Electrical NCSExpert for beginners
I can't remember the menu option, but one of the choices on the top menu let's you connect devices to the VM. You have to use that when you connect you cable for it to be able to talk to the car. Maybe you have to do the same thing for your USB drive.
I see the change for the MINI Connected warning in the CHAMP module but my current configuration won't let me access it. I am running the latest version of NCSExpert but I've got the v34 daten files. I'm guessing the CHAMP module wants newer datens?
Also, has anyone had any luck with accessing the KOMBI module on a '12 model? I've tried twice and both times, it didn't turn out so well so I'm wondering it it will also respond better to the newer datens.
Can the current configs be saved as a file, and then also can you save the changed configs as a file? Would like to be able to perform a quick restore to OEM if needed for warranty, and then go back to the "customized" config thereafter... Have not been able to check myself as my car is still on her maiden cruise from England!
I'm at work and can't get to any of my tools but I've got a question from one of my club members re: coding.
Has anyone looked into coding a new key or reprogramming new keys so that a lost key won't work? The dealership does it through the OBDII port and I suspect it's in the CAS module but I'm not able to check on it for a while. Anyone have any insight into this? Thanks!
The WDS states the following:
Car access system (CAS)
Functional description, see BMW Technology:
TIS --> Document --> SI Technology --> SBT Number 61 03 03 019
Service functions
Replacing control units
The following points must be borne in mind when the CAS or the engine control unit are replaced:
In the case of a new engine control unit, the service function ”DME/DDE - CAS adjustment” in the BMW diagnosis system is used to read the EWS drive-enable code from the CAS and transfer it into the engine control unit. This means that the engine control unit and the CAS control unit are mutually linked.
If the engine control unit is already linked to the CAS, the service function is used to perform a starting value calibration. This means that the random code calculation between the CAS and the engine control unit is calibrated.
A start calibration is required if there is a variance in the random codes caused by the influence of errors in the two control units.
As of EWS4, a start calibration is no longer required.
Locking the remote control/spare key
The service function ”Remote control/Lock/Enable Key” in the BMW diagnosis system can be used to lock or enable remote control keys or spare keys.
The locking is recommended when a remote control key or a spare key is lost or stolen. With a locked remote control key (or spare key), the engine cannot be started. The functions of the remote control are also locked.
A remote control key or a spare key can only be locked if the remote control key or spare key has been used at least once and it is not inserted in the ignition lock.
To perform the service function, it is required that a valid and enabled remote control key or a valid and enabled spare key is detected in the ignition lock.
Activating a new remote control
Insert the new remote control in the slot and hold in this position until the remote control locks into place. This can take up to ten seconds. After locking, wait another five seconds. The remote control is then ready for use.
If the remote control is a replacement for a lost or defective remote control, the old remote control still has to be blocked using the service function ”block/release” (see above). To use the Car/Key functions, the service function ”Personalisation number” has to be run.
Service functions
- If a CAS control unit is replaced, it must be ordered using the vehicle identification number (VIN). Following installation, that starting value must be adjusted to the engine control unit. This starting value adjustment is performed using the service function ”DME/DDE - CAS calibration” in the BMW diagnosis system.
- If the engine control unit is replaced, the drive-enable code must be transferred from the CAS to the engine control unit following installation. This operation is also performed using the service function ”DME/DDE - CAS adjustment” in the BMW diagnosis system.
- After the adjustment of the EWS and engine control unit, these are mutually linked. It is not possible to replace one of the two control units as a test.
i used the download from this site for ncs, installed it and made the necessary files.
i open ncs and use revtor profile i get to the point were i choose "r56" it then gives an error saying my chassis is faulty. any suggestions?
I started over and got the datens figured out, helps when you follow the pdf lol Im now getting a faulty vin. any suggestions?
VIN is faulty
COAPI-1060: error in coding discription file
A_E65CAS
VIN is faulty
A_E65CAS
i figured out the vin problem.
im trying to remove the bulb checks. i went threw and changed all the ones needed to nicht_aktiv when i go to load it back into the car im getting another error
error in cabd! Look at CABI.ERR and ERROR.LOG!
COAPI-2000: EDIABAS or SGBD error
SYS-0005: ECU description file not found
Im slowly figuring out my mistakes but im afraid of messing something up
im using the v38 daten, not sure if i need both 38 and 40 or just one of the two.
I'm not having any luck with finding daten files or NCS expert download links that work either. Didn't find anything on the bmw forum either.
looks like a pogo stick in a mine field to me
What will it get you?
It'll let me deactivate my old radio and activate the new one as well as activate the heated seats that I'm about to install. I'm sure there are countless other things that it will be useful for later on, but for now that's enough. But mostly, it will help me sever the umbilical cord from momma BMW.
+1
i'm stuck.
I have the cable, multiple versions of all involved software (tried 6.4 and 7.1 eiadbas and lots of different datens in NCS) - and i can't get past trying to read my VIN in NCS. It always comes back and says VIN Faulty, no response from ECU.
any ideas?
any ideas?
yeah - i'll give it another shot. i feel like i've done this 5 times already, i'm leaning towards having a faulty cable except i can get both the battery and ignition circles filled in using INPA so i know the computer is seeing action at the car using the cable...
5th times a charm!
5th times a charm!
5th times a charm!
5th times a charm!
after over 50 hours invested i just found out my cable isn't a true D-Can cable... I missed the fine text saying it's kline only when i bought it. Totally my fault.
my mistake but at least i truly know where i went short! can't wait to get a new cable and get this puppy programmed...
5th times a charm!
5th times a charm!
I copied the bin files, the ini files, latency is 1, com port is 1, etc...
full black circles in INPA but I can't read to modules... my car is a 2005 so I shouldn't need the jumpered cable. IF ANYONE FIGURES THIS OUT, PLEASE SHARE!
