Electrical NCSExpert for beginners
Old Feb 1, 2015 | 03:28 PM
  #401
bratling's Avatar
bratling
Super Moderator
Originally Posted by djenks76
That would be awesome. Dealer wants $1299 for the whole shebang...just the programming alone would $350.
Can anyone supply the VO string he will need? I don't see the CD changer in the known codes worksheet:
https://docs.google.com/spreadsheet/...5bUgyZFE&hl=en
Old Feb 1, 2015 | 05:05 PM
  #402
Kevdog's Avatar
Kevdog
Looks like it will be a $694 if the car was prewired for a changer, in which case it looks like a CD changer would be plug & play. Also no coding is probably necessary.
Looks like a car with a CD changer is coded as a $672 in the VO.
I just typed "mini cooper r56 6 cd changer" in Google and found instructions for an ipod retrofit. The doc refers to the VO options.
Old Feb 1, 2015 | 07:07 PM
  #403
djenks76's Avatar
djenks76
I appreciate everyone looking in to it. I have a cd changer heading my way from a salvage yard for $100 and I've found the wires all ready to go. I will report back on the plug and play. I still want to explore the programming for other fun stuff.
Old Feb 19, 2015 | 12:05 PM
  #404
Dimitris Sofianopoulos's Avatar
Hi,
at ncs expert pushing ZCS/FA f. ECU, I choose CAS (and FRM) it gets me back with an error :
VIN is faulty
COAPI-2001: EDIABAS not initialized
Can someone help me?!! Thanks..
Old Mar 17, 2015 | 03:23 PM
  #405
Luis Ramos's Avatar
Luis Ramos
Hi guys, I've just tested on my 2011 R56 and I got NCS Expert working using Datens v40 (v38 wouldn't get the FA code, and sometimes give me VIN Faulty).
But my battery went dead, the car wouldn't start up. Should I be doing this with the car completely on (not just ignition on)?
Also, the coding didn't work (tried to get the comfort window and roof closing), but I believe it was because of the battery.
Did someone have this problem?
Thanks.
Old Mar 17, 2015 | 05:11 PM
  #406
cerenkov's Avatar
cerenkov
Don't do it with the car running.
It is best to have a battery charger connected when do it. That way you don't have to rush.
Old Mar 18, 2015 | 10:56 PM
  #407
Luis Ramos's Avatar
Luis Ramos
cerenkov, thanks! but why is that?
Old Mar 19, 2015 | 02:59 AM
  #408
cerenkov's Avatar
cerenkov
I wouldn't want to have the car running during the process of writing to the different computer modules because they "reboot". I wouldn't want to have the car running when they reboot. It might be ok but I wouldn't try it.
Most people recommend a using a battery charger, especially if you default the whole car.
Old Mar 19, 2015 | 07:35 AM
  #409
bratling's Avatar
bratling
Super Moderator
This! I have depleted my battery enough during coding that the car needed a jump. If you are quick about it, no big deal, but if like me you take your time, changing one thing at a time and testing each step, plus occasionally screwing up and then fixing it, it can take down your charge just enough to be a problem.
Old Mar 19, 2015 | 12:53 PM
  #410
siriuszero's Avatar
siriuszero
FWIW, I've coded my CM with the engine running as I don't have a battery tender with enough juice. No problems at all though.
The only thing you don't want to have the engine running for is for any changes made to the engine module, which this thread isn't about anyway.
Old Mar 19, 2015 | 02:23 PM
  #411
cerenkov's Avatar
cerenkov
^^Good to know.
Old Mar 20, 2015 | 07:55 PM
  #412
Luis Ramos's Avatar
Luis Ramos
Did someone have or knows somebody that bricked the car? And what about that engine modules, is this like "chip" the car?
Old Mar 21, 2015 | 10:51 AM
  #413
siriuszero's Avatar
siriuszero
While I haven't bricked my car, I have had a couple scares:
- When coding the sunroof module, I somehow glitched the safety pinch sensor and it would would only close an inch at a time
- Forgot which module it was, but I somehow glitched my MINI into thinking my active spoiler was in the up position....I had a Countryman, not a coupe....
Both errors were caused by using older datens than what my car had and since, I've learned how to recode to default to fix such errors.
Old Apr 3, 2015 | 11:45 AM
  #414
Luis Ramos's Avatar
Luis Ramos
I've just tried to change the "KOMFORTSCHLIESSUNG_FB" at the ca module, but when I hit process and it returns "Coding ended", there's no "click sound" and nothing happens. Seems that NCS is not writing the file to my car.
Did anyone have this problem?
Using v40 datens.
Thanks!
Old Apr 3, 2015 | 12:07 PM
  #415
cerenkov's Avatar
cerenkov
Originally Posted by Luis Ramos
I've just tried to change the "KOMFORTSCHLIESSUNG_FB" at the ca module, but when I hit process and it returns "Coding ended", there's no "click sound" and nothing happens. Seems that NCS is not writing the file to my car. Did anyone have this problem? Using v40 datens. Thanks!
Just did it yesterday to fellow NAM member car and I can't remember if I heard clicks when doing that module. Make sure that your job selection is SG_CODIEREN.
Does your other coding in other modules work?
Old Apr 3, 2015 | 12:32 PM
  #416
Luis Ramos's Avatar
Luis Ramos
I decided to try one more time before post again, and for some reason it worked (I did the exact some way I was doing before)! It took a couple of extra seconds to process and it did make a "click" sound.
I'll try some other modules too.
Thanks man!
Old Apr 3, 2015 | 01:01 PM
  #417
siriuszero's Avatar
siriuszero
Using v40 datens.
Thanks!
Those are pretty old datens - any reason you're not using newer ones? I think v51.2 is the newest I've seen.
Old Apr 3, 2015 | 01:07 PM
  #418
cerenkov's Avatar
cerenkov
I was wondering the same. The newest are 53.0.5.
Old Apr 3, 2015 | 01:23 PM
  #419
Luis Ramos's Avatar
Luis Ramos
Hum I'm using the ones that came with GTECKO's pack. Didn't realize it was 4 yeas old hehe. I'm gonna update them.
Thanks!
Old Apr 3, 2015 | 01:30 PM
  #420
siriuszero's Avatar
siriuszero
It won't make much of a difference if the software in the car is as old or older than the v40 datens, but if the software is newer, you may run into issues down the line. That's how my CM got accidentally coded into thinking it had a retractable spoiler.
I recommend downloading the newer datens and make sure you DELETE the old one completely before adding the new one. Overwriting datens causes all sorts of issues.
What year/model is your MINI?
Old Apr 3, 2015 | 02:24 PM
  #421
Luis Ramos's Avatar
Luis Ramos
Mine is R56 2011 . . . Im trying to find the latest daten, do you have a source?
Old Apr 3, 2015 | 02:34 PM
  #422
siriuszero's Avatar
siriuszero
This thread has the most up-to-date datens:
https://www.northamericanmotoring.co...ml#post3979610
Old Apr 3, 2015 | 02:44 PM
  #423
Luis Ramos's Avatar
Luis Ramos
Thanks man!
Old Apr 3, 2015 | 05:59 PM
  #424
scf's Avatar
scf
I also downloaded the datens, thanks!!
But..I can't find a working link for the software itself. The links I've tried, either no longer are valid, or what I download doesn't work.
Old May 1, 2015 | 07:40 AM
  #425
dez's Avatar
dez
I got the software from the bimmerforums page last night.
Still waiting on the cable and having some issues with the software reading the datens file but I haven't spent much time on it yet. Mostly just reading
