Electrical INPA Not Working... HELP!
Old Aug 14, 2012 | 08:12 PM
vazdom's Avatar
vazdom
Hello everybody,
I Brought INPA K+DCAN on ebay, I install and I see the black dots Ignition and Battery When I try to connect to ECU, AIRBAG and many others modules POP window come up with this message
grup file: D_Motor.
Sys-0012: Identification error.
program will be stopped
Can't read or erase error memory.
and with airbag
grup file: d_sim
sys-0012; identification error
But I can read the Cluster and few things only.
I have Ediabas 6.4.3 NCS Expert 3.1.0 INPA V 5.0.2
Any Idea will be very appreciate!
thanks.
Old Aug 14, 2012 | 09:14 PM
vazdom's Avatar
vazdom
Ok, Frist problem Solved...
Now I can read AIR BAG error memory, I can read many things but when I try to entry to Engine, or GearBox I have this new message
grup file D_KBM
bip 0009 best version error
malfunctions possible!
Old Aug 18, 2012 | 08:14 AM
spidertnt's Avatar
spidertnt
Depending on your cable and the year of your car you may need to join pins 7-8 together read / write to all components on the k-line. My cable could read some of the modules but not untill i joined 7-8 could it read the vin or write to a module. 2004 MCS preface lift
source http://osefactory.com/tools/k+dcan/A...patibility.pdf
Our K+DCAN USB Interface came in the beginning unlike products from
other vendors with full backward compatibility to older K-Line
equipped vehicles, many of those vehicles use besides the primary KLine on pin7 also the secondary K-Line on pin8 for additional modules
(ECUs). Unfortunately on the latest F Series DCAN equipped vehicles
that pin got re-used as Ethernet activation which interfered with that
full backward compatibility by causing connection problems.
Because most customers prefer the ability to work on latest DCAN
equipped vehicles over the full backward compatibility to older K-Line
equipped vehicles - pin8 was physically removed from the Interface to
enable that. The consequence from that step is that when used in
backward compatibility mode on older K-Line equipped vehicles that
the Interface now only covers modules (ECUs) connected to the
primary K-Line on pin7. Modules (ECUs) connected to the secondary KLine on pin8 will no longer be directly accessible.
Old Aug 20, 2012 | 09:09 PM
vazdom's Avatar
vazdom
well I have a R56s and Im using exactly this interface
Old Aug 20, 2012 | 09:11 PM
vazdom's Avatar
vazdom
https://www.northamericanmotoring.co...face-help.html
Old Aug 21, 2012 | 04:28 AM
spidertnt's Avatar
spidertnt
R56 your cable should be fine
Old Aug 21, 2012 | 08:12 AM
vazdom's Avatar
vazdom
Ok, thank you, I really appreciate your help. So what do you think can be my problem with IFH 0009 ??
thanks!
Old Aug 21, 2012 | 09:52 AM
spidertnt's Avatar
spidertnt
thanks!
From another site http://bmwgt1.com/bmw-dis-connection-problems/
INPA IFH-0009: NO RESPONSE FROM CONTROL UNIT ERRORS
If you experience the IFH-0009 No Response error in Inpa, then it indicates a break down (or lack of) communication between the Vehicle itself, and the laptop. More often than not, IFH-0009 errors in INPA are caused by the following problems.
1) Poor quality, or incorrectly wired interfaces. IFH-0009 errors are the most common in D-Can+K usb interface leads. Often these originate from China or Hong Kong, and can be badly constructed, incorrectly wired, or contain the wrong chip set drivers or come with no drivers at all!. Whilst not all Chinese interfaces are poor quality, buying cheap imported leads is a gamble and when problems occur the seller probably won’t be interested. It is therefore important that you buy an interface lead from a good quality, reputable Vendor.
2) Wrong or Incorrect Interface Drivers. Again, mass produced interfaces can often contain cd’s with the wrong chipset drivers or come with no CD at all. Without the correct (latest) USB drivers, your interface lead will not install under windows properly. Our software package comes complete with a popular driver which is compatible with most Chinese and Western produced USB Interfaces, which will often work if the one supplied from your interface lead vendor doesn’t or hasn’t been included.
3) Incorrectly configured interface lead. Again, one of the most common problems with USB type leads. When installing a D-Can or Usb Interface lead, you will need to reconfigure the Windows based com port settings, so that the USB lead, appears to replicate an old RS-232 serial port. To replicate the port correctly, you need to change the existing Com port setting of the USB interface within Windows to Com Port 1 and change the latency setting to ‘1′ and check any ‘Fifo’ box
4) Incorrectly wired interface. Once again, there is no set standard as to the wiring pin configurations used within D-Can + K interfaces, by the various manufacturers. Some interface leads have pin 8 disconnected, some have pin 8 physically linked (bridged) to Pin 7, and some have pin 7 & 8 connected individually with no bridge link. If you still have problems connecting to the vehicle, and still get ‘IFH’ style errors then you should open the OBD Socket of the lead and check the pin wiring to see which type of interface you have. You should consider trying your interface lead, with the following configurations….
i) Pin 8 joined to Pin 7 using a small wire link
ii) Pin 8 physically disconnected
iii) Pin 7 and Pin 8 individually connected to their own pins with no link.
More often than not, one of these configurations will work with your vehicle, I recommend trying it with pins 7 & 8 linked together first, as this is by far the most popular vehicle configuration.
Also don’t assume that once you have found the pin 8 solution which works with one vehicle, that it will automatically work with a different model. If you have more than one D-Can equipped vehicle, you may need to obtain a second interface lead and configure ‘pin 8′ diffrently.
If you don’t own a soldering iron, or if you don’t feel confident about soldering electrical connectors, then there are adaptors available which will bridge pins 7 & 8 together, without any need to open the OBD socket or solder.
5) Incomplete Versions of INPA. There are many versions of Inpa around, many of which are incomplete or simply lack the various configuration files in which to work correctly. If you try all of the above and the IFH-0009 problem still remains, then you will need to consider buying and installing the full version of Inpa which includes Ediabas and BMW Standard Tools
Old Aug 21, 2012 | 11:26 AM
vazdom's Avatar
vazdom
I see, ok Im 90% certain that my problem comes from INPA installation, or my drivers are wrong I think that because I can Erase Memory I can entry to AIRbag and some modules but I can read DTC. I cant get Any code....
Im looking for a correct Inpa version I think is INPA v5.02 ediabas 7.02 and NCS expert 3.8.1 right???
I found this in other forum...
http://forums.bimmerforums.com/forum....php?t=1673155
seems like this is a complete INPA version, what do you think? another thing Im looking for the Drivers, but I can't find the driver..... the only link i found is this
http://www.ftdichip.com/Drivers/D2XX.htm
When I install Driver (the driver that comes with the cable) In MSDOS screen I see in one line: Expected = Warning
Warning! some Values have no standard data - may be there are problems -
Press any key to continue........
dutchhome
Sep 30, 2015 07:17 AM
skippermini
Aug 13, 2015 06:13 AM
Shoe Coupe
Electrical
May 6, 2015 08:50 AM
everlast
Electrical
Jun 24, 2013 07:13 AM
vazdom
Electrical
Aug 28, 2012 08:23 AM
