm working on retrofitting cruise control and how to code the car to enable it. I have been reading through all the various threads on coding and NCSExpert, after all this time many of the links are dead. I have managed to find, download, and install BMW Standard Tools 2.1.2, I think I have it all installed properly. I have a cable that should work. Before I go try it out on the car - does anyone have a copy of the step by step on how to change the Vehicle Order?
thanks!
Old Aug 17, 2025 | 02:39 AM
  #518
MicaLovesKPOP's Avatar
MicaLovesKPOP
Could you please send it to me as well? I've sent you a friend request in case that helps.
Old Aug 17, 2025 | 02:44 AM
  #519
MicaLovesKPOP
@DogfaceSGM Could you please send it to me as well? I've sent you a friend request in case that helps.
Sorry for the secondary message. I thought I had replied to your earlier message, but I see no sign of it, so you probably did not get notified. Cant seem to remove my earlier message either. Perhaps a mod can.
Comasynthesis
Electrical
146
Nov 28, 2018 06:24 PM
Jose Antonio Romero
Electrical
Feb 21, 2015 07:21 AM
vazdom
Electrical
Aug 21, 2012 11:26 AM
Guthrie
Jul 22, 2011 05:21 PM
larryzhou
Electrical
Mar 24, 2011 07:10 AM
